i need a chip from a 85 tpi 350 vette!
Car: 1966 El Camino Custom
Transmission: 200R4
Re: i need a chip from a 85 tpi 350 vette!
I've got a performance chip from tpichip.com for an 85 F-body with a manual transmission. Can you use it?
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i have a jet stage 2 chip for a 85 tpi, but its for a 305. it needs to be from a 85 vette. tpi 350's were not available in f-bodys in 85.only 85 vetts. but thanks
Transmission: 200R4
This is a custom chip. I had a 10:1 compression 350 with headers, Flowmaster cat-back, SLP runners, Big Mouth intake and a XFI 252 cam. That's what the chip as burned for. The question I should have asked: "Is the 85 Vette ECM the same as a '85 F-body?" If it is, you're welcome to try it out for just the cost of shipping. If it works, we can work something out.
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
