TPI SYSTEM and EXTRAS (Pics)
Old May 23, 2007 | 07:23 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Got a nice TPI setup for sale here that used to be on a 1990 IROC 350. Everything you would need for the swap minus the computer and harness. The entire intake has been cleaned, sandblased, primed and painted gloss black. The system ran perfect before my carb swap, no codes. No parting here, I want to sell this as a set. Located in NJ, 08610 Asking $300 for the entire shebang.
http://smg.photobucket.com/albums/v3...s/TPI%20Setup/
What's included:
-TPI plenum with siamesed runner openings and front EGR walls ground away
-Stock 48mm throttle body, painted. Throttle blades move smoothly, no stick.
-Stock runners with the flange siamesed (driver side rear runner has a dent in it roughly the size of a nickel)
-Stock unported base
-Stock Distributor
-Distributor cover (still gray, did not paint it with the plenum. Also the bolts are missing from that piece)
-Accel ignition coil
-Throttle, Tranny, and cruise cable bracket that mounts to the plenum. Not pictured but it is included.
-Two K&N high flow filters
-Filter mounting piece, all locking tabs are in place and functional.
-Air Intake...box...fork thing. Again, all locking tabs functional.
-Radiator hose
-Intake coolant neck
-MAP sensor
-Fuel rail and all 8 injectors, painted (FP guage that is attached does not work, it was there when I got it. You can just pop that off the schraeder valve.)
-Alternator if you wish (it's kinda heavy so if you don't want it let me know, could save you a few bucks on shipping), but I'm kinda just throwing that in as I have no use for it. Works nicely though.
-Also, I have a brand new cap and rotor kit for the distributor that was never put on. It is a dark gray duralast model with brass terminals. I'll toss that in too.
-All the nuts and bolts you will need. I sort of took them off of the motor in haste, and put them in a gatorade bottle, but I will go through them and try and sort them all out for you so your swap goes easy. There is one bolt from the runners that is missing, but it would be in your best interest to get a new set of bolts that are hex heads instead of torx heads anyhow, since they are a PITA sometimes.
I think that should be it, PM me if you have any more questions.
Old May 24, 2007 | 07:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: TPI SYSTEM and EXTRAS (Pics)
any idea how much shipping would be to a business in 72116?
90 does not have a CSI correct?
Old May 24, 2007 | 03:17 PM
PM Sent, no CSI on the 1990's
Old Jun 1, 2007 | 04:54 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
where are u in nj? im in pa, but my family is in 08360 email me rongsays@aol.com please
Old Jun 1, 2007 | 05:00 PM
flyboy367's Avatar
Car: 02 redfire gtp coupe
Engine: 3.8 modded and supercharged
Transmission: 4t65-ehd
im interested, im in sayreville nj. if it came from your car how come no harness or computer?
Old Jun 1, 2007 | 05:13 PM
Sorry guys, sold.
But the reason the computer and harness are still in is that I use the computer to keep the Speedo working, and I havent weeded out the parts of the harness I no longer need yet.
Old Jun 16, 2007 | 10:12 PM
95blue350's Avatar
Car: 95 C1500 Ext. cab
Engine: 355 TPI running on the TBI ecm
Axle/Gears: 3.73 GM 10-bolt
would you part out the injectors?
Found some Thank You!!!
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
Street Lethal
Aug 13, 2015 08:28 PM
Sanjay
Aug 12, 2015 03:41 PM
