tpi parts
Old Apr 3, 2007 | 07:51 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
tpi parts
i have a gm tuned port system for sale.what i have are two different baseplates,one for early heads(early model smallblock chevy to 86 and aluminum heads) and the other for late heads(87 to 95 non vortec).i also have a set of slp runners and stock runners.it comes with a bbk twin 58 mm throttlebody and a bbk adjustable fuel pressure regulator.i also have two sets of fuel injectors,a stock set and a set of 32lb accel injectors(new).also a new holley intank fuel pump,never installed.the system comes with a painless wiring harness and a stock ecm.it also comes with distributor.i have well over 2500 invested.i am asking 1500 for all.
i am in meridian ms.
the injectors were only run for ten minutes and the painless wiring harness needs some wiring repaired.nothing major.i have two 1227730 ecm's and an aujp prom.i switched over to a carb setup
Old Apr 9, 2007 | 02:15 PM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
Re: tpi parts
How much are you looking to get for the stock injectors? Are they all within the 14-18 ohms specification and what size are they? Can you send a picture to Gearhead2427@gmail.com.
Old Apr 9, 2007 | 07:34 PM
JTB91RS's Avatar
Car: '91 Camaro RS
Engine: Carbed 350
Re: tpi parts
Would you be willing to sell the AUJP Memcal seperate from the ECM, and how much? If not, how much for both? Shipping to 34711?
Thanks,
John
Old Apr 17, 2007 | 03:33 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Re: tpi parts
If you'll separate, I like to know what kind of deal you can make me on the SLP runners, an ECM and the MemCAL.
Old Apr 17, 2007 | 08:16 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Re: tpi parts
i am also very interested in the slp runners [ providing that they are for 89-92]
Speed
Old Apr 18, 2007 | 09:36 AM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: tpi parts
INTRESTED IN THE PAINLESS HARNESS.. YOU SAID IT NEEDS TO BE REPAIRED, WHAT IS WRONG WITH IT? HOW MUCH??
Old Apr 18, 2007 | 08:36 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
sorry guys,i haven't been online in a while...........we will start with the painless wiring harness,when i removed the harness i found some wires were cut for some of the injectors.nothing major to repair .i paid 350 for it i'll take 200 plus shipping.it is for the speed density system.
the runners are for the 89 to 92.i they list for 345 from slp,i painted my intake and runners black.i will take 200 for the runners and bolts.i even have the installation tool also. i'll have to figure out shipping
i would prefer not to seperate the ecm amd memcal.....100 for both.
ecm is 1227730 speed density from a 91 firebird.
the injectors are actaully for a 92 corvette lt1. i bought them from the chevy dealership here. 100 for them....
Old Apr 18, 2007 | 10:39 PM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
Re: tpi parts
Would you be willing to sell the AFPR separate? If so, how much shipped to 58075? Thanks!
-Tyler
Old Apr 19, 2007 | 05:28 AM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: tpi parts
pm sent
Old Apr 19, 2007 | 06:30 AM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
i would rather keep the regulator on the fuel rail,but i can seperate it.it doesn't come with the diaphram or gaskets........
100 for rail and afrp
45 for afpr shipped
Originally Posted by speedmachine
pm sent
pm replyed
Old Apr 19, 2007 | 06:49 AM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
Re: tpi parts
Is the plenum ported or anything? howmuch for that and the TB is ist 52 or 58?
-T
Old Apr 19, 2007 | 12:28 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
-T
the throttle body is a 58mm ,the plenum has been ported some......
i will sell both with the tps sensor,iac and intake air sensor for 350.plus shipping
runners are sold,speed i'll get back to ya on the shipping
Old Apr 19, 2007 | 06:20 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: tpi parts
i need the one for the mass air .. sorri
Old Apr 19, 2007 | 06:52 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
it's ok.
Old Apr 21, 2007 | 08:49 AM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
okay i'll go this route:
1.bbk adpr with stock fuel rail:$100 plus shipping
2.bbk 58mm throttle body with fairly new tps and iac89 to 92 fbody:$300
3.1 stock base plate for 87 up:$50 plus shipping
4.1 mildly port stock base plate for 86 down:$50 plus shipping
5.2 sets of stock runners,one with 9th inj provision the other not: $50 each plus shipping
6.1 painless wiring harness for speed dencity set up'need some wires repaired
if it is a big deal i will repair the wires myself:$250 plus shipping SOLD!!!!
7.complete set 32lb accel injectors nib:$250 shipped
holley intank fuel pump 255lph nib:$150 shipped
8.1 set of stock injectors bought new from dealership for 92 corvette :$100 plus shipping i paid 65 a piece for them.
9.gm performance parts hei small cap distributor:$100 shipped and have coil bracket
10.gm 3 wire heated o2 sensor with adapter harness:$50 plus shipping SOLD!!!!
11.slp cold air kit with iat sensor installed for 92 camaro :$200 plus shipping
12.2 stock ecms 1227730 part numbers and 1 aujp prom:$100 plus shipping AUJP CHIP AND 1 ECM SOLD!!!!!!
