[PA] Parting out 1991 Z-28
Old Oct 24, 2009 | 05:24 PM
dpmalibu's Avatar
I am parting out a 1991 Z-28. it has a 350 TPI crate motor w/ approx. 20k miles on it. It also has a Rebuilt 700 R4 trans w/ shift kit and new converter w/ 59k miles(have reciept). Motor is stock. No smoke and runs exc. It also has a new ECM. Wiring harness is intact. It als has an A/C delete pulley on it. Car also has has new Flowmaster 3" cat back exhaust w/ chrome 3" tips. I believe the whole exhaust including the tailpipes are 3" (which is unusual). The exhaust is in exc. condition other than the pass side chrome tip was flattened due to the car was hit in the pass side rear/ 1/4 panel. The exhaust was not affected other than the tip was damaged. car also has a new fuel pump and a mini starter.
Prices are the following:
Complete motor w/ entire TPI set up includes: motor from intake to pan,wiring harness, fuel pump, ECM etc. $1000 B/O
Long block w/o TPI set up $600
TPI set up $400
Trans w/ converter $400
Exhaust $150
Located in Hatboro,Pa
Old Oct 24, 2009 | 08:11 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: [PA] Parting out 1991 Z-28
is the gauge cluster for sale?
Old Oct 24, 2009 | 08:19 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
will u sell thel maf sensor alone?
dpmalibu's Avatar
Yes it is for sale .Everthing works except for the tach is not accurate. Asking $40 for it. If you want to see pics go the the Interior parts for sale section.
Old Oct 24, 2009 | 08:21 PM
dpmalibu's Avatar
i do have an extra one I will sell but for now I'd like to keep the whole TPI set up together at least until the motor. If you are interested in the extra one let me know and I'll send you some pics.
Old Oct 28, 2009 | 05:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
DOes the cluster have the 150MPH speedo?
Oh and this car does NOT have a MAF sensor. It is a speed density car
Old Oct 28, 2009 | 07:25 PM
dpmalibu's Avatar
Okay thanks for the heads up. Also it does not have a 150 mph speedometer
Old Nov 1, 2009 | 07:24 PM
dpmalibu's Avatar
All drive train parts sold other than the driveshaft and rear.
Still have the steering box ,radiator, dual fans and steering column
Old Nov 3, 2009 | 09:08 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
i saw this on craigslist, u emailed me back and i never got back to you cause ive been busy, the drivetrain is sold now? you got a 4 wheel disc brake prop valve from that by any chance?? how much for the dual fans?
Old Nov 4, 2009 | 03:13 PM
dpmalibu's Avatar
no disc brake prop valve. $50 for the fans.
Old Nov 4, 2009 | 03:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Which type calipers on the rear?
Old Feb 16, 2010 | 03:54 PM
89badass's Avatar
Car: 1989 CAMARO RS
Engine: 5.7 TPI
Transmission: 700R
Axle/Gears: ???
do you still have the extra maf sensor?
Old Feb 16, 2010 | 05:50 PM
eagle's Avatar
need chin spolier...how much
Old Feb 16, 2010 | 06:35 PM
dpmalibu's Avatar
MAF sensor is long long. No chin spoiler either
Old Feb 17, 2010 | 03:05 PM
chevyspence's Avatar
Car: 84 z28 CMC1 spec
Engine: L69
Transmission: BW T5
Axle/Gears: 3.45 9bolt
If the rear end is still available could you provide some details? I assume its a 10 bolt, but is it Disc/Drum, posi, gear ratio? And hopefully it survived the crash! Thanks
Old Feb 17, 2010 | 07:37 PM
dpmalibu's Avatar
sold it
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
