sbc 400, complete t5 set up and some mis.
Transmission: t-5
i have a sbc 400 block with forged speedpro flat top pistons. standard bore. 2 bolt. less than 10k on motor. stock rods and crank. asking 500
http://i120.photobucket.com/albums/o...l/DSCF3263.jpg
http://i120.photobucket.com/albums/o...l/DSCF3262.jpg
http://i120.photobucket.com/albums/o...l/DSCF3261.jpg
http://i120.photobucket.com/albums/o...l/DSCF3258.jpg
383 stroker. eagle cast steal crank (350 mains, 3.75 stroke) eagle i beam rods (5.7 length) keith black pistons .30 over. was a balinced set up. 2 pistons are broke and it cracked the block. been sitting for a year. asking 350
3157.jpgotobucket.com/albums/o195/coreyfrenzel/DSCF3573.jpg
http://i120.photobucket.com/albums/o...l/DSCF3572.jpg
http://i120.photobucket.com/albums/o...l/DSCF3571.jpg
complete t-5 set up! tranny is out of a 91 camaro z. Its a world class! B&M ripper short throw shifter, bell housing, peddes, hydrolices that are less than a year old, stock auto clutch with less than 1k on it, shifts very nice. asking 700
http://i120.photobucket.com/albums/o...l/DSCF3186.jpg
http://i120.photobucket.com/albums/o...l/DSCF3185.jpg
http://i120.photobucket.com/albums/o...l/DSCF3182.jpg
http://i120.photobucket.com/albums/o...l/DSCF3173.jpg
http://i120.photobucket.com/albums/o...l/DSCF3172.jpg
msd coil for tpi or throttle body! asking 20
http://i120.photobucket.com/albums/o...l/DSCF3154.jpg
http://i120.photobucket.com/albums/o...l/DSCF3155.jpg
cran cams 3/8 stud locks new in box still asking 20
http://i120.photobucket.com/albums/o...l/DSCF3158.jpg
http://i120.photobucket.com/albums/o...l/DSCF3157.jpg
sbc chevolet chrome valve covers asking 20
http://i120.photobucket.com/albums/o...l/DSCF3161.jpg
http://i120.photobucket.com/albums/o...l/DSCF3160.jpg
stock v-8 t-5 bell housing. asking 50
http://i120.photobucket.com/albums/o...l/DSCF3147.jpg
formula rims that have been stripped repainted and hand polished!
asking 400
http://i120.photobucket.com/albums/o...l/DSCF3141.jpg
153 tooth flywheel. asking 40
i have couple of other flywheels so just ask
http://i120.photobucket.com/albums/o...l/DSCF3183.jpg
stock tpi disturbitor asking 30
http://i120.photobucket.com/albums/o...l/DSCF3548.jpg
complete wap from 165 ecm to speed density 730ecm. custom chip, for 30lbs injectors. 2bar map and knock sensor asking 300
http://i120.photobucket.com/albums/o...l/DSCF3540.jpg
http://i120.photobucket.com/albums/o...l/DSCF3539.jpg
http://i120.photobucket.com/albums/o...l/DSCF3538.jpg
749 ecm
asking 50
http://i120.photobucket.com/albums/o...l/DSCF3546.jpg
thanks for looking
asking 400
749 ecm
asking 50
thanks for looking
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
Re: sbc 400, complete t5 set up and some mis.
very interested in the 400 engine. Can you send me contact info to gmodude@aol.com. Send some casting #s if possible. Very interested.
is the 400 with or without oil pan.
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i need a 1pc. rear main seal t5 flywheel?
Breazlan
Sep 25, 2015 11:20 AM
dimented24x7
Sep 6, 2015 03:51 PM
