Some, Final Answer, notes
Old Mar 31, 2002 | 08:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
When trying to set up a calibration to be real responsive, two things to rmember:
Set delays to the min.
Set filters, high.
There is no harm that I've found by lowering enable temps., ie TCC, DFCO, C/L, EGR enable, CCP enable, etc.. If you don't want to use something like EGR, then set the enable temp really high. But go thru the hac or whatever documents you have, and make sure you have all the enable temps set at a resonable temp..
Work in one area of the EPROM at a time. Doing IAC, then do that, don't try and get AE dialed in as you move the throttle follower settings.
If you're not running much gear, delta TPS AE can be really helpful to get things crisp coming off of idle. If your MAP AE is zero'd out don't be afraid to try and use it. Especially if you having to add alot of TPS AE. It's a PITA dialing in the AE, TPS, and AE MAP/MAF but work back and forth *slowly* and you'll get what it is you have to do. And once you think you're clear on it, don't be afraid to rethink what it is you think you know.
The bigger the cam the more the engine self EGR's at idle, so you'll need a fair amount of fuel, AND timing. Don't be surprised if you run 30d timing at idle, but getting the engine to decclerate back down means getting the DFCO stuff really right.
It's all a blend, AE, PE, DFCO, idle, cruise, they all work together, and the transistions from one to the other are what seperates the men from the boys.
Old Apr 2, 2002 | 09:04 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
WOW! That was a lot to swallow. Thanks Grumpy!
Old Apr 3, 2002 | 03:26 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
to those of us that arent all up to snuff on the acronyms can you define those? common ones such as EGR, MAP/MAF, TPS no prob bot the rest?
I guess its best to say "were not worthy":hail:
Old Apr 3, 2002 | 06:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Sure hope you not seriously complaining there.
To really grasp the abbreviations, it's as much using them as defining them, so any discription is going to be some what lacking. Getting familiar with the terms means reading and rereading hacs, and then with the hac in one hand try some changes and see what you have.
In short
AE= Accleration Enrichment (acclerator pump in a carb).
DE= Deccleration Enleanment
DFCO= Deccleration Fuel Cut Off
PE= Power Enrichment
Some thing as simple as AE acutually means
delta TPS to allow AE enrichment
delta MAP or MAF
AE vs Coolant temp.
enrichment due to delta TPS
Sometimes there are other coolant temp corrections, enables.
PE also has a bunch of sub categories
Coolant Temp enable
% TPS, enable
% enrichment
WOT AFR
% enrichment by RPM
% enrichment by TPS
(delta=difference)
Old Apr 3, 2002 | 10:06 PM
monte-ss's Avatar
no not complaining, just wondering and being sarcastic, but thanks for the info, just doing some research on starting to do some prom burning of my own and reading the posts and trax's article on how to do it.
Old Apr 4, 2002 | 12:17 AM
chiefz28's Avatar
hey thanaks for the info I 'll be sure to click this one into MY FAVORITES.with all the other good topics such as this one
Old Apr 4, 2002 | 02:28 PM
Bobalos's Avatar
for those that dont know, Grumpy has written a number of posts that have "final answer" in the title. There is a lot of good followup information in them, that kind of takes Traxions article to the next level. Check them out.
BW
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Oct 3, 2015 01:25 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
