[AZ] 92 firebird 350 engine
Old Aug 3, 2009 | 09:39 PM
coupeguy2001's Avatar
Car: '57 Chevy 3200 pickup big window
Engine: L98 350...zz4 longblock
Transmission: corvette 4+3
Axle/Gears: 3.38:1
I have a 350 firebird TPI engine with 55,000 miles for sale.
PICS AVAILABLE
This is a complete engine, It has a carb on it right now.
Currently, it is on my engine run stand so you could hear it run if you live close by.
Factory full roller 350, one piece seal block, Iron heads, R/H dipstick, original bore, standard crank, comes with cam, lifters, pushrods, factory guided rockers, spider, harmonic balancer, tin rocker covers, timing cover and pan.
It has 40 PSI oil press. on the starter, idles cold with 55 PSI.
HOWEVER:
If you want to buy it as is, With the engine run stand accessories, we can come to an agreement. The carburetor will need a kit.
The engine accessories bolted to it stay with the run stand, including manifold and carb, starter, exhaust, smog pump delete kit, Edelbrock reverse rotation water pump, MSD ignition, bilet distributor, accel cap and wires, unless you want it as is..........add $600 since everything is off an 88 corvette....or I can send it with the firebird stuff, only $300 more.
ASKING:
$600 for the engine long block without accessories, I mean everything on your car right now will bolt on to this engine, so why buy stuff you don't need?
I have the serpentine belt system for it in case you need a setup.
$300 for the serpentine setup....AC compressor, power steering pump, water pump, smog pump, alternator, tensioner, all pulleys and brackets and belt. This sells at Summit for more than double that.......Hmmmmmm......maybe I'm not asking enough for this!
$150 for Edelbrock headers
Old Aug 4, 2009 | 12:29 PM
yagga001's Avatar
Car: 88 CAMARO RS
Engine: 350TBI
Re: 92 firebird 350 engine
Any pics of the tpi set up? how much to ship to 90712?
Old Aug 4, 2009 | 01:02 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
were are u located?,
Old Aug 5, 2009 | 12:24 AM
Axle/Gears: 3.38:1
A great replacement for that tired old 305. get rid of that weenie engine and get a 350!
Old Aug 5, 2009 | 12:32 AM
Axle/Gears: 3.38:1
Checking on the shipping weight/vs cost
Old Aug 6, 2009 | 08:04 PM
Axle/Gears: 3.38:1
on the run stand and it's ALIVE!
Old Aug 7, 2009 | 11:04 AM
Axle/Gears: 3.38:1
No leaks, runs excellent
Old Aug 12, 2009 | 12:28 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
any price on shipping to 75228?
Old Aug 13, 2009 | 06:33 PM
Axle/Gears: 3.38:1
yea, I think I can get it there for $130, 3 days by truck, but I gotta build it a crate first.
Want a pic of it on the run stand?
send me your email
Old Aug 15, 2009 | 11:18 AM
Axle/Gears: 3.38:1
ttt
Old Aug 15, 2009 | 11:42 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
can you send pics to cdempsey13@hotmail.com.
Old Aug 15, 2009 | 07:28 PM
Axle/Gears: 3.38:1
This has TPI cam in it. If you use a throttle body injection, you have to change the cam.
Old Aug 16, 2009 | 01:26 PM
Axle/Gears: 3.38:1
still have the engine for sale.... this would be great to get rid of that 305 and get some real power.
use all your injection, exhaust and serpentine belt system, and sell the old engine block for a couple hundred.
Upgrade to the real 5.7 for less than $400
new info and parts added..........
TPI manifold is sold.
Old Aug 16, 2009 | 02:05 PM
91convertable's Avatar
Car: 88 Iroc-Z Convertible
i live in las vegas . very interested. Can you send me pics to lakersluis@yahoo.com. thanks
Old Aug 17, 2009 | 03:25 PM
Axle/Gears: 3.38:1
ttt
Old Aug 18, 2009 | 09:04 AM
Axle/Gears: 3.38:1
pics available
Old Aug 18, 2009 | 04:04 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Originally Posted by coupeguy2001
pics available
Can you send pics to jaybroncos30@hotmail.com as well as your current asking price for the long block (no intake, etc, just pan to heads)? I would need it shipped, Im located in the Denver area so it seems it wouldnt be too much to get it here. Thanks.
Old Aug 18, 2009 | 05:58 PM
}BlueFire{'s Avatar
Car: 1987 GTA
Transmission: 700R-4
I would like pics also, please send to Reverant_GTP@hotmail.com. If you have the ability to take a video also that would be great. How much would you want shipped to 51106? Thanks
jhawkeye
May 25, 2022 06:33 PM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
