Dash and guage swap
Car: 84 Berlinetta
Engine: 332 CI
Transmission: TH400
Axle/Gears: 3.08
Dash and guage swap
I'm getting ready to swap out my dash in my 84 berly with one from a 88 z28. can i get the wiring harness to work with the new gauges or do i need to hunt down a 88 camaro harness too?
Car: 85 IROC
Engine: LB9
Re: Dash and guage swap
hmm thought if it was digital it was all digital...but hell its been like 10 years since I was behind the wheel of a berly and that one didn't even start. My suggestions:
A) Do a few searches on here, see if you can find an answer.
B) just take the old one out and plug the new one in....and see if it works, if it does, great! If it doesn't then you get to figure out how to make it work
problem might be with speedo, I dont know if the digital unit was fed electronically or mechanically, if its electronic you'll have to get an adapter of some sort. If its mechanical, well at the least the speedo will work.
problem might be with speedo, I dont know if the digital unit was fed electronically or mechanically, if its electronic you'll have to get an adapter of some sort. If its mechanical, well at the least the speedo will work. Joined: Aug 1999
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If you intend to place the entire dash housing from an 88 Camaro into an 84 Berlinetta than you will need to replace the entire dash ( including the harness ) for it to work right.
You can't just swap the dash cluster so I'm assuming you plan on swapping the whole dash housing.
While you are at it you will need to replace the original heater / AC wiring harness. The Berlinetta system doesn't use vacuum and the Camaro system Does. The 88 Camaro was set-up with a dash harness connected to a Tail light harness - The Berlinetta used 3 harnesses for this purpose - so you might want to use the 88 Tail light harness to reduce the amount of splicing you will need to do.
Also; the windshield wiper wiring is different. You will need to either swap motors and cut/splice the wiring from the interior side of C100 to the motor, or cut the engine side harness and splice the berlinetta wiring into the camaro wiper wires on the dash harness.
I just swapped an 88 Camaro Dash housing into an 85 Berlinetta a couple months ago.
Car: 84 Berlinetta
Engine: 332 CI
Transmission: TH400
Axle/Gears: 3.08
Thanks for the tips. im not worried about the wipers, A/C, or heater because i have gotten rid of all of that. but now i know that i have to find another wiring harness.
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
I have no computer and an older motor and its a standard is it possible to put a berly digital dash in my 84? what sort of issues may I encounter?
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
try posting in a new thread of your own in one of the technical forums... i don't get why any of this post was in the parts wanted forum to begin with.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Vintageracer
Aug 11, 2015 08:13 PM
