Then... and Now! :D
Old Aug 11, 2011 | 12:38 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Then... and Now! :D
Then... and Now!
I thought it would be interesting and cool to see your rides as they were when you first got your car and what it looks like and has now.
Include specs when bought and current specs now if you are feelin' it!
Note: Day 1 for me was July 15, 2008.
Day 1:
Now:
Day 1:
Now:
Day 1:
Now:
Performance(1/8th mile):
Day 1: 9.99 @ 72.x mph, 2.3x 60'
Now: 8.29 @ 85.2 mph, 1.84 60'
Day 1:
350
T5 5 -Speed, non-WC
3.23 gears, open drum diff
Now:
Engine
*Small Block 350 + .060" (5.9L, 360cu)
*10.5:1 compression, 93 octane fuel
*71' Corvette Heads - Pocket porting, double spring, 1.60/2.02 valves
*XE274 Comp Cam, 230/236 @ .050, .487/.490 lift
*Holley 750 DP w/ Holley HP main body
*Edelbrock RPM Air-Gap intake
*Hypereutectic Domed Pistons
*Fully Balanced Rotating Assembly
*Centerforce Flywheel
*ARP bolts
Transmission
*T56 6-speed
*Pro 5.0 Shifter + UMI Short Stick
*Spec Stage 4 6 puck unsprung
*LT4 PP
*Hawks T56 conversion crossmember
*Hedman Longtube Headers
*True-Dual 2.5" Straight pipe exhaust
*Flowmaster 40 Series 2 chamber mufflers
Suspension/Tires
*BFGoodrich g-Force Sport, 245/50/16 front, 255/50/16 rear
*Spohn rear lower control arms, tubular, polyurethane bushings
*Spohn lower control arm relocation brackets
*Subframe Connectors
*Spohn poly panhard bar, polyurethane bushings
*Edelbrock tubular torque arm
*36MM front/24MM rear sway bars
*Polyurethane front and rear sway bar bushings
*Polyurethane transmission mount
*Polyurethane torque arm mount
*Wonder bar
*Bilstein shocks/moog springs
Rear end
*10-Bolt 7.5"
*4.10's
*Aluminum girdle w/ support caps
*Moser 28-spline axles
*Moser wheel studs
*Zexel Torsen differential
*Solid pinion spacer
Exterior
*GM Victory Red base coat/clear coat
*Tint: 5% rear/20% sides
*Custom made aluminum nose emblem
________________________________________________
Hope to see a bunch of awesome transformations!
Old Aug 11, 2011 | 02:37 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Then... and Now! :D
Its always fun to see "Then in Now" but i like during... that's something you rarely see... Nice improvements btw
Old Aug 11, 2011 | 02:50 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
great transformation, nice car
Old Aug 11, 2011 | 03:47 PM
Twin_Turbo's Avatar
Where did you get that nice carbon filler panel?
Old Aug 11, 2011 | 07:33 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Plasmeh that is truly a great transformation & your car looks great!!!
Unfortunately I am in the "Then" stage of my car....LOL, I hope to be in the "Now" around November of this year. I will be putting in new seats tomorrow. I will take some pics of the current seats. So far I did upgrade the wheels & lowered the car.
Old Aug 11, 2011 | 11:22 PM
polaris91's Avatar
Car: 88 camaro z28
heres mine itll be finished early next week.
belive it or not there is a car under all those parts... the day i bought it still at the po's house
and now
Old Aug 11, 2011 | 11:41 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
this is gonna be fun lol
day i got it, june 6th 2009
Attached Thumbnails Then... and Now! :D-user103514_pic14749_1277430843.jpg   Then... and Now! :D-user103514_pic14755_1277432542.jpg   Then... and Now! :D-user103514_pic14754_1277432275.jpg
Old Aug 11, 2011 | 11:46 PM
Engine: L31 350
and as of today, august 12th, 2011.
only different in interior is that i had a new headliner put in, steering wheel from a 90 RS, new seatbelt buttons, and new outter guides( can see in first pic)
Attached Thumbnails Then... and Now! :D-user103514_pic21570_1298859912.jpg   Then... and Now! :D-user103514_pic23992_1307113304.jpg
Old Aug 12, 2011 | 06:23 AM
plasmeh's Avatar
Car: 1986 IROC-Z
I'm not sure why this was moved to the 'Members Camaro' section - it's for everybody.
