parting out 1988 gta--5.7tpi car
Old Jan 14, 2009 | 07:47 PM
89irocz355's Avatar
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
have whole car. what do you need?
Old Jan 15, 2009 | 10:41 AM
IrocTheZ28's Avatar
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
Re: parting out 1988 gta--5.7tpi car
Dual fan assembly and whole or partial ( no runners or fuel injector rail ) TPI intake assembly available?
Old Jan 15, 2009 | 07:14 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Is the motor a roller block standard bore?I need a core.
Old Jan 15, 2009 | 08:11 PM
89irocz355's Avatar
it is all original. never rebuilt. i'd take $400 complete with tpi or $300 without intake setup
Old Jan 16, 2009 | 07:51 AM
Steve Mack's Avatar
Car: 87 Iroc
How many miles on the motor?
Old Jan 16, 2009 | 03:13 PM
89irocz355's Avatar
115,000. runs great.
Old Jan 16, 2009 | 05:20 PM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
pics and price on the front groundefect pieces shipped to 20636.
steven.m.coogan.ctr@navy.mil
Thanks!
Old Jan 16, 2009 | 06:02 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
what color is the interior? hows the headliner? hardtop?
Old Jan 16, 2009 | 06:39 PM
tri power's Avatar
i need top and bottom radiator bracket or complete dual fan setup and left and right front ground effects.
Old Jan 16, 2009 | 10:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Send me pics of the engine and the tpi because i rebuild them and sell them
Old Jan 17, 2009 | 02:34 AM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
PM Sent.
Old Jan 17, 2009 | 04:33 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
color of the interior?
Old Jan 17, 2009 | 06:22 AM
89irocz355's Avatar
gray
i need to sell the whole fan setup complete for $75 shipped. the ground effect pcs: 1 is junk. i have the other on e-bay till tomorrow night.
are you around here. i get them all the time. i'll post pics later today. still in car but i'll pull near end of week.
Last edited by 89irocz355; Jan 17, 2009 at 06:25 AM. Reason: Automerged Doublepost
Old Jan 17, 2009 | 10:00 AM
tri power's Avatar
i will take the complete fan setup for 75.00 shipped to 36274 let me know how you take payment. thanks
Old Jan 17, 2009 | 01:24 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Do you have the AC lines? Are they in good shape?
Old Jan 17, 2009 | 04:43 PM
89irocz355's Avatar
heres pics of the motor.
Old Jan 17, 2009 | 08:43 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Sent you a PM
Old Jan 17, 2009 | 08:53 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What about the headers and flywheel and the whole intake system how much shipped to 90650
Old Jan 17, 2009 | 09:20 PM
87Formula391S/C's Avatar
Car: 87 Formula
Engine: L98-350
Transmission: 700-R4
Axle/Gears: 3:08 Posi (Disk)
what shape is the rear wing in an d how much?
Old Jan 17, 2009 | 09:53 PM
89irocz355's Avatar
actually, it has the 91 rear wing.
Old Jan 17, 2009 | 10:15 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
how much for ecm and tpi wiring harness(with plugs please) shipped to 35209?
Pm price if you dont mind.
Old Jan 17, 2009 | 11:29 PM
89irocz355's Avatar
i'll get back to you. if i sell the motor w/o it.
Old Jan 26, 2009 | 07:29 PM
swerv52's Avatar
Car: 1989 IROC-Z
Engine: 5.0 Liter TPI
Transmission: 5-speed Manual
Axle/Gears: 3.45:1
Do you have the air inlet system. I need all of the parts from the air cleaner housing that bolts into the battery box in the right front fender to the Mass Air Flow sensor. I also need the bracket that mounts the MAF to the top radiator support.
Old Jan 26, 2009 | 08:32 PM
89irocz355's Avatar
i have the whole setup with the bracket but i sold the mass air sensor.
$40 shipped in the u.s.
Old Jan 26, 2009 | 09:33 PM
88tpi350's Avatar
Car: 88 formula
Thanks!
need the ones that go from infront of the front wheels to the front bumper
Old Jan 27, 2009 | 04:03 AM
89irocz355's Avatar
i sold the ones on this gta. but i'm picking up a 89 gta saturday morning and i'll send you pics. this weekend. $75 shipped for both. i know they should be mint cause the body is clean on this car.
