Wonderbar and Sway bars for sale
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Parts for sale:
Wonderbar Steering Brace
Pulled from an 86 IROC
SOLD
Firebird / Trans AM MAF Ducting
The ducting or boot that connects the throttle body to the MAF Sensor and then the second duct that connects the MAF sensor to the air cleaner can.
These boots are in excellent shape, and even have ALL clamps on them.
SOLD
Also have a set of Front and Rear Sway bars off the IROC.
Post your zip code if you seriously interested and I will get you shipping info.
SOLD
SOLD
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
Re: Wonderbar and Sway bars for sale
what size is the rear sway bar? shipped to 75075
thanks
is the wounder bar aftermarket?
thanks
I couldnt find my caliper but I found the Circumference to be 2 7/8" and using the formula C=pi/d the diameter is d= .915140" and converting to mm
D= 23.25 mm
My best guess is that it is the 23 mm sway bar, assuming my math is right.
The wonderbar is a stock wonderbar off an 86 IROC that I parted out.
PM Sent
bump
PM Sent
Car: 92 firebird, 95 Z28
Engine: LO3, LT1
Transmission: 700R4, 4L60E
Axle/Gears: 2.73 4th gen posi(x2)
do you still have the wonderbar? I am local so shipping isn't an issue if you do...
PM Sent
Payment received from Gen 3 Fbody Fan for one of the Wonderbars.
Thanks!
Thanks!
Payment received from 92jamaicayellow for last Wonderbar, thanks!
Both Wonderbars are SOLD
Positive feedback left for Gen 3 Fbody Fan and 92jamaicayellow.
Both gentlemen are excellent buyers with good communication.
raymondandretti
Exterior Parts for Sale
Sep 5, 2015 05:02 PM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
