Bunch of parts FS:
Old Oct 10, 2008 | 10:52 AM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Bunch of parts FS:
I have a Red Neck performance 3200rpm stall converter. It has anti ballooning plates too. I bought it for my 700r4 that I was told was a 27 spline and its realy a 30. It'll fit a 200r4 and a th700r4 with 27 splines. I would like to get $250 shipped obo
I also have a Edelbrock electric fuel pump #1791, only seen 1000 miles. I got a bigger pump going in. $125 shipped. I can even include the relay kit.
400sbc bare block, 330817 casting numbers, $250
Edelbrock Performer RPM manifold 7101 $80 shipped.
Autometer Sport Comp silver 5" tach, converted to a mini shift light as well. $150obo.
1" Phenolic space, 4 hole $15 shipped
882 heads, upgraded crane springs. - $50obo
Custom true dual exhaust: Magnaflow x pipe, true duals over the axle into a set of Dynomax Bullets. $200obo
PM me if you're interested or want pics of anything.
Old Oct 11, 2008 | 11:31 AM
Engine: 406sbc
Transmission: TH400
Re: Bunch of parts FS:
Bump
All prices negotiable
Old Oct 11, 2008 | 12:45 PM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
Transmission: 700r4 auto
any chance of pics of the exhaust? whats the ground clearance?
Old Oct 11, 2008 | 01:12 PM
Engine: 406sbc
Transmission: TH400
Ground clearance is very good. It tucks up high to the floors. Heres some pics.. The epoxy stuff is JB weld, everything is fully welded but I threw some of that on just incase there was a tiny pinch, I HATE little exhaust leaks. Everything is also mandrel bent.
Old Oct 11, 2008 | 01:22 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
How big is the diameter and what is this set up for (long headers?)
Old Oct 11, 2008 | 02:31 PM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
has the block been bored? what condition is it in? 2bolt main correct?
Old Oct 12, 2008 | 09:21 AM
Engine: 406sbc
Transmission: TH400
The pipes are 2 1/2". It can be used for either actually, You can run a straight pipe from the shorties to the x or with LT's I use some hedman header extensions and some tubing to connect to the x.
The block is a virgin bore, 2 bolt main(stronger). I've been holding onto it in case I broke the 406 I have now. Heres soem pics.. I have had the block looked at needs a good Hone possibly a overbore from sitting. No core shift.
Old Oct 12, 2008 | 11:19 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
how much for the exhaust shipped to 11010
Old Oct 12, 2008 | 03:34 PM
Engine: 406sbc
Transmission: TH400
It'll cost about $25 or so to ship it to NY.
Old Oct 12, 2008 | 04:51 PM
RockJay81's Avatar
would you take 200 including the shipping 175 for the exhaust then 25 for the shipping?
Old Oct 12, 2008 | 05:04 PM
Engine: 406sbc
Transmission: TH400
Just waiting to hear back from some others. I'll let you know by tomorrow night.
Old Oct 14, 2008 | 12:22 AM
Engine: 406sbc
Transmission: TH400
Sale pending on the exhaust!
Old Oct 14, 2008 | 10:43 AM
Engine: 406sbc
Transmission: TH400
Exhaust is sold!
Bump for some other parts
LT1Formula
20
Nov 14, 2015 12:02 AM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
