Disc 9-bolt, all suspension, more for sale
Old Apr 26, 2008 | 11:54 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I have a lot of parts from my 89 Camaro IROC-Z for sale. I have pictures of everything except the rear and suspension because they are still on the car. Feel free to make offers, please.
TPI intake manifold and associated parts:
-Throttle body
-Adjustable fuel pressure regulator
-Fuel lines
-Water Neck and thermostat
Brand new Mahle PowerPak pistons, SBC125030F05, for 383 stroker with 6" rods, $615 from Summit, asking $420 shipped
3" Flowtech exhaust cutout
19lb/hr injectors
Various climate control parts including condenser, evaporator assembly with switches, wiring, blower motor, resistor, controls (All climate control has been removed from the car)
Most cruise control related items
Stock crankshaft, pistons, rods (104k miles- L98 motor)
AutoMeter Phantom Air/Fuel indicator gauge, 2 1/16"- $25
Starter- $10
Water pump- $10
Instrument cluster trim piece
Valve covers- good shape- $25
Stock lifter guide plates
Stock rocker arms
Two (2) Accel coils
AIR Pump and hoses
Stock 153-tooth flexplate
OEM Fan switch and thermostat- never used
Complete disc brake 9-bolt rear end- should be 2.77 gearing- make offer
Stock driveshaft (700R4)
All stock suspension pieces (torque arm, sway bars, control arms, springs, shocks, struts, panhard rod)
Parts located in Palos Hills, IL
Remember, feel free to make offers. Most of this will likely be tossed soon. Thanks!
Old Apr 26, 2008 | 02:00 PM
Finetunedz28's Avatar
Re: Disc 9-bolt, all suspension, more for sale
Interested in the pistons and some other parts. Need some interior parts also. WHat color is the interior? What bore does the pistons fit? I live near Plainfield, Il. I could come pick up everything.
Old Apr 27, 2008 | 05:34 PM
Car: 1989 IROC-Z
Engine: 383 stroker
PM Sent
Old May 1, 2008 | 10:00 PM
Car: 1989 IROC-Z
Engine: 383 stroker
bump
Old May 2, 2008 | 08:33 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Mahle 383 pistons sold.
Old May 5, 2008 | 07:30 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I forgot to specify the brakes are PBRs
Old May 7, 2008 | 06:50 PM
1985z28FordKila's Avatar
ow much u want for the rear? is it posi and how many miles?
and can i get the break master cylinder along with it?
Old May 26, 2008 | 04:15 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Driveshaft sold.
Old Jun 1, 2008 | 04:01 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Entire TPI setup sold
Coils sold
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
