need a steering column
Old Mar 24, 2008 | 06:23 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I need a steering column with a set of keys for the lock. Pm or post here if you have one and want to sell
Old Mar 24, 2008 | 07:27 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: need a steering column
year?
Old Mar 24, 2008 | 08:13 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by tpi-hearse
year?
By reading his info I would guess an 89 because he has two of them
Old Mar 24, 2008 | 11:20 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I have one, $75 shipped. Its from a 91 RS with Tilt, cruise, etc. Only issue it has is the hazard button broke off.
Old Mar 25, 2008 | 09:06 AM
WIll36's Avatar
Engine: 355, 408
It's going in my 88 but unless I'm mistaken they are all the same except for the ones equiped with airbags. I would rather have one with out cruise control if possible
Old Mar 25, 2008 | 09:15 AM
Stephen's Avatar
Car: 87 GTA
Well, the 89+ ones would be wired for VATS.
Old Mar 25, 2008 | 10:53 AM
WIll36's Avatar
Engine: 355, 408
Your right I did over look that. But you should still be able to use the column in any of the car because not all the cars can equiped with the VATS system from the factory?
Old Mar 25, 2008 | 11:11 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The biggest issue when it comes to the columns is usually the wiper function plug. There were at least 3 versions of that plug used from 82-92.The Vats is only an issue if the car needs it since it's an independant plug. If you don't need it don't plug it in !
I've got a couple "base" columns...... compatable with an 88 with no tilt, no cruise, no delay, no steering wheel, HAS key
Manual = $35 + shipping
Automatic = $30 + shipping
Hope this info helps !!
Old Mar 25, 2008 | 11:43 AM
tpi-hearse's Avatar
this is the years that work with one another
82-83
84-88
89
90-92
and if your car is auto you'll need one from an auto
Old Mar 25, 2008 | 11:47 AM
WIll36's Avatar
Engine: 355, 408
thanks i appreciate the information. Are the electronics the difference between the various styles or are there some physical differences to the columns themselves?
Old Mar 25, 2008 | 04:29 PM
WIll36's Avatar
Engine: 355, 408
thanks to everyone that offered to help I have a deal set with John so hopefully that goes as planned
Old Mar 26, 2008 | 04:41 PM
the973camaroguy's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
i have a steering column out of a 86 iroc z no vats i allso have a steering column out of a 82 camaro
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
