Lots of unique items forsale SPRING CLEAN UP! supercharger, tpi intakes, New items
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Finally cleaning out the guarge, shed and house and figure before I go to ebay ill see what sells on here and give you guys first dibs. If you are interested in any of these items you can contact me at coreyace@ptd.net I have pictures of everything so feel free to ask for pictures of perticular items. I am located between harrisburg in PA for anybody who would be interested in local pick up as well.
PAYMENT METHODS - Paypal,Cash,Check,Western Union basically pretty flexible
Paypal account = Dest099@ptd.net
*Items in list are from 1987 Iroc-z unless otherwise noted*
Complete TPI Intake includesSOLD
-RunnersSOLD
-Top and lower plenum (Lower plenum has been ported and polished)SOLD
-Fuel rails with some new o-rings SOLD
-Stock fuel injectors believe their 22lbs SOLD
-TPI Throttle Body SOLD
-Thermostat housing and stock thermostatSOLD
Complete Serpentine/VBelt Pulleys and brackets includes $75
-Ac compressor pulley
-alternator pulley
-power steering pulley
-water pump pulley
-2 crank pulleys one serp other serp and V-belt
Stock Ring and pinnon gears (7.5 rear 3.23 ratio) $45
Brand new Pistons and rings for a 355 (speed pro 10.2:1 comp ratio with 64cc heads) $90
Stock Distributer with cap/rotor and extra module SOLD
Brand new Edlebrock double roller timing chain P/N 7800 $35
Brand new stock timing chain $20
T-Tops in perfect condition included right and left $50
Oil pan $25
brake resevior and boost $45
Xlerator High performance muffler single in dual out $35
6 15" standard camaro Rims with no tires installed $45 each
stock LB9 Heads with valve assembly still installed $50 for set
T-5 Tranmission with approx 90k miles on it (Borg Warner #s on tranny are 61DKBU014440 and at top has DKB) $175
stock coil and fuel pump $25 for set
Brand new stock cam (never been used) $35
Fel-Pro complete intake gasket set (All gaskets for stock TPI unit) $25
Fel-Pro head gaskets (P/N 7733 PT-2) $20
2 sets of Fel-Pro Rubber valve cover gaskets $15
Brand new holley adjustable FPR for the stock TPI intake $80 thats $20 off
Holley EGR Block off plate for stock TPI intake $15
VORTECH SUPERCHARGER KIT for small block or big blocks includes
- Supercharge V-1 with bracket for a small block currently installed and 5 rib serp pulley
-Inline Fuel pump for the extra fuel you will need
-Boost Retard switch
-Fuel managment unit / kit and lines
-Oil lines for supercharger supply
-Ignition boost control with wiring
-Air duct working and brackets needed for install
**Selling for $1000 sells on ebay for 1500-1950 serial code is D-213-16 and as stated above its a V-1 complete kit
-RunnersSOLD
-alternator pulley
-water pump pulley
Oil pan $25
Last edited by Destructive099; May 7, 2007 at 07:56 AM. Reason: Adding basic overview pictures
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: Lots of unique items forsale SPRING CLEAN UP! supercharger, tpi intakes, New item
Pm sent about the lower intake and runners.
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
how much for that t-5? and where are you located?
Engine: 5.7 350
Axle/Gears: 3:42
T-5 I was going to sell for $175 and im located near harrisburg in PA
Car: 1984 S-15
would you take 100? thats the best i can do right now and i need the truck back on the road...i'll come and pick it up.
Engine: 5.7 350
Axle/Gears: 3:42
sorry its actually a spare for the iroc but i figured if I could get 175 id let her go
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
pm me price for superchsrger...
Engine: 5.7 350
Axle/Gears: 3:42
im looking to get $1000 for the Whole supercharger kit and have had tons of pms about it so im basically saying first one to send money gets it
Car: 88 IrocZ Vert
Engine: 5.0 TPI
I'm looking at your distributor & module to 80233 $$$???
