33lb injectors, lt1 block, stock lt1 cam, etc.
Car: 91 RS
Axle/Gears: 3.42 LSD
All prices are OBO and plus shipping.
94 LT1 Block, spun the main beargins will need a line bore, and maybe new main caps. The cylinder bores are stock 4.000 still, would make a great core for a 355 of 383 build. --- $100 (will have to be shipped frieght expect 100-150 depending)
Set of 33lb injectors, flow tested and matched. SOLD
Stock 94 LT1 cam, ~125k miles, all journals mic'ed good and the lobes all look good. --- $40.00
94 LT1 A/C compressor, $15
NX fuel solenoid, used I can't test it with fuel pressures applied but it does click when voltage is applied. --- $35.00
Stock TBI Fuel pump. --- $20
Stock TPI fuel pump. --- $25
Automatic cooling fan switch. (not in box, but unused) --- $10.00
The fallowing are for a 1 pc. rear main SBC:
Freeze plug set --- $5.00
STD. Main Bearing --- $5.00
Cam Bearing --- $5.00
2.73 gears and open 7.5" diff --- Free
Car: 91 RS
Re: 33lb injectors, lt1 block, stock lt1 cam, etc.
They are made by Bosch, they are the stock injectors from L67 engines. (GTP's)
Yes I take paypal. Mdenz3@hotmail.com
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I will take the Lt1 cam. Got any pics and what is shipping to K7R3L1 Ontario, Canada?
