'86 Berlinetta Parts
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
just a couple parts from an '86 berlinetta i parted out. Front grill w/out fog lights ($25 shipped) and a driver side marker/turn signal ($15 shipped). Electronics are limited so you may inquire but i can't promise much. If you have any basic interior parts needed and potentially some exterior feel free to ask. It was a red exterior and dark carmine red interior. Again feel free to ask any questions. Thanks
Jon
Jon
Re: '86 Berlinetta Parts
Thank you! Items above sold (front turn signal and grill) Anything else anyone might need, feel free to PM me and i'll see what i can get you.
don't forget to post pics (before and after) when you get them in, i like seeing my parts going to a happy home
Thanks.
Thanks. Re: '86 Berlinetta Parts
hey man i need a coupla things first the console lid and second the top of the dash and while im tlakin to you, seeing how you have the same car im havin a problem that you might be able to help me with...when i turn the headlights on, all of them come on i have no low beams alone its either all or none so im thinkin its in the switch or somethin. i dont know i just cant seem to figure it out. i know the switches are good. but when i turn the lights on nothin happens till i hit the dimmer switch then they all come on. i hit the dimmer switch again and they go off instead of goin to low beams. idk hopefully you can help me. oh and i need the lid to the truck compartment thing the one side where the bolts fasten broke. ok well thanks for any help you might be able to offer
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Hi TJ,
I got your Private E-Mail and plan to respond to most of your questions there later tonight or tomorrow morning ( depending on how the next hour or so goes ! )
As far as your headlights,...... I can just about guarantee that the Light Module is the problem. When your high beams are ON and you press the button again to turn them off ( and set the LOW beams on ) the button is working fine - the Light Module is simply not passing the signal to just the headlights as it should.
I'll send you a reply Email ASAP with as many answers as possible !
ok im back do you still have the light module? and any or all the relays for the headlight system? if you do how much do you want for it all? and if you want my zip for a shipping quote or something. or you can pm me with your phone number and i can give you a call or something. i just bought the car and all im tryin to do is get it on the road. but im havin a hell of a time gettin there.
oh i forgot my zip its 17042
Last edited by bud4life820; Jun 30, 2008 at 12:42 AM. Reason: Automerged Doublepost
LT1Formula
20
Nov 14, 2015 12:02 AM
