cleaning out the garage!
Old Mar 25, 2009 | 07:48 PM
scaryjerry's Avatar
Transmission: t-5
All parts include shipping Or you are welcome to pick them up and save some cash. For trade Im only looking for a set of slick's and skinny's. (3.5x15 and 10x15 with 5.5bs)
Im located in delavan wisconsin,
Thanks for looking. ask any questions and ill try my best to get you a answer.
I have pictures for everything just ask.
1.) t-5 shift plate out of a 88 formula. One window motor button is a different color altho they work. No rips in the boot! great shape----$75
http://i381.photobucket.com/albums/o...2/IMG_0479.jpg
http://i381.photobucket.com/albums/o...2/IMG_0480.jpg
2.) 4:11 gears for a ford 9inch.------------------$75
http://i381.photobucket.com/albums/o...2/IMG_0483.jpg
http://i381.photobucket.com/albums/o...2/IMG_0484.jpg
3.) MSD 85551 stock distributor gear --------------$7
http://i381.photobucket.com/albums/o...2/IMG_0489.jpg
4.) 749 computer with no memical.---------$30
http://i381.photobucket.com/albums/o...2/IMG_0462.jpg
5.) tpi throttle bracket---------$7
http://i381.photobucket.com/albums/o...2/IMG_0454.jpg
6.) I have 2 chrome oil dip stick----------$7each
http://i381.photobucket.com/albums/o...2/IMG_0457.jpg
http://i381.photobucket.com/albums/o...2/IMG_0458.jpg
7.) boost gauge with wiring------------$15
http://i381.photobucket.com/albums/o...2/IMG_0496.jpg
http://i381.photobucket.com/albums/o...IMG_0497-1.jpg
8.) I have 2, 3bar map's -----------$10 each
http://i381.photobucket.com/albums/o...2/IMG_0444.jpg
9.) tpi mass air flow sensor screen's are cut out. I know i have another one with the screen's still in place for the same price.--------$50
http://i381.photobucket.com/albums/o...2/IMG_0475.jpg
10.) Brand new flywheel shim -----------$5
http://i381.photobucket.com/albums/o...2/IMG_0446.jpg
11.) stock 88 formula 350 distributor without a gear. I did have a brass gear for this, altho i cant find it right now. If i come across it it will come with it.
$ 50
http://i381.photobucket.com/albums/o...2/IMG_0438.jpg
12.) Knock sensor for speed density---------$10
http://i381.photobucket.com/albums/o...2/IMG_0448.jpg
13.) soild roller lifters. Crower. All hot tanked, and cleaned. I dropped one in the clean tank and chipped one, (see pic) You can still order a single roller from crower and save $$$. Stock sbc size. No offsets. --------$100
http://i381.photobucket.com/albums/o...2/IMG_0503.jpg
http://i381.photobucket.com/albums/o...2/IMG_0506.jpg
http://i381.photobucket.com/albums/o...2/IMG_0507.jpg
14.) Full roller rockers 1.6 ratio with 7/16 studs with polly locks. All but one are rebuildable. They are all in perfect working order, just hot tanked. 4 of them are straight in the back and the rest are angled,(see pic) Reason for selling is they hit the new springs. 2mins of run time and you can see where they hit. I called comp and they said when you grind them it does not affect the performance. Im unsure what brand they are. They came on my brodix heads.-------------$80
http://i381.photobucket.com/albums/o...2/IMG_0509.jpg
http://i381.photobucket.com/albums/o...2/IMG_0510.jpg
http://i381.photobucket.com/albums/o...2/IMG_0512.jpg
http://i381.photobucket.com/albums/o...2/IMG_0513.jpg
15.) comp cam. soild roller custom grind small circle base. Ment for boost or nos. 3 months old. Went with a new head combo I have pic's of grind number and cam card!----------------$225
http://i381.photobucket.com/albums/o...2/IMG_0477.jpg
http://i381.photobucket.com/albums/o...2/IMG_0473.jpg
http://i381.photobucket.com/albums/o...2/IMG_0478.jpg
http://i381.photobucket.com/albums/o...2/IMG_0517.jpg
16.) cran cam's polly locks for 3/8 studs. Brand new never used!!----$15
http://i381.photobucket.com/albums/o...2/IMG_0455.jpg
http://i381.photobucket.com/albums/o...2/IMG_0456.jpg
17.)two inch aluminum carb spacer----------$7
http://i381.photobucket.com/albums/o...2/IMG_0463.jpg
18.) brand new edelbrock carb bracket. chrome.--------$15
http://i381.photobucket.com/albums/o...2/IMG_0472.jpg
19.) sbc 400 forged pistons with stock rods. i bought the pistons from a friend new and they are speedpro. One piston is damaged. All the other 7 measured out perfect still. Stock bore.------------$100
http://i381.photobucket.com/albums/o...2/DSCF4246.jpg
http://i381.photobucket.com/albums/o...2/DSCF4247.jpg
http://i381.photobucket.com/albums/o...2/DSCF4248.jpg
20.) 7 brand new forged 6inch H-beam rods. Brand name is race parts, or that is who sells them. These have been threw already and all measured perfect and all weighed out also. 7/16 arp bolts(you can find them on ebay for 275 a set.) stock size ends. ----------$100
http://i381.photobucket.com/albums/o...2/DSCF4242.jpg
http://i381.photobucket.com/albums/o...2/DSCF4241.jpg
THESE NEXT FEW THINGS DONOT INCLUDE SHIPPING! They are pick up or you pay actuall shipping charges.
