Cleaning out the garage. Alot of stuff inside!!!
Car: 70camaro rs/ss, 83 camaro
Engine: 70 has 454, 83 has 327
Transmission: both have 700r4
Axle/Gears: 70 has 3.73, 83 has 3.27
Ok guys time to clean out the garage and get ready to move (hopefully). Here is a list of things that I have left over, or am unable to use or keep.
I have listed prices for all items and I have pixs to go with each item. I can get more pixs if you would like either pm me here or email me at
ninigone70@comcast.net I am willing to ship everything at buyers exspense. I can do paypal for payment, money order, or cash on pick or
deliver. Deliver is avaliable for a small fee. I am located in Waukegan, Ill which is about 40mins north of chicago. Right off of I-94 and Rt.120.
1. Q-jet carb from 86 k-5 blazer with elec. choke, elec. fuel metering, and elec. indle control. $10.00
2. Weiand single plane intake. Needs to be cleaned. No stripped bolt holes or oblonged holes. $50.00
3. Edelbrock Torker II intake. Needs to be cleaned. No stripped holes or oblonged holes. $50.00
4. Tpi Exhaust manifold with air holes, they are plugged with brass bolts for easy removal. Has O2 hole and O2 in one of the manioflds. $20.00
5. LT1 exhaust manifolds. $10.00
6. 2 sets of truck manifolds for sbc. 1 set with O2 holes with old studs. $10.00 1 set without O2 holes new studs. $15.00
7. 1-ton big block truck exhaust manifolds $10.00
8. 70-81 f-body sbc headers black bottom of driverside is dented. Have rust from sitting. $25.00
9. (7) trw forged pistons for 350. 030 over bore only have 6 wrist pins Part number L2304.030 $10.00
10. 70-81 camaro bumpers. 1 front for z-28 $40.00 2 rears 1 standard and 1 z-28 $40.00 each.
11. 70-81 camaro hood. clean and straight. $35.00
12. 70-81 camaro steering column non-tilt with key and shaft to gear box. $40.00
13. 70-81 camaro front sway bar from a SS car. $20.00
14. 70-81 camaro headliner front and rear inside trim (black) need to be cleaned and the old headliner excess removed. $20.00 for 2 pieces
14. 70-81 camaro side mirrors. Need to be clean. Glass is good and driver side is remote control. $10.00
15. 78 camaro upper grill. Clean no cracks or missing pieces. $45.00
16. 95/96 caprice/impala rear disk brakes. Backing plate's, calipers, rotors and rubber lines. $100.00
17. SBC oil pan braces for bolt holes both sides. $5.00
18. Accel super coil $15.00
19. (2) sets of stock center bolt valve covers $5.00 a set
20. 2002-2007 Trail blazer side mirrrors with clear turn signal lenses. $150.00 for set brand new in the box oem's.
21. 1997-2003 Ford F-150 trailer hitch factory class 3 with wiring mounted to it. And mounting bolts and plates. $30.00
22. 2002 Ford F-150 spare tire hoist for under the truck. Still works needs a little oil on cable. May fit other year ford trucks?? $10.00
24. 82 camaro wiper motor not sure it has delay on it or not. $5.00
25. 82-92 f-body t-tops non locking $20.00 for the pair.
27. (2) Goodyear Eagle GS-C 255-45-ZR17 $50.00 pr.
28. (2) Pirelli PZero Asimmetrico 225-45zr17 91y $50.00 pr.
29. (2) BFG comp t/a drag force radials 235-60-R15 $25.00 set
30.(4) sets of sbc cast iron heads 1 set is 78-79 350 bare #3998993 75cc $30.00 set.
