Wonderbar
Old Mar 24, 2002 | 07:25 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Wonderbar
1.) What is it?
2.) What does it do?
3.) Where do I get one?
4.) How much does it cost?
5.) Is it worth it?
Could I be anymore direct??
Old Mar 24, 2002 | 08:02 PM
poncho9789's Avatar
Do a search on WONDERBAR and you will come up with all the answers you need and more.
yes it is worth it
it is cheep
it stiffens the front end
JUNK YARD.
Old Mar 24, 2002 | 08:24 PM
Car: 91 RS
Engine: 350 TBI
Well I checked the archives, but they really aren't all that useful. I did get a part number, but if I get one from a junk yard, that really doesn't mean anything.
What did they come on?
And how easy are they to install?
Do I need one--->91' RS?....or do I already have one?
Old Mar 24, 2002 | 08:44 PM
poncho9789's Avatar
The only cars they came on was the Iroc's your car doesn't have one unless someone put one on there which is doubtfull. GM nolonger sells them so you can either get one from a junk yard (iroc)or order one from wings west ($40). As for instaliation of them a drunk monkey could do it and not hurt himself. You would take your bushings loose on the sway bar and put the wonder bar under the bushings and tighten the bolts back up. I have seen cars were they just welded a piece of square bar at the front of the subframes right behind the lower radiator support.
Old Mar 24, 2002 | 08:52 PM
Car: 91 RS
Engine: 350 TBI
When it comes to suspension, I'ld pay a drunk monkey to do the work for me, cause I do not trust my ability that much. I'm only good at preventive maintenance type stuff.
So it just slides onto the endlinks? Or do you just sandwhich them in there? That doesn't sound very safe?
Old Mar 24, 2002 | 08:59 PM
Jza's Avatar
Jza
http://www.sethirdgen.org/wbar.htm
Shows you what it looks like, where it goes, and how easy it is to install.
Old Mar 24, 2002 | 09:02 PM
poncho9789's Avatar
No the sway bar bushing not the end links. The ones that attach to the frame. about 2 foot apart.
It is ok we all have to learn someplace. This is a great place to learn.
Old Mar 29, 2002 | 07:26 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
there is a member on this board names "lonsal"do a search on him .he fabricates wonderbars
Old Mar 30, 2002 | 12:07 AM
Buck268's Avatar
I am a moron, but I had NO problems installig my wonder bar... Very straight forward. It it helps sooo much - my car would creak and groan like it was orgasming when I would back outa my driveeway - now it doesnt, barely at all. I can really feel the front end tighten up (I alos put new endlinks on, with poly bushings...). Anyways, go fer it! Its not hard (once ya get under the car and see what ppl are talking about!).
Old Mar 31, 2002 | 09:17 PM
89 Drop Top's Avatar
Car: 89 RS Convertible (Original owner)
Axle/Gears: 3.73 With Zexel Torsen Ltd. slip
I just scored 2 of them yesterday at the local junk yard , and sorry, no, they are not for sale. One is going in the convertible, and the other is going in my '85 Iroc coupe, which for some reason, didn't have one in it, go figure . I'm glad to hear the positive responses about it, as I wasn't quite too sure about it's benifits, you guys all rock!!!!!:rockon:
Derrick
'89 RS Convertible
'85 Iroc Coupe
Old Mar 31, 2002 | 09:26 PM
Car: 91 RS
Engine: 350 TBI
Yeah, I've already searched everything around here, but to no avail
I'm just going to buy the Global West one and be done with it. Atleast it'll be purtty
And after looking at that link the Jza left, I feel like a real A$$. Forget the drunk monkey, I think a "Mr. *****" could even do this.
Old Mar 31, 2002 | 09:46 PM
breathment's Avatar
iv heard that this really isn't worth anything... plus the extra weight.. otherwise i think pontiac would of used them on the WS6 cars..
Old Mar 31, 2002 | 10:56 PM
CrazyRob75's Avatar
isn't worth anything? you wait until your weak frame cracks around the box and then tell me it isn't worth it. The thing weighs next to nothing. I'd happily trade 5-10 pounds for the increased strength i got.
Old Apr 1, 2002 | 02:08 PM
Buck268's Avatar
I too will vouch for its worth. After I put it on, I could really feel the front was tigher! (esp. when backing down drive!) :lala:
Old Apr 3, 2002 | 09:14 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Check the link:
https://www.thirdgen.org/techbb2/sho...threadid=97201
Old Apr 3, 2002 | 09:37 PM
Car: 91 RS
Engine: 350 TBI
Well yall.....it arrived today, and in less than an hour I had that bad boy on my car. This thing is the shizit!! If you don't have one, I highly recommend it. If you have t-tops, YOU SHOULDN'T BE W/O ONE. It's amazing how much flexing that thing takes out. Also, as an added bonus, my t-tops no longer squeak ......now I can't wait to put in Spohn's SFC.
Thanks to all that replied:rockon:
Old Apr 4, 2002 | 08:39 AM
Steve89GTA's Avatar
I saw an 86 IROC at the bone yard. Would it have the wonderbar?
What is the size socket that I would need to remove the bar? I heard 15mm. Does anyone know for sure?
Thanks,
S
Old Apr 4, 2002 | 11:19 AM
Car: 91 RS
Engine: 350 TBI
15 mm is the correct size, but I'm not sure the 86 IROCs had them.