Regardless, the panel you see in the hood latch area is stainless steel that was hand made to fit that area using the stock black piece as a template. There is about 15 hours of work altogether in that piece alone. The majority of the time came from placing each circular sand mark exactly .015" apart from eachother. Thanks for the compliments guys! I have loved every minute of taking this car from what it was to what it is. I just got married, and my wife loves the car as well. This one is staying with me no matter what. She can stay, too.
polaris, thats a hilarious picture of when you go the car with everything piled on it lol
Old Aug 12, 2011 | 06:49 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
then:
now:
then specs:
blown up completely stock 3.1/700r4. 3.23's in a 10 bolt.
now specs:
carbed 370ci lsx, PRC stage 2.5 ls6 heads, 11.5:1 scr diamond pistons, eagle h-beams. th400, Transmission Specialties 9" 4500 stall converter, moser 9" 4.11's and a full spool
the car has been 10.76 @ 126 on a 1.51 60' early this spring. i anticipte 10.6x's this fall.
Old Aug 12, 2011 | 07:07 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Yeah, I'd say that's a pretty radical conversion, haha. So sick, great job man =)
Old Aug 12, 2011 | 06:22 PM
one92rs's Avatar
Car: SOLD!!!!!
then
now
Old Aug 13, 2011 | 12:36 PM
FueledSoul's Avatar
Not going to bother posting before and after quotations pretty self explanatory
Old Aug 13, 2011 | 12:37 PM
FueledSoul's Avatar
This is the best i have for after pics still not done at all with the bottom side
Old Aug 15, 2011 | 07:23 AM
plasmeh's Avatar
Car: 1986 IROC-Z
So sick... wish I had the money/time to make mine better than new. Stop making everyone jealous lol
Old Aug 15, 2011 | 11:36 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I already have a thread chronicling my restoration (so I'm just gonna link it, lol), with then and now pics, mind you it is still very much a work in progress, though she has certainly come a ways since I bought her.
https://www.thirdgen.org/forums/memb...-4-camaro.html
I don't have pics of everything up yet though, cause I need to get them off my mother's SD card(had use her card since mine got lost).
Old Aug 16, 2011 | 09:27 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Then:
Now:
Old Aug 18, 2011 | 10:14 AM
marokid's Avatar
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
THEN:
first car...86 z28 305 carburated all stock and original down to the window sticker
and now 350 crate...700r4 shift kit...hooker exhaust ss hood...wheels
Old Aug 24, 2011 | 08:44 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Some great conversions here guys - a lot of you have beautiful rides
Old Aug 24, 2011 | 03:08 PM
Project-RS's Avatar
heres mine. started off as a 305 tbi with a 700r4
and now with a 355 tunnel ram
still have a long way to go. way to many mods to list in 1 post.
Old Oct 18, 2011 | 02:08 PM
plasmeh's Avatar
Car: 1986 IROC-Z
UPDATES PEOPLE UPDATES!
Old Oct 18, 2011 | 02:41 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
car before then car after then motor before and then motor after.
before 1986 Iroc 305 TPI 700r4
After 1986 Iroc 468 Big Block with t5
Attached Thumbnails Then... and Now! :D-1986-iroc-z-23   Then... and Now! :D-1986-iroc-z-770
Old Oct 18, 2011 | 02:45 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
motor pics before and after and recent hood stripes forgot to add it had red camaine interior it now had charcoal plastics with gray seats have a quote to have interior redone in all black for $2500.00
Attached Thumbnails Then... and Now! :D-1986-iroc-z-764   Then... and Now! :D-img_20111010_160159.jpg   Then... and Now! :D-1986-iroc-z-19
Old Oct 18, 2011 | 03:09 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
what???? theres no way in hell a t5 could handle a big block... right?
Old Oct 18, 2011 | 03:30 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
It has so far but i already have a fund for a tremic for when it goes. I'm 40 years old it is more of a tool around car not a full blown drag car so i am not that hard on it yet. but give me time I have jumped on it once In my drive left 2 10 foot black marks then pulled back did it again and the car hooked that time. when i say jumped on it i mean 1/4 pedal and let the clutch out alittle fast not dumped when it was an Auto i drove down the street with it and thought the trans was slipping nope the tires were that was only 1/4 pedal also. it's putting down about 590hp to the wheels. it's 13.5 to 1 compression and a lunati braket master cam with a 850 holley done at lawrenceville speed shop flowed or whatever to 930. it has a lakewood scatter sheild 11 inch zoom clutch and 3.42 gears in the rear
Old Oct 18, 2011 | 03:33 PM
Car: '90 Camaro
Engine: 305 tbi
thats crazy. i would love to have that much power!
i thought the t5 wouldnt be able to handle cause of the torque.