1 set of 74-80 350-400 #333882 76cc Bare heads. $30.00
1 set of 69-76 327-350 #3927185 70cc $50.00
1 set of 75-86 350-400 Target performane complete with 1.94-1.05 valves, springs, retainers, and locks. Ready to go. $100.00
31. 1966 Chevelle Headlight backing plates. $ 25.00
32. 1966 Chevelle Headlight buckets and trim rings. $25.00 for set
33. 1966 Chevelle Rear inner/outer tail light trim 1 set of outer. $45.00 (2 and 1/2) inner trim $ a set. 20.00 set
34. 1966 Chevelle front fender "230 cid" emblems 1 set with all mounting tabs still there. $5.00 set
35. 1966 Chevelle rear "Malibu" script 1 set with good mounting tabs $15.00
36. 1966 Chevelle headlight side wings 1 set $15.00 pr.
37. 1966 Chevelle headlight cover just 1 side. $20.00
38. Several low lift crank jaceks from ???? $5.00 each.
39. Flex-lite fan 13" with spacer and 3 bolts missing 4th $5.00
40. 1986 K-5 blazer/pickup/van/suburban front grill turnsignal lights $5.00 set may fit other years????
41. 4wd drive shifter from 1986 K-5 blazer/pickup/suburban for np-208 transfer case. $5.00
42. Several chevy starters some need rebuild some missing selnoids. $5.00 a piece
43. B&M shifter for auto trans. Sticks needs to be cleaned. $10.00
44. 1965-66 Mustang headlight bezels $20.00 pr.
45. 1991 Honda crx si front and rear sway bars. Front still on car, but can be off in a few minutes. $30.00 set
46. Stock clutch style fan from sbc truck/ car $10.00
47. 1988 Honda crx si wheels with decent tires. Rims need to be rebone has paint is flaking off bad. $65.00 set of 4
48. DC sport header for B-series. Use very short time no dent to it at all. It looks to be stainless steel. 4-1 design. $100.00
49. Complete rear cargo trim, side panels, crago cover, and center compartment from 1991 crx si $75.00 for all
50. Front pads and rotors for 1991 crx si both have less than 2000 mile on them. Little surface rust from sitting $15.00 for both
51. (2) electric fans one is from an eclipse and one is from a honda both work great. $10.00 each.
52. 88 crx si d16a6 w/ 100k new t-belt, water pump, head gasket, and complete with intake, exhaust, and dist. $50.00
53. 93 sohc trans. shifted fine when pulled. not grinds or anything. has start still attached no clutch. $25.00
54. Engine harness from 88 crx si I think one broken connection. $25.00
55. stock ecu from 88 crx si $5.00
56. Passanger seat from 88 crx si clean no rips. $10.00
57. 1st gen Eclipse front seat no rip or tears need to be cleaned really good. 2-tone gray. $40.00 for set
58. 2000-2002 cavalier stock front fenders. $50.00 Indigo blue in color
59. 2000-2002 cavalier stock front bumper $40.00 Indigo blue in color
60. 2000-2002 cavalier stock hood $50.00 Indigo Blue in color
61. 2000-2002 cavalier fiberglass Z-3 fenders in gel-coated color. Never mounted on a car. $25.00
62. 1995-up J-body stock springs or Drop zone drop springs. 1.75" drop $50.00 for either set both have arond 10k miles on them.
63. 1995-up Cavalier rear spoiler. Stock factory with 3rd brake light installed. $30.00 Indigo blue in color.
64. 1995-up J-body front strut bar Polished. $20.00
All items have pixs in my photobucket link below.
http://s80.photobucket.com/albums/j1...%20for%20sale/
If you need more pixs of any items just ask. I am open to offers on everything. Any question just ask I'll try and answer as soon as possible. And Thanks for looking. Nick
Re: Cleaning out the garage. Alot of stuff inside!!!
Does the shifter work good? And is it for a TH350/400? I'm interested in this if it works. I'd be interested in the pistons too, but I'm on a very tight budget..
The shifter is sticky and hangs up sometimes when trying to pull it thru the gears. Hinch the needs to be cleaned. And it was hooked up to a 700r4 so it should work on a 350/400 has well. And the pistons thats $10.00 fopr the set of 7 with the 6 wristpins thats all I have for those. Let me know.
