GARAGE SALE - LOTS OF PARTS !!!
Old Oct 10, 2009 | 12:47 AM
RiggsLW81's Avatar
Car: 1987 IROC-Z Camaro
Engine: 350 (5.7L)
Transmission: 700R4 (Auto)
All parts came off of my 1987 IROC 5.7 350 TPI. All are in working condition UNLESS otherwise noted.
- Stock Water Pump (works great, upgraded to an aluminum one) $60
- Tilton Starter (needs rebuild) - $50 (over $400 new!)
- K&N Cone Air Filter (for cold air intake - I upgraded to a bigger one) $25
- Pair of T-Tops (Glass...NOT Lexan): Latch works fine, secures to roof properly. $150
- stock 350 cylinder heads (one in good shape, the other needs to be rebuilt...from an overheating problem last year) $75
- stock TPI Runners/Plenum/Intake/Air Filter base: -$150 for all, *will seperate if needed*
-Stock Fuel Rail w/ 5 injectors attached $50
- stock TPI 350 Throttle Body $50
- Air Foil for Throttle Body $25 (will sell with throttle body..$65 for both)
- stock Parking Lamps (Pair): used, but no cracks $25
- stock Amber Turn Signals (Pair) used, but no cracks $25
OTHER GM PARTS
- stock GM 2 Barrel Carburetor (off 1978 Pontiac): needs rebuilding, $25
- stock GM Intake Manifold w/ 160* thermostat (off 1978 Pontiac): $25
- 14x6 steel wheels (4 of them), all hold air: $20 each, $75 for all 4
- stock GM air cleaner/single snorkel (w/ almost new air filter included): $50
SOLD
- Edelbrock Shorty TES Headers w/ Y-Pipe AND Magnaflow High-Flow Catalytic Converter - both headers is good used shape. no holes, tight seals. Y-Pipe and Magnaflow Cat are almost brand-new..used for less than one month before removal! $350 (All this would cost around $600 new...save some cash!!)*I Have pics!* ***SOLD***
- Toyo Proxes FZ4 Tires - Set of 4 (tread life is around 50% on 3 tires, 75% on 1 - all hold air) Retail for a set of 4 is $450. Asking $150 or Best Offer. ***SOLD***
- Stock TPI dual fans setup (w holder & pigtails.. swapped out for higher flow dual fans) $75 ***SOLD***
- Stock radiator (swapped out for high performance aluminum rad) $60 ***SOLD***
- Edelbrock Y Pipe (for shorty headers..swapped out for different exhaust setup) $50 ***SOLD***
- Flowmaster muffler (3 inch in/out) w angle cut pipes. Also has the over the axle pipe still attached (I believe the muffler is a 40 series or American Thunder muffler.. was on the car when purchased from last owner who didnt remember which one...it is on the louder side FYI...great sound...I swapped out for a newer setup) $125 ***SOLD***
- *BRAND NEW- NEVER USED/MOUNTED* Magnaflow slash cut exhaust tips - 24 inches long, 2.5 in, 3.5 out $85 (retail for $120 from Summit Racing) ***SOLD***
- MSD BTM (Boost Timing Controller): works great. used with my Vortech blower. have no use for it on my current motor. $125 ***SOLD***
- Hollow 3 inch in/out catalytic converter $20 ***SOLD***
PLEASE PM ME IF YOU ARE INTERESTED IN ANY OF THESE PARTS. I AM LOCATED IN NEW JERSEY...ABOUT 15 MIN FROM NYC.
WILL SHIP ALL PARTS - BUYER RESPONSIBLE FOR SHIPPING FEES. LOCAL PICK UP IS OKAY TOO.
Old Oct 10, 2009 | 09:09 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: GARAGE SALE - LOTS OF PARTS !!!
Where in NJ are you located?
Old Oct 10, 2009 | 11:53 AM
RiggsLW81's Avatar
Engine: 350 (5.7L)
located in the Meadowlands area...5 min from Giants Stadium.
interested in any parts?
