T56 cable drive speedometer tail housing
Old Aug 3, 2008 | 12:29 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
T56 tail housing modified to run a mechanical speedometer. Includes modified tail housing, new speedometer gear sleeve, hold down tab, and a set of speedometer gears to match your gear ratio/tire size. Or if you are replacing a T5, you can use your existing gears. This conversion uses stock GM T5 gears that are readily available.
I have a couple of different gear sets in stock, but if I don't have the ones you need I'll have them drop shipped to you. This is a 93-96 style housing with thrust washers on the reverse idler gear. This conversion does not disable the stock VSS setup, and unlike other conversions available you do not have to remove the front torque arm mount to change the speedometer driven gear.
I can include the reverse idler gear at no charge so this can be used on all LT1 and LS1 style transmissions. Price is $425 outright, or $300 exchange with your tail housing plus $25 shipping for UPS ground. I can also do the conversion on your tail housing for $325 plus $25 for shipping in the lower 48 states.
Second pic shows how the speedometer drive gear fits on the main shaft, and third pic shows the differences in the different year tail housings.
Old Aug 31, 2008 | 06:12 PM
alloy's Avatar
Car: 87 IROC-Z28
Re: T56 cable drive speedometer tail housing
I can also do the cable conversion to your tail housing. Contact me for details.
Old Oct 14, 2008 | 03:54 AM
Pat Hall's Avatar
Bump for a good guy who's providing an affordable service a lot of us desperately need when swapping in a T56!
Old Oct 14, 2008 | 04:06 PM
alloy's Avatar
Car: 87 IROC-Z28
Thanks for the kind words Pat. Was a real pleasure doing business with you.
Old Feb 10, 2010 | 10:11 AM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
If you need to put a T56 in your third gen, look no farther. My tail housing looks Great, I can't wait to put it on my car. Thanks Again!
Old Feb 10, 2010 | 12:15 PM
alloy's Avatar
Car: 87 IROC-Z28
Thanks for the kind words TORN, glad your happy with my work. Let me know if there is anything else I can do for you.
Dan
Old Feb 10, 2010 | 08:40 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Stand up guy cant wait to get it in the car for next year. The workmanship is top notch
Old Feb 11, 2010 | 12:21 AM
alloy's Avatar
Car: 87 IROC-Z28
I'm just glad all of you are happy with my work. I originally figured this out for my T56, and I realized I had all the designs, fixtures, and tooling paid for, so why not offer this as a service to fellow hot rodders. You guys have been good to me and the extra $$$ I make have allowed me to further my own 3rd gen to a higher level.
Next mod is a new vortec headed 355 going in it!!!
Thanks again guys.
Dan
Old Mar 28, 2010 | 08:28 PM
1harley1camaro's Avatar
Want a title? Post!
Car: 68 Camaro, 65 C-10, 61 Corvette
Engine: LT1/4L60E, 5.3/4L60E, LS1/T56
Axle/Gears: 3.73s in all 3....
What a deal! Far better price and quality than what I have seen elsewhere. Thanks Dan!
Old May 2, 2010 | 10:26 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
I just finished putting my car back together after having Dan do the machine work to the tail housing. He does excellent work! Thanks again Dan!
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