21.) set of GTA rims. The outter lip has been stripped and hand polished to a mirror finish. They are origanally charcoal color. The white dots are water spots. I will buff them up befor they are sold. No center caps------$300
http://i381.photobucket.com/albums/o...2/DSCF4098.jpg
http://i381.photobucket.com/albums/o...2/DSCF4099.jpg
http://i381.photobucket.com/albums/o...2/DSCF4100.jpg
http://i381.photobucket.com/albums/o...2/DSCF4101.jpg
22.) 383 stroker from eagle. 5.7 sir rods. steal crank with 350 journal's. KB hypereutectic pistons .30 over. For the bad new's 2 pistons cracked in the same spot. and cracked the block in one spot. If you want to get 2 new pistons from summit they are 70 each. The engine bag tore so everything will need to be cleaned and i would mirco polish everything.-------$150
23.) sbc 400 with only 8k on it. stock casting style pistons but .40 over. 509 casting 2 bolt block. Bad news is the engine back was torn and everything sweat so their is slight surface rust altho everything was well oiled. No ridge, so a hone will clean up the block and mirco polish everything else. This is only a short block------------$200
24.) bunch of t-5 parts. I had 3 for parts since i kept breaking them. just ask and i may have something you need also i have 1 stock shifter with a camaro and firebird ****.
Old Mar 27, 2009 | 05:38 PM
scaryjerry's Avatar
Transmission: t-5
Re: cleaning out the garage!
bump
Old Apr 3, 2009 | 08:02 PM
scaryjerry's Avatar
Transmission: t-5
map and knock sensor is sold
Old Apr 18, 2009 | 10:17 PM
TransAM Joe's Avatar
still have the Formula t5 shift plate?
Also looking for t5 clutch dust cover
Old Apr 19, 2009 | 12:22 AM
mrtater99's Avatar
Car: 89 RS.. 91 1/2ton 1500
Engine: 305 tbi
Transmission: 5 speed manual
pm sent
Old Apr 25, 2009 | 07:58 AM
Antoneal's Avatar
Car: 1969 Camaro SS
Engine: 396 bbc Berger built
Transmission: 4 spd stick
Axle/Gears: 4.11 posi
do you still have the MAF (mass air sensor)?
Old Apr 25, 2009 | 03:54 PM
Big, White & Sl's Avatar
Car: 86 Camaro
Transmission: Powerglide w/brake
Axle/Gears: Currie 9" w/4.56
What's the recommended rpm range for the cam?
Old Apr 25, 2009 | 04:01 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Do you have a good T5 case? I just need the bare main case, I found a small crack in mine while rebuilding it. Price + shipping to 15963.
Old Apr 25, 2009 | 04:10 PM
king1960's Avatar
Is the maf a five wire style?
Old Apr 25, 2009 | 09:36 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
pm'd you to buy the poly locks let me know thanks.
Old Apr 26, 2009 | 04:15 PM
scaryjerry's Avatar
Transmission: t-5
sold the cam and lifters.
Old Apr 26, 2009 | 04:17 PM
Car: 86 Camaro
Thanks anyways.
Old Apr 26, 2009 | 04:25 PM
scaryjerry's Avatar
Transmission: t-5
Yes sir i have one. I have like 3. I would have to take the gears out of them for the fact i broke 3rd gear in all of them. I am located in wisconsin, and im guessing on shipping here but if you think this is fair, $75 shipped?
Old Apr 27, 2009 | 11:46 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
PM Sent
Old Apr 20, 2010 | 09:55 PM
Julie1980's Avatar
Would you do $250 for the GTA rims??
Old Apr 20, 2010 | 09:58 PM
scaryjerry's Avatar
Transmission: t-5
would i take 250 for what?
Old Apr 20, 2010 | 10:02 PM
Julie1980's Avatar
$250 for the GTA rims!!
Old Apr 20, 2010 | 10:06 PM
scaryjerry's Avatar
Transmission: t-5
pm sent.
Old Apr 21, 2010 | 12:05 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Did you sell both MAP sensors? If you still have one I'm pretty sure my brother will be interested in it. Also, do you happen to have any good synchros/keys from those T5's? I think mine are kinda worn as the shifting is getting more and more "notchy".
Old Apr 22, 2010 | 01:44 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
does the edelbrock carb bracket support the throttle cable and th350 kick down?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
