Garage Sale...Awesome parts list..Don't miss out!
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Hey everyone, Just came from the garage with my digital camera . I have several projects that never got underway, here is a list of what I have for sale so far(i have tons of more stuff by the way)...
28 Spline Auburn Posi w/3.73 gears.....used $225
Shorty Headers w/ collectors....used $75
1 Pc Rear main Oil pans...used $20..Your choice of colors
TDS Wonderbar/Steering Brace........used $35
1.52 Rollertip rockers, self aligining type...new in the box .$50
Cat 383 Stroker crank for 2 pc rear main seal....new in the box .$135
Rear Hatch Struts..Used but guaranteed...$20
700R4 metal Torque convertor cover....$20
AC Delete Heater box w/blower.......$100
Competition Cams XE268H-10 w/Lifters new in box...$145...specs on request
PAYPAL gets first priority, I will take Postal money Orders......first come(pay) first serve...I will not hold parts for anyone. Shipping is not included in price. I will post pics of all these items over time and give better item description or as requested.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Re: Garage Sale...Awesome parts list..Don't miss out!
Low miles Auburn Posi out of 94 Z28 Disc rear....ABS ring removed. This unit is very clean and complete with GM factory 3.73 ring and pinion with little or no wear. 11-41 count on the gears. Has 28 spline and will fit any drum or disc rear 89-92 with 28 spline axles. For you Guys/Gals with earlier rears(26 spline...82-87) that want to upgrade I can get 28 Spline axles for you to go with this for a few extra bucks. All will be a direct bolt in replacement.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
These Shorty Headers are in used condition. Flowtech I believe, has an O2 bung if desired. Comes with Collectors, gaskets and hardware. The Header pictured on the left had a pinhole in it due to the machineshop beadblasting it. I had a small patch brazed(welded) over it.....
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Two used Oil pans . Fit One piece rear main seal L98/LB9 type motors 86 and later. These were blasted clean and painted with High temp paint . Your choice. Will fit Camaro/Firebird chasis. Comes with the Pan Rails.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
TDS Wondebar or Steering Brace. Same as the ones found on early IROC Z-28 cars........Like new condition.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
1.52 Roller Tip Rockers. New in the box with the rocker self locking nuts and roller ******(washers)......These are for Self Aligning valve types....87 and later L98 /LB9.........Roller motors use self aligining rockers.
These have been SOLD
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Rear hatch struts(2 pair) and a 700R4 torque convertor metal cover. The struts are strong and the cover is new with traces of the sticker still on it.
I have one pair of Hatch struts remaining, other pair is SOLD....Plus the 700R4 TQ cover has been SOLD.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
AC delete box in awesome condition. Comes with working blower motor and partial harness. I also will include all the factory mounting hardware(not pictured)....Box is not rusted inside or out and the factory mounting gasket is unbroken and still attached.
Item has been SOLD.
Item has been SOLD.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
CAT 383 stroker crank...new in the box... fits 2 pc rear main seal blocks(I have a 4 bolt main block if needed)....
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Comp Cams XE268H-10 brand new in the box with new lifters...grind # 12-242-2........specs are dur@.50 224/231 and lift .477/.480........a great dual pattern cam with nice choppy idle to be used with Carb motor, gears 3.23 and up. Makes good street horsepower.
do you still have the rocker if so email me at rogergagnon77@yahoo.com i have paypal
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Anybody responding to items for sale should let me know what State they live in so I can give an accurate shipping quote, prices on some items are negotiable....If you are local I may ship for free , with Insurance optional on your end. PM or respond here or both(I could use the Bump to the Top!)....Happy New Year........Dean
Car: '86 Camaro Iroc-Z, '86 camaro Z28
whatsup. i live in brooklyn. whats the price on the rear setup for an 86, you mentioned a few extra bucks. i can pickup. if nothin else, heres the bump.
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
hi im very interested in that tds wonder bar ,, what type engine setup did it come off of ,,
an whats s&h to 53215
Car: 1972 GMC
Axle/Gears: 4:10
I wil take the Roller rockers I live in Chaska Minnesota 55318, let me know what paypal account info I will send payment right away.
John
John
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
This a a Hydraulic Flat tappet Cam...it can be used in a Roller block with regular lifters and pushrods....However, This is not a Roller cam. Pre 86 blocks or Truck blocks 87-95 and any Roller block with proper components.
Car: 1972 GMC
Axle/Gears: 4:10
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
....This is a Steering brace, fits down atop the swaybar using the same mounting holes/hardware. Engine type not an issue. Should fit 83-92 F body......I believe the 82 was a little different, but not sure. Do your homework, call TDS if you have to. I bought this used and its been sitting around. Shipping is $12.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
interested in the crankshaft.whats shipping to 01610, worcester mass
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Posi still available, I have 3.42 & 3.23 gears available as well if the 3.73 don't fit your needs. Will be adding more parts this week to list.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Thanks for all the PM's guys/gals.....all have been returned.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Here is a link to Garage Sale # 2....check out this stuff !!!!
https://www.thirdgen.org/forums/engi...2-awesome.html
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Auburn Posi & 3.73 gears are SOLD........I do have the other gearsets still available. 3.42, 3.23, 2.73.......
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
do you still have the tranny cover? if so how much shipped to 98195?
~JAKE
~JAKE
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Car: 1989 iroc
Engine: 5.0
Transmission: t-5
interested in the shortys if you still have them how much for shipping to 95037
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
No, 10 bolt........9 bolt gears would be 3.45 ratio
Car: 1990 Firebird
Engine: 600 hp 353.4 CI
Transmission: TH-350/B&M3000
Axle/Gears: 10 bolt 3.23
still have the cam? im interested.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
LT1Formula
20
Nov 14, 2015 12:02 AM
Street Lethal
Aug 12, 2015 11:33 AM
