[PA] Various performance parts
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Crane Cams HI-6S CD ignition and coil kit
summit part # CRN-6000-6302 $191.95 (new)
will sell for $100.00
Holley Avenger 52mm throttle body
summit part # HLY-112508 $359.95 (new)
will sell for $200.00
Abbott Cable X (needed to convert electronis speed sensor signal to a mechanical cable driven speedometer) NEVER INSTALLED OR USED
$310.00 (new) will sell for $230.00
LT4 Hot cam (with cam card) less then 2000 mile on it!
Style Hydraulic roller
Operating RPM Range 1,800-5,800 (pulled to 6000 on dyno)
Intake Duration at 050 inch Lift 218
Exhaust Duration at 050 inch Lift 228
Duration at 050 inch Lift 219 int./228 exh.
Advertised Duration 279 int./287 exh.
Valve Lift with Factory Rocker Arm Ratio 0.492 int./0.492 exh. lift
Lobe Separation (degrees) 112
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
will sell for $120.00
1995 LT1 cam 45,000 miles on it
$60.00
1995 LT1 aluminum heads ported to 185cc intake runners
LT4 valve springs, locks, retainers, seals, guides
NEEDS ONE INTAKE VALVE AND GUIDE
will sell for $200.00 (I have a lot more money in the porting and parts)
All parts are slightly used (under 2000 miles) and in new condition with exception for the Cable X (new) and the ported LT1 (needs one valve and guide) and come with all original paperwork and instructions. I ran 11.8 seconds with the ported LT1 heads and LT4 hot cam and 10.63 @ 127 with nitrous.
Serious inquirers please email roeser123@comcast.net for pictures.
$60.00
Car: 1987 firebird
Transmission: 4l60e
Re: Various performance parts
I also have a set of 8 stock 1995 LT1 24lb injectors. These injectors have 45,000 miles on them and work great. Not one of them bleeds off fuel. $100.00
Car: 1987 firebird
Transmission: 4l60e
As of right now the LT4 hot cam is sold, and I am awaiting payment but everything else is still for sale.
Car: 1987 firebird
Transmission: 4l60e
Crane ignition, LT1 cam, Abbot cable X, and Holley 52mm TB still for sale.
LT1Formula
20
Nov 14, 2015 12:02 AM
86IROC112
Aug 17, 2015 02:00 PM
