F.S. LS1 Alum Driveshaft (photos)
Old Jan 14, 2008 | 11:46 AM
SLP_GTA's Avatar
out of a 36k 2000 SS Camaro. New rear u-joint, shaft in very good used shape, not perfect but good.
135.00 shipped in CONUS postal MO only.
Old Jan 14, 2008 | 11:59 AM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Re: F.S. LS1 Alum Driveshaft (photos)
Does this even fit in a stock 3rd gen?
My iroc had its aluminum shaft replaced at some point with a steel one, and id like to put an aluminum one back in.
Old Jan 14, 2008 | 12:10 PM
SLP_GTA's Avatar
fits all later 3rds 87 up with 700R4 or T5
Old Jan 14, 2008 | 01:37 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
why do you say not perfect? is it out of balance?
Old Jan 14, 2008 | 02:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Will fit all years with T-5 or 700R (though the rear U joint may need replacement on pre-88 cars--at least that was the situation on my 85). By the way, LMSkyliner, an 85 IROC wouldn't have been originally equipped with an alum drive shaft. IIRC, the JG1 didn't make an appearance until 1988.
JamesC
Old Jan 14, 2008 | 02:56 PM
ebmiller88's Avatar
It'll slide right in, no problem.
Ed
Old Jan 14, 2008 | 03:21 PM
SLP_GTA's Avatar
its not out of balance, I say not perfect because its a used part and has 36k. Some may expect perfection from a used part so I like to be clear.
If you check on ebay you'll find this is a really good shipped price deal.
Old Jan 14, 2008 | 03:53 PM
JamesC's Avatar
But an 85 may not mate correctly to the pinion yoke unless the rear U is changed (the part # is provided in the following link). I'd test fit first:
https://www.thirdgen.org/forums/tran...light=carquest
JamesC
Old Jan 14, 2008 | 05:11 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
PM sent.
Old Jan 14, 2008 | 05:39 PM
SLP_GTA's Avatar
SPF
Old Jan 24, 2008 | 01:21 PM
watajob's Avatar
Car: 92 T/A 'vert
Thanks for a pleasant transaction!
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
