WTB: 305-350 TPI 91-92 memcal
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I am in need of a stock TPI prom/memcal from 91-92. Must be TPI V8, 305 or 350. Let me know what you have
Car: '57 Chevy 3200 pickup big window
Engine: L98 350...zz4 longblock
Transmission: corvette 4+3
Axle/Gears: 3.38:1
Re: WTB: 305-350 TPI 91-92 memcal
I have a memcal for a 92 firebird 350 TPI auto. Chip numbers are:ANJF 4307
$65 shipped to lower 48. build date on the car was feb 92, key resistance is #12
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
yea i need to buy one ofthem too i jsut swaped my 305 to 350 i need a prom/memcal 350 tpi auto u know were i can get one
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I know you said stock, but I have a Hypertech I figured I should mention. 91 305 TPI Auto ( #121342 )
I know you need one for a 350 ngonnelly, My response was for Orr89RocZ.
Car: 89 Iroc-z
Transmission: TH400
Bump I need a memcal. preferably a 305 TPI 90-92 auto setup since i got a 305 knock sensor in the car but i'll take what i can get
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Hey, do you still have that 350 tpi memcal? let me know if you do.
Car: 91 RS
Axle/Gears: 3.45
i have a 91-92 305 TPI chip if thats what your looking for?
i just need one for a 350 91-92 TPI so i can seel or if someone is looking for a trade...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I need one too 90-92 tpi speed density 305 or 350 I don't care pm me !!
Car: 57 chev 2dr sedan - 57 chev 3100
Engine: the car is a 350 the truck is a 383
Transmission: both turbo 350s
I might be interested in that. I have a aujp (350 auto) that I may need to trade for a 305 16163062. I am doing a custom build in my 57 chevy pickup and its not running great on the aujp with a piggyback from scott hanson. He told me because its custom (72 vette 350 now a 383 stroker w/ 92bird tpi) it would run better with the 305 memcal and the same piggyback as an easier over ride. I would have to let you know but it should only be a couple of days. I have access to a 16163062 and we are going to try it first
Engine: Lb9
Transmission: M20
Axle/Gears: 3:42
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Axle/Gears: 3:42
Cause if you have a 305 motor, then you should use the 19lb/hr injectors or if you are using 22lb/hr then you should reduce the fuel pressure so the car can run correctly. It will run overly rich with larger injectors and will be a little quicker with the correct injectors.
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
I have a stock 305chip for a 91 camaro 305 tpi speed density
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Car: 91 camaro vert
haha yea it is just wasn't paying attention to what i was typing.
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
