carb parts
Old Sep 11, 2008 | 08:23 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
carb parts
I decided im done messing with carbs and all that fun stuff, so im selling everything i have for a carb so i can convert to tpi.
All of this stuff is new or very close to new with LESS than 700 miles on it:
Demon road demon carb 625 cfm, stock jets, has 400 miles on it, with dual feed line, vacuum secondaries - $200
Tall plain chrome valve covers perimeter bolts very clean no scratches -$20
Generic aluminum Dual plane intake manifold -$40
Black 100 amp Alternator V-belt, one wire, works great only 2000 miles on it - $75
Chrome alternator brackets for 86 style sbc - $10
Aluminum water pump pulley, needs a little cleaning but overall great shape, v- belt -$10
V-belt Chrome Crank pulley - $10
305 heads, off early- mid 80’s 305, freshly rebuilt, they have maybe 1k on them after rebuilt, they do NOT smoke - $100
Crane Cams Gold 1.6, 1.5 roller rocker arms about 20k on them, they work fine, no ticking or visible damage - $150
Chrome Water neck early style for v-belt very clean no scratches - $10
GM HEI stand alone Dizzy recently tested by professional shop and passed, new vac advance mechanism, accel ignition chip included - $50
New stock Carter mechanical fuel pump self regulated at 6 psi, no return, - $25
Holley 600 CFM spread bore Carb, vac seconds, comes with remainder of rebuild kit - $20
Local pickup is prefered, but can work with buyer for shipping. Thanks
Old Sep 12, 2008 | 07:11 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Re: carb parts
casting # of the heads
Old Sep 12, 2008 | 08:53 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
head casting number: 14014416
Old Sep 13, 2008 | 08:46 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
very good parts here people ttt
Old Sep 13, 2008 | 10:48 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Re: carb parts
can you send me pics of the aluminum intake to endless448@Hotmail.com and some measurements (just looking for the tallest point)
Old Sep 14, 2008 | 12:41 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
the intake was painted by the previous owner... i have never had any problems with it or any leaks. here are some pics of the whole motor itself. i have not taken any parts off of the motor yet so here it is as it sits.
as far as measurements, it will fit under a stock hood, i have a 1 carb spacer on it and a bigger air filter, with the cowl hood i never needed to worry, but this intake was on another 3rd gen with a stock hood and it was fine.
Old Sep 15, 2008 | 11:30 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Sep 15, 2008 | 12:01 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: carb parts
Is the rocker arms a full set of 16 1.6 ratios or a mix od 1.5s and 1.6s?
Old Sep 15, 2008 | 10:11 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
half 1.5 half 1.6
Old Sep 16, 2008 | 12:07 AM
Mikz86TA's Avatar
Re: carb parts
ok thx anyways
Old Sep 16, 2008 | 11:23 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
want to add 350 block, 4 bolt mains, has bad rotating assembly still installed, will need machine work. 10033036 i believe is the casting number, its a crate motor. asking 100, must be picked up.
Old Sep 17, 2008 | 11:10 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt, offers welcome. more pics will be posted tomorrow night.
Old Sep 20, 2008 | 10:28 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
still up for grabs.
Old Sep 23, 2008 | 01:34 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Sep 25, 2008 | 09:38 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Sep 27, 2008 | 06:33 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Sep 29, 2008 | 07:52 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
make an offer !! this stuff needs to go!
Old Sep 29, 2008 | 11:30 PM
CAM_231's Avatar
Car: 87 Pontiac Firebird
Engine: Carbed LO5
Axle/Gears: 2.73 non-posi
Re: carb parts
PM sent.
Old Oct 5, 2008 | 04:54 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt.
Old Oct 9, 2008 | 09:26 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
update: power steering pump bracket + pulley are gone.
other parts still for sale. open for offers!
The demon carb is perfect, brand new !
Old Oct 16, 2008 | 09:15 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
open for tpi trades, or serp parts.
Old Oct 20, 2008 | 08:06 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Oct 31, 2008 | 05:09 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Nov 12, 2008 | 12:42 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
Carb spacer, air cleaner, dual feed line, throttle cable and bracket are SOLD
Still have all the other parts, That demon carb could use a good home, its perfect for a mild 350!
Old Nov 13, 2008 | 11:33 AM
gmtofd's Avatar
Re: carb parts
PM on the Carter mech fuel pump.
Old Nov 13, 2008 | 09:01 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
replied.
EDIT: the holley carb leaks at the throttle plate while on the motor. I have no idea how much on is but whoever wants that and the remainder of the build kit just pay for shipping and its yours.
Old Dec 12, 2008 | 09:24 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
still have parts, can negotiate price, need this stuff gone!
Old Dec 12, 2008 | 04:19 PM
kzhurley's Avatar
Car: 86 IROC-Z
Engine: 406
Transmission: TH400
Axle/Gears: Ferd 9 inch/ 4.11 spool
Re: carb parts
pm sent
Old Dec 18, 2008 | 10:16 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt still have a lot of parts.
Old Jan 18, 2009 | 08:54 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
Old Jan 24, 2009 | 11:21 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Feb 3, 2009 | 09:35 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Feb 6, 2009 | 10:40 PM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
open for offers on anything! need this stuff gone for my tpi swap
Old Feb 20, 2009 | 08:45 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
ttt
Old Feb 21, 2009 | 10:02 AM
nascar2496's Avatar
Engine: 305 tpi
Re: carb parts
pm replied
Old Feb 21, 2009 | 10:42 PM
laintocable's Avatar
Car: 89 firebird
Engine: 400 sbc/forged/alum/supercharged
Transmission: TH350, manual valve body
Axle/Gears: posi 390/4 whl disc
Re: carb parts
$150.00 for the Demon card shipped to 33635? Sorry, I'm low on $$$.
Old Feb 22, 2009 | 08:47 PM
Car: 89 firebird
Re: carb parts
free bump, let me know.
Old Feb 23, 2009 | 10:23 AM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
Transmission: TH350, B&M shift kit, Huges 3000 sc
Axle/Gears: 3:23 Posi
Re: carb parts
Hi, Im intrested in the Water pump pulley, Is it 1 or 2 groove?
Also, Is the holley together or does the rebuild need to be finished?
I am located in Jefferson and can come pick it up, Let me know Thanks.
Old Feb 23, 2009 | 10:31 AM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
Re: carb parts
Does the demon have electric choke?
Old Feb 25, 2009 | 04:56 PM
Car: 89 firebird
Re: carb parts
pm'd you.
Old Mar 3, 2009 | 04:33 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: carb parts
distributor still available? If so, any pics?
Old Mar 5, 2009 | 06:12 PM
Car: 89 firebird
Re: carb parts
is there anybody that will answer those interested in some of your parts???
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
