WTB TPI air intake setup for 91 firebird
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Swapping in a 350 TPI out of a IROC and it doesn't look like the air filter setup will fit. So...
Car: 91 Bird
Engine: TPI 350
Re: WTB TPI air intake setup for 91 firebird
What comes with that? If it's complete I'll take it - it's sold. I need from the MAF sensor out. Maybe not the flex rubber on the MAF if it will fit the firebird stuff.
How do you want payment. I'll send a PM with the shipping info.
Car: 91 Bird
Engine: TPI 350
I wasn't clear on what I am doing - the engine is a TPI 350 from a 1989 IROC. Going into a 1991 Firebird. It is not a Formula or Trans am.
Using the 5-speed from the 305 TBI. Using the 3.23 posi rear w/disc brakes. WOuld like to use the 700r4 but too much stuff to change out right now.
Car: 91 Bird
Engine: TPI 350
Sounds like like what I want. How much do you want for it?
I have the whole thing. The hose that mounts to the throttle body, the tube that mounts to the can, the filter can and a k&n filter. I'll take 50 shipped. Let me know.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
What year is the IROC? Camaro air ducting is different then Firebird due to battery location. You will need to use Firebird ducting or relocate your battery. Engine wiring harnesses are different also again due to battery location.
1992 Trans Am
05-10-2023 07:19 PM