Old Oct 10, 2009 | 09:42 PM
rick121's Avatar
Car: 91 Camaro RS
Engine: 3.1 liter
Axle/Gears: positrac off an 83 T/A
how much use is on the cat and what are the dimensions of the y-pipe?
Old Oct 10, 2009 | 11:59 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
the cat converter only seen a few thousand miles, the car isnt driven a regular basis..
the y pipe is this exact one:
http://www.summitracing.com/parts/EDL-65930/
Old Oct 11, 2009 | 10:56 AM
Erics88Iroc-Z's Avatar
Car: Toyota Tacoma/1988 Iroc
Engine: 5.7
How much for the heads shiped to 03833
Old Oct 17, 2009 | 03:20 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
there really heavy, about 40lbs each at least. i would think between $50-75 to ship..can get u an exact cost if your serious about purchasing.
Old Oct 18, 2009 | 04:18 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
if youve still got the dual fan setup in november ill be hitting you up, moneys tight til i get my bonus from work
LMK
Old Oct 22, 2009 | 05:18 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
thats fine..1st with cash gets the parts..
when do u anticipate being able to buy them?
Old Nov 6, 2009 | 05:17 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
you email me any pics of the exhaust stuff you got so I can decide to buy or not...
abailey79@hotmail.com
Old Nov 7, 2009 | 01:39 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
does the cat have the A.I.R set up
Old Nov 11, 2009 | 09:43 PM
25th92RS's Avatar
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
Did you sell the cylinder heads yet? They are center bolt style right? they should be anyway if they're from an 87. How much for shipping to 44212??
Old Nov 11, 2009 | 10:17 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
here are answers to the last 3 posts..sorry its taken awhile, been busy..
DrewsCam- I will email you the exhaust pics this weekend.
JMR- No it doesnt have AIR set up, the cat is hollow
25th92RS - Yes, I still have the heads, they are from my original 87 motor. Shipping will be in the neighborhood of $50-ish. Could be abit more, would need to go to post office for exact estimate. Want them?
Old Nov 11, 2009 | 10:29 PM
25th92RS's Avatar
yeah, get me a for sure number on the shipping and I'll see what I can do for ya!
Old Nov 14, 2009 | 12:14 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Shiping the heads to you will be approximately $56, but I'll still ship them to you at $50..I just want the heads gone.
Let me know.
Old Nov 15, 2009 | 01:06 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
got any pics of the exhaust tips?
Old Nov 16, 2009 | 11:35 AM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
I would definatly like the fan setup. The first one with the money right? How much would it be to ship it to 29418 or South Carolina.
Old Nov 24, 2009 | 06:16 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Ownor- the tips look like this- they are brand new & never mounted:
http://www.magnaflow.com/02product/s...e=main&id=8331
GadeXTrigger - the dual fan set-up is yours, shipping there would be approx $15-20. want it?
Old Dec 6, 2009 | 07:21 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
bump...the holidays are just around the corner..treat urself to some quality parts for cheap!
Old Dec 20, 2009 | 07:12 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
bumpity bump
Old Jan 7, 2010 | 08:46 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
someone here needs some cheap parts...
Old Jan 22, 2010 | 03:28 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
TTT ... will take BEST OFFERS on all parts!
Old Jan 25, 2010 | 11:47 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Any pics of the exhaust and would you ship it
Old Jan 27, 2010 | 05:29 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Yes, I have exhaust pics...(I sent you a PM)
Yes, I will ship exhaust, but you pay for shipping, as stated.
Old Feb 15, 2010 | 02:47 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Flowmaster exhaust sold...
Old Feb 15, 2010 | 07:38 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
i wish there was a third gen garage sell in my neighborhood lol
Old Mar 11, 2010 | 03:12 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Spring is around the corner...who needs cheap parts to get up and running?
Old Mar 12, 2010 | 05:35 PM
gwood75's Avatar
Want a title? Post!
