FS: Fully race ported cast iron heads, $300
Old Jan 31, 2008 | 12:51 PM
KrazedZ's Avatar
Selling a set of fully race ported cast iron heads not just a gasket match here, full runner and bowl work, 64cc chambers, aftermarket valves with under cut stems for more flow, 1.94" intake and 1.50" exhaust. Heads are cleaned and assembled. asking $300
These heads were off of a friends 79 camaro, he upgraded and i was going to use them on a project but have gone a different direction.
His camaro was running a consistant 11.80's at 116mph on motor, stock bottomend with flat top 4 valve relief hyperutectic pistons, single plane intake, 750 carb, compcams flat tappet single pattern 248 dur @ 0.050" cam (off the shelf cam), 1 5/8" long tube headers, 350 trans with a jegs converter, 3.73 gears and southside lift bars in a stock weight car, just listing his setup to see what these heads can do with a very average setup.
Tony
located in NJ 08721
Old Jan 31, 2008 | 02:58 PM
chatmanx's Avatar
Re: FS: Fully race ported cast iron heads, $300
PM sent
Old Feb 12, 2008 | 02:45 AM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
tpi bolt to these heads?
Old Feb 12, 2008 | 12:00 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
wit valves or no? clear up confusion
Old Feb 12, 2008 | 08:40 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
SOLD, i bought them 1st week feb. just to clear up confusion
junkcltr
Aug 2, 2019 11:12 PM
anesthes
42
Oct 24, 2015 07:30 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