13.2 stock plenums for 85 to 89,one is mildly ported for bbk throttlebody:$50 each
all items are obo
Old Apr 21, 2007 | 11:33 AM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
i accept paypal and i may be willing to split shipping on some items
Old Apr 22, 2007 | 12:23 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
still have parts ....
only thing gone are the slp runners
Old Apr 23, 2007 | 08:27 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Re: tpi parts
interested in the wiring harness sent pm
Old Apr 23, 2007 | 10:04 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
pm replied
Old Apr 28, 2007 | 08:27 AM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
bump
Old Apr 29, 2007 | 05:44 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: tpi parts
is the harness still for sale??
Old Apr 29, 2007 | 07:06 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
yes......actually i still have everything but the slp runners
Old Apr 29, 2007 | 10:16 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: tpi parts
hey, will you do 250 for the harness and one of the ecu shipped, and ill fix the wires?? thanks
Old Apr 30, 2007 | 12:33 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
yes...
Old Apr 30, 2007 | 12:43 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: tpi parts
pm replied
Old May 3, 2007 | 12:20 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
wiring harness is sold.
Old May 3, 2007 | 07:43 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
PARTS LIST HAS BEEN UPDATED
Old May 4, 2007 | 07:44 AM
VTBANDIT's Avatar
Re: tpi parts
wrong thread sorry
Old May 4, 2007 | 04:18 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
still have the bbk throttle body and all intake stuff.comeon guys.this stuff needs to go.
and thanks to camarojokester and speedmachine.
ya'll should be getting your parts anyday now.
Old May 7, 2007 | 10:32 AM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Re: tpi parts
Still have the SLP cold air kit? I'm interested. If so, please send me a PM.
Old May 10, 2007 | 03:21 PM
joephis2002's Avatar
Re: tpi parts
If you could PM me on a price shipped for the throttle body, injectors, and pump...just bought a supercharger kit and will need these for the install...trying to find best deal..thanks...zip 14561
Old May 10, 2007 | 06:08 PM
Bad Karma's Avatar
Re: tpi parts
Which set of stock runners are in better condition? Thanks!
Old May 10, 2007 | 06:27 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
i really need to check,but i believe the 89 up runners are the better ones.
Old May 10, 2007 | 06:33 PM
Bad Karma's Avatar
Re: tpi parts
Pretty good shape? I have several sets with large dings and dents, so I'm looking for some cosmetically nice runners...
Old May 10, 2007 | 06:40 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
ouch..........let me look this weekend ,they are at my parents house in the shed,i'll let ya know as soon as i find out.and i'll get ya some pics of them also
Old May 10, 2007 | 06:43 PM
Bad Karma's Avatar
Re: tpi parts
Cool deal. I'll be away from the computer this weekend, so I'll check back on Monday. Thanks again!
Old May 10, 2007 | 07:36 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
i went ahead and picked the runners up from my parents.i guess when i stored them the woukd be safe.i have one runner that looks mlike someone beat the heck out of it,one with a small ding or two and the other two have minor scratches maybe a really small ping.they would need some serious cleaning.i posted the prices thinking they were in ecellent shape.just to get rid of them i'll take 50 for both sets.
Old May 10, 2007 | 07:57 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: tpi parts
runners recieved.
Old May 10, 2007 | 08:06 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
runners recieved.
when did you get them?i was kinda worried it's been almost 3 weeks since i shipped them
Old May 10, 2007 | 09:00 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: tpi parts
got the harness today.. thanks for everything.. great seller.. thanks
Old May 10, 2007 | 09:25 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
no problem.
Old May 11, 2007 | 05:14 AM
Car: 1989 IROC-Z
Engine: 346 LS6
Re: tpi parts
i got them yesterday. thanks
Old May 11, 2007 | 09:58 AM
Bad Karma's Avatar
Re: tpi parts
They sound better than mine, got any pics?
Old May 11, 2007 | 05:17 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
let me clean them up this weekend and take some pics.
Old May 11, 2007 | 05:47 PM
Bad Karma's Avatar
Re: tpi parts
Sounds good, thanks.
Old May 12, 2007 | 10:38 PM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
Re: tpi parts
do you still have the stock LT1 injectors??
how many miles on them??
Old May 13, 2007 | 10:49 AM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
yes i still have them,probably about 7000 miles on them in over 6 years total.i didn't drive the car a whole lot,mostly weekend driver and track test and tune.
Old May 13, 2007 | 04:53 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: tpi parts
Whats up from V-Burg MS.Interested in the mildly ported plenum and maybe the throttle body.My wifes from meridian and we`re over there atleast once a month.Gimmie a good price on both and I`ll pick them up.Pics if you can to shadygab@yahoo.com.
Old May 13, 2007 | 05:17 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
Re: tpi parts
cool a fellow mississippian
Old May 13, 2007 | 05:54 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: tpi parts
not many of us on here.I`ve been meaning to get to the track over there.Maybe we`ll meet up over there when I do.Do they t&t on sundays?I work most saturdys.I`m sure I`ll atleast get the plenum but I really need the tb,money is just a little tight.It may take me a couple of weeks to get up enough for both,so if you get a buyer till I do thats cool.
