LT1 Parts from 95 Z-28
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I'm parting a 95 Z28, have a lot of LT1 parts that can be used in your thirdgen conversions.
Lt1 Engine, 4L60 Trans, Posi Disc Rear. Let me know what you need.
Located in Nicholasville, KY 40356
Examples of prices.
Injectors $25 shipped.
Fuel Rail $25 shipped.
TB with sensors $25 shipped
Heads $150 shipped
Shortblock $250 (pick up only)
Alternator $50 shipped.
AC Compressor $50 shipped (Cold Ac works great)
Just Installed Opti $100 shipped.
Water Pump $50 shipped
Radiator $50 shipped
Fans $90 Shipped
Trans $200 (Pick up only)Shifted fine before parked.
Posi Disc Rear w/brakes $200(Dont know the gearing) Pick up only
Lt1/4L60 Harness and PCM $150 shipped
Examples of prices.
Heads $150 shipped
Fans $90 Shipped
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Re: LT1 Parts from 95 Z-28
Do you have the 95 LT1 timing cover in good condition? If so I will buy! Let me know, pics would be nice too
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Jt, I'd like to have the timing gear cover too but SomeGuy beat me to it!
W
W
Jt, do you have the spider retainer, roller lifters and keepers?
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Yes, they are still in the engine. I have no problem tearing it down if you need them.......jt
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Hi,
I would like the injectors But before I send you money do they all work and is it a set of 8? do you have a ohm meter and can you check the the coils to see if they are all about 16 ohms...
Dave
daferris@cablespeed.com
Dave
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Hi,
Dave
Dave
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Coil Assembly $25 shipped
TB With Sensors $25 shipped
Alternator $50 shipped(Tested and Works great)
Fuel Rails $25.00 shipped.
Valve Covers $25.00 shipped
LT1 Intake $50 shipped
PCM/Bracket 95 LT1/Auto $75 shipped
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Sorry, i sold the heads and what was left of the engine.......jt
LT1Formula
20
Nov 14, 2015 12:02 AM
