WANTED 1990-1992 TPI plenum
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Plenum must be from a 1990-1992 !!!!!! NO STRIPPED bolt hold and plenum must also have original surface casting as well as NO PORTING work done to it. ................ PM me if you have one.
Engine: 4.0 V-6
Re: WANTED 1990-1992 TPI plenum
I am still looking for this plenum ......... If anyone has one let me know asap and I can paypal you immediately!!!!!!! ................ My friend decided to supercharge this car so a ported plenum will be fine but he still prefers the original rough casting surface on the outside ......... If you have one post a picture of it ....... again must be from a 1990-1992.
Engine: 4.0 V-6
90-92 have a port for the MAP sensor for one, and the drivers side of the plenum doesn't have an EGR port they also have the holes to mount the MAP sensor on the plenum. If you want to know what it is look on the bottom and it has a casting year.
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Well I was hoping there wasn't a difference because I have one for 85-89 for sale. Sorry I couldn't be of more help.
Engine: 4.0 V-6
Another thing is there is a cosmetic difference. the ribs dont come as far towards the throttle body as the earlier years.
Sanjay
Aug 12, 2015 03:41 PM