Car: Pair of 92 Z28s
26. (2) BFG G-force T/A KDWS 275-40-ZR17 98w $75.00 pr.
How much tread? Gonna need pictures, and shipping to 22152? You dont need to box them up or anything. UPS and Fedex will ship them with just shipping label should be pretty cheap. I have a buisness address also which would help.
-Steve
-Steve
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
10 each or for all? how much for shipping?
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
What condition is the accel super coil in? do u have any pictures?
Pix of the coil can be seen on my photobucket link above. It worked great when pulled 6 months ago. It has seen better days as far as the out side but worked great on my mild 350.
soultron: That is for all of them. Shipping is like $15.00 any where in the us.
Everyone else any thing you want pixs of are in photobucket. Plese look there.
Stevo: I will get a depth on them to you later today. And I will also look into shipping those as well.
Thanks, i see the other pictures on your photobucket. No uneven wearing? The bead isant cut at all right? Any dry rot? Any idea how long they have been sitting?
Thanks.
Thanks.
No uneven wear. And the beads are perfect. Been sitting for about 6 months if that. Maybe less. no dry rot either.
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
i know i dont see anything about wiring harness's or anything but i figured id ask! im looking for the wiring harness from the battery positive side terminal to the coil.. and it has to have the connector on it with a fuseable link i believe.. if you need me to get a pic of wat im talking about i can
thanks
thanks
tourville send me a pix of what you need I have a engine harness and mite be able to get it for you. My email is ninigone70@comcast.net
few offers on stuff and a lot of tire kickers. What a matter noone wants to build there cars anymore. I have till the end of sept. Than most of this stuff will be trashed so make offers.
Car: 1991 Camaro RS
tourville I got you email, but sorry I don't have it on mine either.
Stevo not sure I would have top say about half tread. I don't have a depth gauge anymore.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
do you have the drivers side accy. braket? the one that holds the alt and ps pump?
Car: 92 camaro,99 s10
can i get some more info on them?
Well at 50% im not sure if they are worth the time and effort to mount and balance. You said youd be getting rid of them in a month if they were not sold so ill offer you $75 shipped...youll be making something at least. If not thats fine ill pass then.
there a 76cc combustion chamber
thats all the other info i have on them
stevo if you want them them $75.00 is cool if not I have a guy local that is interested in them has well. Let me know asap.
List updated.
Car: 84 Z/28
Transmission: 700R4 - rebuilt by me
Axle/Gears: 3.73 posi
If they're available still, I'll take them. Just tell me where to send the money and what you want to ship em to st louis.
Dave
Dave
Pm sent o you dyed..
yup still got the shifter. Pix on in the photobucket link above. There is several pixs of it.
This is the listed updated. Thanks and make offers I need this stuff gone now.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
shipping to 83642? how much life is left? any problems with them...any pics? moncarr737@aol.com
also all the 70-81 camaro parts are they in good shape? i wonder how bad shippin would be for them to idaho?
the tires don't have much left on them. I would have to say less than 40%. I don't think they are worth more than a few passes at the track before they are done.
The camaro stuff is in good shape and shipping is going to be quite abite due to the weight of the bumpers and sway bar. I would have top guess at weight and boxes and say problay around $75.00- 90.00 just in shipping. Unless you only want certain things. I can get shipping on those items for you.
Car: 92 1500p\u 2wd
my old man has a 74 camaro that i know is in need of a new headliner.....he also might be interested in some other things sway bar and bumpers...can i get pics of these parts please? moncarr737@aol.com
There are pix in the photobucket link below the bumpers are going to be different for a 74 camaro. The sway bar will work and the headliner trim piece should as well.
Street Lethal
Apr 30, 2019 12:14 PM
92camaroJoe
Aug 13, 2015 06:07 AM
