xe258hr less than 10k miles , and roller block 5.7
Old Jun 15, 2008 | 03:08 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
roller cam for tpi car......... perfect for a 305tpi but Ive heard good things about this cam for the l98 also..... $150 heres a link with specs...
http://store.summitracing.com/partde...8&autoview=sku
also have a vortec 350 roller block with 2 bolt caps, stock rods,pistons,roller lifters, lifter hold down retainer and a 89 l98 cam all have 80 - 90k miles on them... no crank for $120.........also got a set of 081 heads and 801 heads milled .030
Old Jul 12, 2008 | 09:30 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: xe258hr less than 10k miles , and roller block 5.7
Im a noob at this so I was wondering if alot of tunning is needed for that cam....is it more for racing or street use? what kind of increase in hp/tq?...will it affect gas mileage much(not too important but its nice to know)?
Old Jul 12, 2008 | 10:24 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
sorry I thought I got all the threads I started for these but I guess not, everything was sold thanks
Old Jul 12, 2008 | 10:45 PM
O ok
umm would you still be able to answer my questions about the cam? I'd like to know whether or not its worth it, thanks
Old Jul 12, 2008 | 11:08 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
the heads would need the valve guides milled down at a machine shop for the added lift.....anything over .470 needs to be.... its one of the best cams you can get for a 305 tpi.... I actually traded this cam and block for some nib subframe connectors,,, I believe the member I traded with decided to go another route and is now selling this cam.... look for his add with the xe258hr in the title... hes a good guy.
Frozer!!!
Jan 19, 2024 04:55 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
anesthes
Aug 8, 2015 09:37 PM
