please post pics of 15" subs in 3rd gen!
Old Apr 11, 2002 | 09:36 PM
outragis's Avatar
I have a single JL 15w6, and I would like to use it in my 86 Iroc, any ideas or suggestions? Thanks
Old Apr 12, 2002 | 12:31 PM
KlayBuRn's Avatar
Old Apr 12, 2002 | 03:15 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I use to have a pair of those, they kick ***!!!
RF rule!!
Old Apr 12, 2002 | 05:43 PM
KlayBuRn's Avatar
I know, i was really impressed by them, for only being 200 RMS, it slammed pretty hard...Just as good as 1 600 RMS HX2...
Plus my box was way off, i bought a box for 2 12' Earthquake HP's and cut out more for those 15's...
Old Apr 13, 2002 | 09:52 PM
outragis's Avatar
Nice set-up, what are the box's measurments?
Old Apr 14, 2002 | 01:00 AM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
That is.......a hella lot of wires, lol. Like the setup though, its tight. what are the specs on the 2 amps and what is each one running? Did you have to change altenators or you got strike caps hidden somewhere?
Old Apr 18, 2002 | 10:07 PM
THEISENATOR's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
What model amps are you pushing those with?
Old Apr 19, 2002 | 02:06 AM
KlayBuRn's Avatar
Ok, ill start by explaining my wires in the picture...
2 sets of RCA's, a spliced remote wire, 2 8 gauge power and 2 4 gauge ground wires for amps, 2 more 8 gauge power and 2 4 gauge ground for 2 1.0 farad caps under the interior paneling, and the other 4 gauge in you see, is a 2nd battery in the other interior panel...
fronts where fosgate 4x6's off deck
6x9's kenwood excelon 4 way 6x9's being pushed by the pioneer gmx1022, which was 400x1 @ 4ohm, or 100x2 @ 4ohm, the 6x9's where 100 RMS...
Amp for 2 15' XLC's(200 RMS a peice), was being pushed by the RF 800.2 (800x1 @ 4ohm, or 400x2 @ 4ohm, needless to say, i had the gain down a little), the box was designed for 2 12' Earthquake HP's, i think 1.25 Cube a side(it was a split box, one with the board in the middle) i just cut it out to drop the 15's in, basically stuffed it to the speakers, and it pounded....
deck, pioneer premeir DEHP412 ?
know nothing of box's measurements...
Old Apr 20, 2002 | 11:34 PM
EjBaL's Avatar
question, I am going to be hooking up 2 amps, did u run the remote wire to one amp, then from that amp to the other, or where did you splice it at?
Old Apr 22, 2002 | 01:33 PM
KlayBuRn's Avatar
You can do it one of two ways...
You can either...
A. Run your single remote wire to the terminal on the amp, then with a seperate wire, just run it from that terminal to the other terminal on second amp...
B. Or splice it before you run to your amps(like i did, i believe you cant see it in the picture, but i just ran it to a butt splicer thing and plugged each wire into the splice...
Either way it dont matter, the remote wire carries such a small current to tell the amp to kick on, it doesnt matter, so amp to amp, or splice....
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
BADNBLK
Nov 16, 2016 09:12 AM
1985chevydude
Aug 20, 2015 12:29 AM
reiderz iroc
Aug 13, 2015 04:57 PM
