Go fast goodies!! performance engine part out
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. Recent plan change is having me part out my engine. Heres what I've got.
MAKE OFFERS THIS STUFF HAS TO GO!!! MOST DECENT OFFERS NOT REFUSED!
-1992 chevy 355 roller short block assembly. Bored .30 over. around 35k on engine since rebuild. Includes set of roller lifters and spider assembly. $250
-Comp XR276 extreme roller cam. 224, 230 dur @ .50, .503, .510 lift with 1.5 rocker arms, 112 LSA *SOLD*
-Trick flow stock length pushrods $25
-Trick Flow 23* aluminum cylinder heads, complete, springs good for up to .540 lift cam. Centerbolt style for 87-95 engines. *SOLD*
-Dynomax shorty headers w/ Y-pipe. Headers are black painted in good shape. Y-pipe is a little banged up but works. 2 1/2 inch outlet on Y-pipe. *SOLD*
-chrome stamped steel centerbolt valve covers with hardware *SOLD*
I also have 2 distributers for the later style FI engines...88-95 I believe (small cap), but don't quote me. One is aftermarket and almost new..$50 for it, and the other is a stock replacement with new cap and rotor..30$ for that one *BOTH SOLD*
If I think of anything else I will add it.
Car: 1986 Trans am
Engine: 5.3 LM7
Re: Go fast goodies!! performance engine part out
Forgot to mention, all parts have never been driven on the street, only started and run in the driveway so they are all almost brand new!! Shortblock is the only thing with miles on it.
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
What condition is stock distributor in?Is the gear on the bottom worn badly?
Car: 1986 Trans am
Engine: 5.3 LM7
Gear is in really good shape. Dist came out of a 93 chevy 1500 with I believe around 95K on it. Has a brand new blue cap and rotor kit too. I will check it again when I get home from work, but I am positive it's in nice shape. I had it in my car running for a little while so I know it works.
Car: 1983 firebird
Transmission: t-5
Axle/Gears: 10 bolt, locker, disc brake setup.
how much for the headers and y pipe shipped to Carey, Ohio 43316
Car: 1986 Trans am
Engine: 5.3 LM7
PM sent
C'mon guys start makin offers!! I need to make room for a nice new 5.3 LSx!! Haha.
Also have a 400 unbored SBC engine. Ran good when pulled. Took heads off so will need head gaskets. Motor comes with heads, Heavy duty aluminum holley valve covers, oil pan, balancer, & timing cover (long block basically) 400$
I need space!!
I need space!!
Car: 87 Iroc
What part o Connecticut are you in?
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
interested in the 355, cam, pushrods. How far north are you? it would be a nice & long drive for me lol..
-T
-T
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 1986 Trans am
Engine: 5.3 LM7
Like I said before, I'm about 15 mins north of Hartford. I would say I could meet you somewhere but honestly, I think that would be more trouble than it's worth, trying to shuffle a 355 between 2 trucks, since I have an engine hoist right at my house. If your really interested, I can give you a deal on that stuff. PM me and we can talk.
Car: 1986 Trans am
Engine: 5.3 LM7
Bump, stuff is still for sale!!
I will sell the entire engine with front accessories, roller rockers, the WHOLE engine minus intake manifold and valve covers for 1500$!!!!! This engine cost me 3000$ to build. It is a 430 HP engine for half price.
I need space! Everything will start going to ebay in the next week.
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Nvm looking for 3" outlet
Car: 1986 Trans am
Engine: 5.3 LM7
TTT
Start making those offers. . .Price on heads just lowered!
Car: 1986 Trans am
Engine: 5.3 LM7
Bump for a good salesman
Car: 92 RS
Axle/Gears: 4th Gen/3.23/Posi
Any pics of the two distributors?? Who makes the aftermarket one?? I'll probably pick up one of those two... some pics and more info on the one would be great. Thanks!
Car: 1986 Trans am
Engine: 5.3 LM7
Not too sure on the brand that makes the aftermarket one. It MAY be proform but don't quote me on that. I bought it brand new in the box at a swap meet for 100$, put it in quick, had the engine running for a week or 2 and then switched to carb haha, so new distributor. Unfortunately I don't have the box anymore either, but there was no brand name on it. It looks like it's a pretty nice quality part though. The entire shaft is billet aluminum and it has a nice red cap and rotor with brass terminals. I'll post some pics up after work today (around 5PM).
Car: 1986 Trans am
Engine: 5.3 LM7
I do have an MSD direct replacement coil for 87+ engines, as well as a few factory coils lying around. As far as wiring, I should have harness connectors for the coil and MAYBE 1 for the dizzy. I would have to check.
Car: 92 RS
How much were you looking to get for the MSD coil? If ch@os doesn't take it, I'll probably ****** that up. Definitely going to take the aftermarket dizzy though... I'll be looking for the pictures. PM sent!
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 1986 Trans am
Engine: 5.3 LM7
Pics of new dizzy *SOLD*
Car: 1986 Trans am
Engine: 5.3 LM7
MSD coil and used dizzy *SOLD*
Car: 1986 Trans am
Engine: 5.3 LM7
355 short block
Engine has to go. I am pretty flexible. This is a nice, solid shortblock with low miles, and it's a roller engine!!
Car: 1986 Trans am
Engine: 5.3 LM7
Have a set of ford racing 30lbs injectors for sale as well, in like new condition. Were used to start a motor then I switched to carb. Paid 300$, looking for 130 shipped!!
SHORT BLOCK WAS LOWERED TO 250$ !!! I NEED IT GONE
Car: 1986 Trans am
Engine: 5.3 LM7
bump...injectors and short block still up for grabs
Fast355
Dec 2, 2016 06:33 PM