Do you still have the fan setup????
Old Mar 14, 2010 | 02:36 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
yes, still have the fans - I sent you an email too.
Old Jul 8, 2010 | 10:57 AM
RiggsLW81's Avatar
Engine: 350 (5.7L)
BUMP...
also updated with more parts for sale!!! check the original post for new items including parking lamps, amber turn signals, MSD ignition, and more !!!
Old Jul 13, 2010 | 02:06 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
TTT
Old Jul 14, 2010 | 07:17 PM
Pat Hall's Avatar
PM sent...
Old Jul 16, 2010 | 12:17 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Can I get a pic of the parking lamps?
Old Jul 19, 2010 | 05:27 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Axle/Gears: 12 bolt 3.73 Eaton posi
pm sent
Old Jul 28, 2010 | 10:44 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
zacheryhorn- will get you pics of the parking lamps this weekend..
Old Jul 28, 2010 | 10:54 PM
likeyoumeanit's Avatar
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
price shipped to 17601 for the 6al and the intake manifold?
Old Jul 28, 2010 | 10:55 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
do you still have spark plug wires
Old Jul 29, 2010 | 09:45 AM
Car: 1987 IROC-Z
You never answered my pm about the cat ad the plug wires.
Old Aug 10, 2010 | 12:19 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
The items are $150...shipping will be (approximately) $50 (intake is really heavy)... so $200 shipped for everything.
to those interested in MSD plug wires, they are no longer being sold. sorry.
ZACHERYHORN - please PM your email address. I have pics of parking lamps you requested to send to you...
RACING GEEK - you have a PM
Old Aug 24, 2010 | 08:45 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
bump
Old Aug 30, 2010 | 06:33 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
dual fans have been sold
Old Oct 29, 2010 | 12:20 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
TTT...Edelbrock Headers w/ Y-Pipe a & Magnaflow High-Flow Cataytic Converter added to list!
Old Nov 6, 2010 | 11:47 AM
RiggsLW81's Avatar
Engine: 350 (5.7L)
BUMP
Old Nov 24, 2010 | 02:03 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
TTT..who needs complete headers w Y-pipe & cat ???
Old Dec 7, 2010 | 03:29 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
the holidays are here...all parts are BEST OFFER ACCEPTED!
Old Dec 8, 2010 | 05:54 AM
ownor's Avatar
Engine: LS1 / L03
Hi there, i'm interested in the 3 items in the quote. what exact BTM box is this? if you have any pics of the parking lamps and turn signals that'd be cool, too.
Thx
ownor
Old Dec 9, 2010 | 12:49 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Hi Ownor - The MSD Box looks lke any other MSD box, red in appearance, it has the Vortech Supercharger logo on it, and says Ignition & Boost Controller on it. wires/hooks up come with it...im even throwing in the MSD Boost Retard **** w/ wires.
I have pics of the parking lamps if you want to see, the amber turn signals are stock, they look like every other camaro turn signals - no different. PM me your email for pics.
the exhaust tips are brand new as well...
do you want to purchase these items? let me know
Old Dec 9, 2010 | 02:56 PM
ownor's Avatar
Engine: LS1 / L03
ok i didn't notice the lamps were for a camaro, i can't use them in this case, sorry.
for the msd box, does it say MSD 6 BTM CD or something similar on it? and the **** is normally included anyways
i might consider the tips if we get a deal for the BTM box.
thanks for the infos.
l8rs
Old Dec 9, 2010 | 04:07 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
sent you a private email Ownor. (and I have seen the box and **** sold seperately on different f-body sites & ebay..thats why I said I'm including it for free with the box purchase)
please get back to me at your convenience. thank you.
Old Dec 13, 2010 | 04:49 AM
ownor's Avatar
Engine: LS1 / L03
for anyone interested in the vortech MSD BTM, this link might be interesting.
according to this and other sources, the Vortech version does only retard timing, but doesn't make use of MSD's CD ignition system!