Old Apr 4, 2002 | 11:25 AM
VortecZ's Avatar
Car: Camaros
Yes, the '86 IROCs had them.
Old Apr 4, 2002 | 11:28 AM
Steve89GTA's Avatar
Awesome, I'm gonna go pull that sucker Saturday. I'm guessing it'll fit on my 89 GTA
Only thing I'll need is a 15mm socket right? (and a Torque arm).
Old Apr 4, 2002 | 04:52 PM
mat89RS's Avatar
If I do my own WonderBar and weld it ... just like mentionned previously... will it work as well as the real thing ?
Old Apr 4, 2002 | 05:05 PM
breathment's Avatar
why did only the Irocs have them??
Old Apr 4, 2002 | 09:01 PM
Momar's Avatar
I dont know why only the irocs had them but if you do a search on them you might find some pictures of what can happen without it. I saw some pictures of a guys car where the frame cracked up front by the steering box and he had to have it welded. These in adition to stoping general flex are supposed to prevent the stress that causes these cracks.
Ben
Old Apr 6, 2002 | 09:36 AM
OK Guys, I just installed one of them on my 'vert last night, and all I can say is WHOLY ****!!! WOW! I can't belive how that little piece of metal realy tightened the car up! Just like everyone else has stated, the car definitely feels much tighter, and seems to track through the turns better also. I would highly recommend this to anyone who has a convertible. It really eliminated a lot of front end body flex, which was evidenced when I pulled out of, and into my driveway. I can't wait to get the coupe done now and put the other one on that car!!!:rockon:
Old Apr 6, 2002 | 11:14 AM
breathment's Avatar
i guess I'll have to get one
Old Apr 6, 2002 | 02:24 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Does that Wings West have a website or contact phone number?
Old Apr 6, 2002 | 02:43 PM
Momar's Avatar
I thought it was made by global west. http://www.globalwest.net/ it is listed for 46 something partway down the page on the subframe connector page. It is in the picture with the subframe connectors for 82-92 camaro/firebird.
Old Apr 6, 2002 | 04:51 PM
formul8!!'s Avatar
Car: 2004 GTO
I have the Global West bar on my '89 Formula. Cost under $50 with shipping.
It was pretty easy to install. I did let the sway bar go accidentally and it whacked me in the head, but that was my fault.
It really tightened up the steering. No more groans and front wheel hop when pulling into tight parking spaces. I have a set of Hotckis tie rod sleeves ready to go on. That should make the steering system feel even better!
DEFINITELY worth the money. Skip the GM piece, go with the GW bar!!
Old Apr 15, 2002 | 12:10 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Wonderbar...
Does ANYONE have a photo of it...I can't find one anywhere. I'd like to see both the GM Wonderbar as well as the GW...
Old Apr 15, 2002 | 12:42 AM
lonsal's Avatar
I can't supply pic's of GW's version. But I can supply pictures comparing TDS's (Top-Down Solutions) version to GM's.
This is the prototype piece I've completed. I'm currently building the first production run and expect to have them available in a couple of weeks. Lon
Old Apr 15, 2002 | 01:11 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Why did the IROC's have them?? For more bracing and better handling.
Old Apr 19, 2002 | 09:28 PM
3gc's Avatar
3gc
Car: Z28
According to the Parts and Illustration Catalog and GMpartsdirect.com the wonder bar is still available from GM.
<p><img src="http://www.3gc.net/6-02.jpg"></p><p><img src="http://www.3gc.net/6-04.gif"></p><p><img src="http://www.3gc.net/wonderbar.jpg"></p>
Old Apr 19, 2002 | 09:52 PM
lonsal's Avatar
14079634 is the correct pn for the Steering Brace (aka Wonder Bar). Or should I say "was". It is indeed discontinued. Lon
Old Apr 20, 2002 | 10:47 AM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
what will you be charging once to get these things in production?
Old Apr 20, 2002 | 11:38 AM
lonsal's Avatar
My version of the Steering Brace (aka Wonder Bar) is in production. I've just not finished the first run yet. I sent you my Price List via e-mail. The TDS 105021 82-92 F-Body Steering Brace is $40. The TDS 106021 89 TTA Steering Brace is $47.50. If you have any other questions or would like to order one, e-mail me at: topdownsolutions@yahoo.com. Lon
Old Apr 22, 2002 | 07:45 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i just ordered part#14042019 through my local GM dealership the cost was $7.00 i should have it thursday.
Old Apr 22, 2002 | 09:22 AM
lonsal's Avatar
I bought my Wonder Bar pn 14079634 through VanDevere Olds about 3 years ago for $22.46 plus shipping. Do you really think GM would sell the Steering Brace (aka Wonder Bar) for $7? That should be a big clue that the pn you ordered was incorrect. But we'll wait until Thursday for you to confirm as much. Lon
Old Apr 22, 2002 | 09:35 AM
91banditt2's Avatar
Engine: 5.7 HSR
yeah i know $7 for something like that is hard to beleive but i figure it's only $7 bucks!!
Old Apr 22, 2002 | 09:56 AM
lonsal's Avatar
Don't forget to take a picture of it and post it. BEFORE you return it for credit of course.
Old Apr 26, 2002 | 06:22 PM
lonsal's Avatar
Hey 91Banditt2, why are you keeping us in suspense? What did you get by mistake instead of the Wonder Bar? Curious minds want to know.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