Old Jan 27, 2009 | 08:09 AM
vingta1989's Avatar
Car: 1989 GTA CONVERTIBLE
Engine: 355 tpi
Transmission: ART CARR 700 R4
Axle/Gears: 3.70
do you have the emergency brake brackets? that bolt on to the rear calipers specifically driver side for an 89 gta?
Old Jan 27, 2009 | 11:38 AM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
Does it have the deluxe door panels? If so, I could use the arm rest brackets off the door. Thanks.
Gilley's86
Old Jan 27, 2009 | 02:23 PM
pdizzle9691's Avatar
Want a title? Post!
Car: 91 Z28
Engine: 5.7 TPI
How bout you take off the throttle position sensor, and let me have it for cheap
Old Jan 27, 2009 | 04:03 PM
swerv52's Avatar
Car: 1989 IROC-Z
Axle/Gears: 3.45:1
I don't need the MAF. I only need the parts from the air inlet to the MAF. Including the SUPPORT, Air Cleaner (p/n 10034600), HOUSING, Air Cleaner (p/n 25098232), DUCT, Air Intake Front (p/n 10055894) and BRACKET, Mass Air Flow Sensor (p/n 10055896). Can you take pictures of the parts that you have and e-mail them to me at swerv52@aol.com
Old Jan 28, 2009 | 10:18 AM
dranate's Avatar
Car: 1986 camaro, 1992 and 1994 saturn
Engine: 305 wanting a 350
does the rear end have posi if so email me at pokerthug123@yahoo.com
Old Jan 29, 2009 | 03:22 PM
89irocz355's Avatar
Gilley's86
it has the good panels. heres the pics of the armrests
Attached Thumbnails parting out 1988 gta--5.7tpi car-100_2055.jpg   parting out 1988 gta--5.7tpi car-100_2056.jpg
Old Jan 29, 2009 | 05:50 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
How much for the headliner?
Old Jan 30, 2009 | 01:18 PM
LouStugots's Avatar
Car: 2006 VW Jetta GLi
Engine: 2.0t
how much for just the heads?
Old Jan 30, 2009 | 04:37 PM
89irocz355's Avatar
$20 shipped in the u.s.
Old Jan 30, 2009 | 04:39 PM
89irocz355's Avatar
$120 shipped to n.y.
Old Feb 2, 2009 | 02:44 AM
ajmaudio's Avatar
how bout a good deal on teh engine accessory brackets?
Old Feb 2, 2009 | 05:00 AM
89irocz355's Avatar
whats your zip?
Old Feb 2, 2009 | 05:38 AM
ajmaudio's Avatar
37013... thanks
Old Feb 2, 2009 | 06:01 AM
89irocz355's Avatar
Originally Posted by 89irocz355
whats your zip?
i can do $70 shipped. only cause shipping is a fortune nowadays.
Old Feb 2, 2009 | 12:39 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
what does it have for a rear end and what would you take for it?
Old Feb 2, 2009 | 01:19 PM
89irocz355's Avatar
i believe its a 3.23 disk posi. i'll have it out saturday morning. i'll check the gears but i think thats what it is. $200
Old Feb 2, 2009 | 02:25 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Got any casting #, or valve sizes for the heads? How much shipped to 33635? Please Pm me,Thanks.
Old Feb 2, 2009 | 02:27 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
good trans? and how much? im actually looking for just a core
Old Feb 2, 2009 | 05:00 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Will you ship the entire motor how much to 90650
Old Feb 2, 2009 | 06:05 PM
89irocz355's Avatar
don't really want to ship a complete motor. it would take alot of time and work on my behalf.
Old Feb 2, 2009 | 06:25 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Do you have the front bumper reinforcement? Connects the bemper cover to fenders
Old Feb 2, 2009 | 09:36 PM
Well?
Old Feb 2, 2009 | 09:49 PM
89iroczsbc's Avatar
what kind of wheels are on it? also what color is the interior
Old Feb 2, 2009 | 11:24 PM
lillis375's Avatar
Car: 1989 Camaro
Axle/Gears: 9 bolt 3.45
accessory braket with power steering pump shipped to 32907 perfer just that bracket not the whole thing thanks