Car: 1984 S-15
alright well let me know if you can do 100, i really need this trans.
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
yo would you just sell the bellhousing to the t5?
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
how much for the runners,intake, plenum and throttle body. shipped to 60423
Engine: 5.7 350
Axle/Gears: 3:42
No, was wanting to sell unit as a whole and for no less than $175
$40
Last edited by Destructive099; Apr 30, 2007 at 07:44 AM. Reason: Automerged Doublepost
Car: 1986 Z28
Engine: lg-4 305 carb.
Axle/Gears: 4th gen. 3.42 posi
does the t5 come with everything needed for a swap? petal, shifter etc.?
Engine: 5.7 350
Axle/Gears: 3:42
just the transmission itself with the bellhousing connected
Engine: 5.7 350
Axle/Gears: 3:42
Anything else anybody wants before items go on ebay ?
Car: 89 Trans Am GTA, 01 Ram, 01 Harley
Transmission: Worldclass T-5
Is the supercharger for TPI or carb application?
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
would like to buy the entire tpi set up. need a complete. wire harness, injectors, everything. do you have what i am looking for, cause i have money waiting in paypal......thanks
westicle1
westicle1
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
do u know how much it would cost to ship the tranny to 33076?
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
How about the Power Steering brackets?
Engine: 5.7 350
Axle/Gears: 3:42
Supercharger I believe has a carb bracket on it atm however one can be bought for tpi quite cheap and all you would need is some basic air ducts with clamps charger also boosts around 6-8 with the pulley installed.
If its a residential address your looking at quite a bit around $300 if you got a business address it can be shipped too its Drastically cheaper
Power steering brackets are yours for $40 or ill sell you all the brackets including the extra crank pulley for $75
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
hey i really want the runners and base and plenum. email me at jcsereiko@comcast.net i need to know if these are the ones with the 9th injector hole and shipping cost to 60423. I have been having problems with your replys going through because of my computer was set on a high security setting. are these a matching set with them being ported or can the fit fine with a stock base?
Engine: 5.7 350
Axle/Gears: 3:42
I am actually waiting on payment for the full intake if I dont get it in a day or 2 im going to inform everybody its still for sale
How much for the Complete Serpentine/VBelt Pulleys and brackets, the felpro intake gasket set and the Brand new holley adjustable FPR for the stock TPI intake?
Axle/Gears: 3:08
price on edelbrock timing set,fuel pump,
Engine: 5.7 350
Axle/Gears: 3:42
$40 (double roller timing set), $35 (Fuel Pump)
$25 (complete gasket set), $85 (Holley FPR), $75 (Complete serpentine/vbelt pulleys and brackets)
Axle/Gears: 3:08
you wouldn't happen to have a fuel sending unit would ya?
Engine: 5.7 350
Axle/Gears: 3:42
Engine: 5.7 350
Axle/Gears: 3:42
Ive updated all items that are left with prices set pretty low so I can sell everything fast
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
I will take the EGR block off plate, Holley FPR, and oil pan. Please send a total cost with shipping for area code 41005.
Thanks!
Thanks!
Engine: 5.7 350
Axle/Gears: 3:42
Total shipped to your door is $135 and as always once payment is received items will be shipped out right away and tracking information will be sent to you.
Does the supercharger have everything you need to install it? What would you need to buy?
Engine: 5.7 350
Axle/Gears: 3:42
Engine: 5.7 350
Axle/Gears: 3:42
Still want the parts ?
Is the oil pan stock or aftermarket? Can you send pics? How do you want to be paid?
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
is the blower still available?
Engine: 5.7 350
Axle/Gears: 3:42
Blower is still available
Car: 88 IROC
You have a new PM
-PJ
-PJ
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Be careful of seller. Sold me a worthtless Distributor now wont return any E-mails. I have Pics if your interested....
Engine: 5.7 350
Axle/Gears: 3:42
Still got some left that didnt sell on ebay
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Sanjay
Aug 12, 2015 03:41 PM