Old Oct 18, 2011 | 03:34 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I am testing the limits of a world class t5
Old Oct 18, 2011 | 04:32 PM
Car: '90 Camaro
Engine: 305 tbi
i bet haha.
once you blow that thing to pieces your gonna have to post it in the holly s*** thread in the racing part of the forum lol
Old Oct 18, 2011 | 06:06 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Originally Posted by BlueZee28
Then:
Now:
I love the clean look, how do you like the wheels? I love those but I do not want to use spacers if at all possible
Old Oct 18, 2011 | 06:12 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Originally Posted by mw66nova
then:
now:
then specs:
now specs:
Wow! What a transformation. Nice job.
Old Oct 18, 2011 | 06:39 PM
one92rs's Avatar
Car: SOLD!!!!!
beautiful car man. that car looks mean and runs as well also.
Old Oct 18, 2011 | 07:38 PM
mw66nova's Avatar
Engine: 7.0L
thanks guys, it's ever changing in my quest for the baddest street driven n/a small tire car on the planet, though i'm far from that title right now, lol!
Old Oct 18, 2011 | 07:54 PM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Badass thread, will have to put some pics of mine. It's incredible to see how far some people's cars have came
realized this was a Camaro thread :P
jacked it and created my own in the Firebird section
Old Oct 20, 2011 | 10:13 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Originally I had it in the general section, but it got moved to the Camaro section for some reason :P I see you got a thread started for firebirds - I love seeing how everyones project progresses through time. Everyone has to be proud of building a car rather than buying it built.
Old Oct 20, 2011 | 11:47 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
then.......
Old Oct 20, 2011 | 11:49 PM
Car: 87 iroc
Engine: 410 sbc
NOW......
Old Oct 20, 2011 | 11:50 PM
Car: 87 iroc
Engine: 410 sbc
then.....
now.......
Old Oct 20, 2011 | 11:53 PM
BlueZee28's Avatar
I like the Z06's, although I had a set of chrome ZR1's before these and I actually kind of miss them. I would like to get a set of 17x9/17x11 for the rear in the chrome ZR1's. That would look real good I think. These wheels are 17x9 all the way around.
I'm using a 4th gen width rear so the only spacers are in the front. I honestly forget they're even there until it's time to do a brake job.
For those that like the "between" pictures, here you go:
Old Oct 21, 2011 | 09:32 AM
UMI Performance's Avatar
This is a cool thread... I love the before and after shots. You guys have some nice looking projects!
Old Oct 28, 2011 | 11:48 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Awesome thread man! Sadly I have mostly NOW photos because I'm a newer owner of my car, But i can tell you There is still a huge difference between when when i got it and now.
Old Oct 29, 2011 | 12:24 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Now
Now
Old Oct 29, 2011 | 03:25 AM
  #42
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Then...
Now...
Old Oct 29, 2011 | 05:19 AM
  #43
plasmeh's Avatar
Car: 1986 IROC-Z
You fixed it so much you turned it into a firebird?!
Old Oct 29, 2011 | 05:32 AM
  #44
Carlos773's Avatar
Yes, it grew wings. Jk, Pretty much all the work I did to that 92 was transfered over to the 86. Everything from the LT1 swap. The body is the only original part left on this 86. I am already in the garage removing the front end for lowering. As you can see the car is a 4x4, the Intrax 2' springs should do the trick.
Old Nov 1, 2011 | 11:25 PM
  #45
puma1552's Avatar
Found some old pics today, this was the very first day I had it back in June, 1999. Took delivery a few hours prior:
Summer 1999:
These had to have been around 2001-2002. I thought I put the BFG Radials on in 1999, but I think it was actually spring, 2000. In the below pic, you can see the 2001 Car Craft Summer Nationals sticker in the windshield, so this put these pics somewhere shortly after that time:
And dear Lord did the car look terrible before it was lowered:
And here is the original Autotrader ad from 1999 when I found the car, I just took this picture today:
Kind of cool to find old 35mm pics. I knew I had them around somewhere.
Old Nov 1, 2011 | 11:28 PM
  #46
puma1552's Avatar
And today:
Old Nov 1, 2011 | 11:29 PM
  #47
-DylanN
UltRoadWarrior9
Jun 6, 2015 06:41 PM
Thomas Stahel
Jan 10, 2014 01:14 PM
JAYDUBB
Jan 21, 2013 08:39 AM
Anak
Oct 14, 2007 08:03 PM
