1987 IROC Z kick panels wanted
Car: 2010 2LT RS
I just recently traded my 87 Vette Roadster for a very nice mint 1987 red IROC Z . The car needs a few things for the interior. I noticed it does not have kick panels which cover the fuse box on the drivers side and the passenger side area as well. There are under dash light bulbs hanging. Where can I find these parts and did the IROCs have them?
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: 1987 IROC Z kick panels wanted
I ahve both under dash panels from a 87 camaro. Doe snot have the fuse lid for the drivers side. PMN me your email and I will send you some pics.
Car: 2010 2LT RS
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
those are not kick pannels they are under dash hush pannels, i have them also with the fuse box cover if still needed, kick pannels are the color of the interior and on the lower part of the post just some fyi.
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
still need this? I have several styles but not sure which yours takes. I forget. Got any pics anyone?
Thx
Ray
Thx
Ray
Car: 87' Pont GTA
Engine: 5.7L
Ted is correct. What you are requesting is the Under Dash Covers and they run $10.00 each plus shipping and handling. You may also need the Fuse Cover that runs $5.00 and the Diagnostic Link Cover which runs $3.00 plus shipping and handling. If you have any questions or other needs we can be reached at (805) 522-2539.
Thank you,
Thomas R. ***
(805) 522-2539
www.houseofcamaro.com
Thank you,
Thomas R. ***
(805) 522-2539
Car: 87gta 88gta 88marovert
The frist tow are camaro hush panels the drivers side one is out of a manual trans car. I have one form a auto car but don’t have any pics right now. The third one is a pass side form a firebird a/c delete car.
Car: 2010 2LT RS
Here is what House of Camaro sent me. Thomas is a good guy. However I think he may have sent me the wrong hush panel for the drivers side for my year IROC. There are 3 mounting screw holes at the top with a cut out for the diagnostic terminals. I have the cap for it however this cut out is blocking me from removing the cap from the terminal freely. The middle mounting hole is off and does not line up correctly for me to screw the center in place. I believe there should be 4 mounting screw holes. This looks to be from a later year camaro.. maybe a 91-92? Here are pics...
That not one from a 91-92. 91-92 do not have aldl covers. Just a fuse panel cover
Transmission: auto
it looks to be from a camaro, but i always thought 82-89 are the same except for ac delete and 5-speed setup, i could check what i have and let you know
hey 87, the panel you have is for your car the 91-92 has the ode port on the left side, they are all have the 3 holes to mount, but sometimes they dont line up witch is a common prob for cars that are 20+ years old things shift and then not to line up, but if you still want another i have a few for all years pm if your interested.
Car: 2010 2LT RS
That is defiantly form a firebird. If your iroc has the adl cover that goes over the connecter look at the top of your kick panels there might be a metal bracket with a hole for the lights. The cars that came with out the hush panels had a adl cover the slides on and the brackets for the lights on the kick panels.
Car: 2010 2LT RS
Hear check out this link.
https://www.thirdgen.org/forums/hist...-plastics.html
If you look at the first 2 pics I posted before they are camaro hush panels you can see the top is not strait across one side hier then the other. The 3rd picture is a firebird panel it is strait across like the ones you have.
Car: 2010 2LT RS
Pm me your email I just got a hus panel with fuse lid cover form a 82 camaro. I will send you some pics
mustangman65_79
Aug 11, 2015 03:17 PM
