Holley Stealth Ram -Almost NEW!!
Car: 1988 Trans Am GTA
Transmission: 700r4 rebuild, heavy duty clutch pa
Cleaning out the garage. Never even put this on my car. Bought from another guy here a couple years ago.More to come !!!
Holley Stealth Ram Non Vortec. Includes: Complete manifold with upper plenum powder coated silver and then coated again in clear. Fuel rails with non-adjustable fuel pressure regulator. SVO 24lb injectors. Stainless steel braided fuel line with correct fitting to connect to factory GM F-body fuel lines. CSI billet aluminum waterneck (factory waterneck will not work). All vacuum fittings. 8 ARP intake bolts and 4 Holley bolts with correct angled spacer. Extra Plenum gaskets. All you will need to add is your throttle body, air temp sensor, coolant sensor and throttle cable bracket.
600obo
600obo
Re: Holley Stealth Ram -Almost NEW!!
Not willing to separate at this time. With everything included it is a worry free setup for someone swapping their intake.
Royal_Z
Sep 30, 2015 08:45 PM
