Parts Blow out (everything has to go)
Old Nov 21, 2007 | 08:30 PM
Blackjak's Avatar
like the title says everything has to go . all prices are obo and shipping is not included. any question just ask or pm me .
Parts include:
slp headers and y-pipe -150
k&n round filter -25
msd 8mm wires -35
Edelbrock preformer intake -100
Edelbrock 750 carb with carb kit -150
Edelborck water pump with fan -75
chevrolet valve covers -50
Msd 6a -70
perma-cool trans cooler -30
holley fuel pump -50
Msd distributor-100
350 2 bolt main block and rotating assembly -300
700r4 with a 2200 stall ( unknown stall brand) -350
350 heads - 150
Msd blaster2 -40
here is some pics:
o yea and im located in cincinnati
Old Nov 21, 2007 | 08:43 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Parts Blow out (everything has to go)
what size headers? If 1 3/4 consider them sold
Jay
Old Nov 21, 2007 | 09:45 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Are the heads aluminum? If so, I'm interested. What are specs?
Old Nov 21, 2007 | 09:56 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Pm sent
Old Nov 21, 2007 | 10:55 PM
Blackjak's Avatar
yes i believe so , they are coming off a 87 gta and they are stock specs , i could find out if you want
Old Nov 21, 2007 | 11:05 PM
Blackjak's Avatar
Jay
i believe so but i will check
Old Nov 22, 2007 | 12:07 AM
Stevo's Avatar
Car: Pair of 92 Z28s
No third gen came with alum heads, + the fact i see surface rust on parts they are most def cast iron.
Old Nov 22, 2007 | 12:37 AM
Blackjak's Avatar
then i guess they arent i thought they were for some reason
Old Nov 22, 2007 | 05:54 AM
miller7c's Avatar
Car: 87 trans am/ 87 formula
Engine: lb9/ l98
Transmission: 700r4/700r4
if the headers are still avalible i would like them
Old Nov 22, 2007 | 07:46 AM
joeEZ's Avatar
Have you any pictures of how the plug wires routed on your car? I cannot seem to find a set that is not cut to fit, that will route nicely over the valve covers and not be stretched tight.
Old Nov 23, 2007 | 06:33 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Axle/Gears: 10 bolt,3:73's
PM sent about tranny cooler
Old Nov 24, 2007 | 12:54 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
whats the status on the MSD?
better pics and is there all the wires, how long are they and is it known to be working? THX
Old Nov 25, 2007 | 07:18 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
Info on the 350. casting #'s & dates, is it bored, location, etc. thanx
Old Nov 30, 2007 | 02:23 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
if nobody wants the headers, I will take them . I do not want to step on any toes. whoever was first should get them, if they do not want them, i will gladly be the next in line. jcsereiko@comcast.net
Old Nov 30, 2007 | 09:54 PM
Blackjak's Avatar
headers are sold , sorry everyone
Old Nov 30, 2007 | 11:49 PM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
Is an MSD 6a the same as a 6al? Does it have the rev limiter chip? Also, do you have a wiring diagram because i don't know how to set it up....
Old Dec 1, 2007 | 07:07 PM
westicle1's Avatar
how old is fuel pump and water pump....how much shipped to 66062
wantinto check some prices shipped
Old Dec 1, 2007 | 08:23 PM
kscamaro89's Avatar
Car: 2002 MINI Cooper S
Engine: 1.6L Inline 4 Supercharged
Transmission: 6 SPD
Re: how old is fuel pump and water pump....how much shipped to 66062
6A does not have a limiter. thats the only difference between the 6A and 6AL. Still a decent price if it works though.
Wish I had a V8 so I could pick up some parts here.
Old Dec 1, 2007 | 11:40 PM
Blackjak's Avatar
it doesnt have limiter to my knowledge and i think the 6AL is a newer version of the 6A
Old Dec 3, 2007 | 09:52 AM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
FYI, you can get a Blaster 2 coil for 35 bucks brand new from Summit.
Old Dec 3, 2007 | 11:58 AM
Blt_4_Spd's Avatar
Is distributor still available and what's the part #? Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
