86 V8 non-WC T5 conversion
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
The transmission is from a 1986 LG4 Trans Am that had 114K miles. I did drive the car and the trans shifted smoothly and operated without any funny noises. All parts are used. You get:
T5 transmission (WG 13-52-157, electric speedo)
Bellhousing
throw-out bearing
clutch fork
clutch assembly
Flywheel (casting #14088671 1-piece seal, ext balanced)
Torqe arm brackets
Transmission mount
Clutch and brake peddle assembly (w/switches and pigtails)
Hydraulic cylinder assembly w/resevoir
Transmission wire harness pigtail (cut off where it entered engine harness)
Dust/inspection cover
Hurst shifter
Consol shifter plate (broken)
What is missing for a complete automatic conversion is the lower shift boot. It was cut away by a previous owner.
Asking $485 shipped to anywhere in the lower 48 states. Save an additional $40 if you don't want the clutch and flywheel as they have to be shipped seperately.
More pics:
Bellhousing
throw-out bearing
clutch fork
clutch assembly
Torqe arm brackets
Transmission mount
Hurst shifter
More pics:
Car: 69 Olds F85
Engine: SBC 11:1 w/ aluminum topend
Transmission: Hurst commanded 4-speed
Axle/Gears: Built Chevy 12 bolt w/ 3:73s
I could do $400 shipped. I live next door in WI so that should help shipping. Let me know.
WSBADMF found one closer to home. Anyone else?
Price reduced: $435 shipped, without clutch and flywheel $395 shipped.
Peddle close-up and hydraulics
The other pictures you wanted. I double checked all the fasteners. Missing from the picture are 4 M6 screws for the inspection cover. I'll pick those up tomorrow on my way home. The bolts for mounting the peddle assembly will come from your car.
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
alright cool thanks for the pics thats exactly what i needed im going to pick up the cashiers check tomaro morning from the bank. so look for it middle of next week.
Sorry knoxie90,
Deal pending:
Maroon88iroc is buying everything except the clutch, flywheel and broken shift plate.
Deal pending:
Car: 88 IROC
i recieved it today everything looks 100% exactly how its pictured. im very glad it worked out ive never done a transaction like this so im glad it went smooth. rob is a great seller, kept me informed about everything and i got the package immediately there was a little delay on my part on getting the money to him but it was my own stupidity and im sorry about that but thanks for bearing with me lol.
Yor
Feb 15, 2010 02:13 PM
