waste of a car 89 iroc 67k 350 tpi auto hardtop
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a waste of an 89 iroc with 67k miles on it, 350 tpi, auto, hardtop
9-bolt disc posi, black interior, car was hit in the front but not repaired correctly, half assed back together, never had the frame pulled, just cut and screwed back together, intake sprayed silver, fuel rail painted red, its just a mess, security light is on now so i cant start it and drive it anymore,
complete car for parts
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: waste of a car 89 iroc 67k 350 tpi auto hardtop
Are you parting it out or selling it as a whole? If you part it I would be interested in some black interior parts if they are decent. Thanks
Transmission: auto
complete car is for parts,
norcalz28 , all of the plastic are there it does have the option for the carpet on the panels, only parts that are damaged is the one screw hole on the rear headliner plastic and the door sill for both sides are cracked,
TheJoeY88, looking the sell the 9-bolt rear complete with the pbr brakes
yeah i would want to get everything needed to change my rear drum car to a rear disk car, like the whole rear with brakes, calipers, ebrake cables, ect
pics would be great. alpha283@yahoo.com. mostly interested in trim for the doors and things like that, Thanks!
Transmission: auto
TheJoeY88, ok so your cvar is a drum rear and you want everything to make it a disc rear, i cam provide everything to due that, prop-valve, rear end with the brakes, brake lines and parking brake cables, looking to get $600 will check the ratio but it should be 327
norcalz28, will take some pics and send them to you asap
much appreciated, also interested in the door triangle seals/window guide apparatus at the front of the doors, interested in both. Thanks
Will
Will
How is the engine harness? any cuts or hacked up harness or connectors? what about the ecm. Do you have the rear cover that rolls out and attaches in the trunk? what color if so. and prices. maybe some pics. pics sell..
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Transmission: auto
norcalz28, will check out the window seals and door triangle seals and let you know,
jtisdale23, harness is not cut, ecm is still there yes it has the rear cargo cover in a black vinal type material need e-mail address to send you some pics,
juanillox8, really looking to part it out dont want someone to fix it, pm with an offer i would concider selling it whole, but only if its going to be parted out
Transmission: auto
norcalz28, door seals are shot cracked and dryed out. door triangle seals look ok, also reply back to e-mail so i can send you some pic's
88TATBI5.7, hows $150 plus shipping
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Are the runners is decient shape? I need a set of 89' runners that aren't all smashed.
If they are good, send me a few pics to me please, and shipping to 78410.
Transmission: auto
powerslave, runners are good, here is my e-mail address e-mail me so i can send you pics,,, wtg3575@aol.com
Car: 88 TA
Engine: TBI 5.7
sounds like a fair price. mine just doesnt run right anymore so i think the ecm or prom is shot. so with shipping to 06478. think you could throw in the Electronic Spark Control Module? little box near the brake booster. im going to look over my car and see if there is anything else i need.
Transmission: auto
88TATBI5.7, will give you that spark module also, e-mail at wtg3575@aol.com
with your address so i can figure out the shipping
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
Transmission: auto
89RSTBI, would have worked but the column is all apart now, the wires are broken off the back of the cycliner for the key, so it will need a new one
Transmission: auto
sorry thery were not there when i got the car
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
dash pad condition? and looking for a black centerconsole with holes for power windows. lmk pricing shipped to 63385 thanks
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
I need the rear speaker sail panels. Are the 89 clips the same as the 84's?
Also, i need the engine side motor mounts so i can swap the 350 in. So if the motor goes, i'd like the mounts.
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
how much for the 350 and auto setup with ecu and wiring ?
Transmission: auto
resop27, dash pad has a crack, but its not your normal cracked spot, i hit it when i was trying to load the dash pad into my garage, its got a 3/4 split almost dead center on top where the 2 centervents are on the dash can get you pic if interested, are you looking for only the top plate or the complete console,
MrPhotographer0, are you loooking for the carpeted panels that cover up the speakers? are you looing for the bracket on the engine or the mount thats on the k-frame or both of those parts?
lopezisgod, sorry but the engine is sold, still thae the tpi set-up, ecu, wiring and trans
Hi, I need the harness that plugs into the drivers side firewall below the wiper motor for all the accessories. I have an 89 iroc, the guy went from tpi to carb and cut every wire out of the engine bay. thanks
Transmission: auto
montecarlossman, the wiper motor plugs into the tpi harness, and the body harness, does all of the lights and horns, and there is a third smaller harness the has a vacume line and some wires for the cruse control,
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
hey ted any chance I can get pics of your NOS 91-92 gta taillights now? Are you feeling better yet?
justintiime@gmail.com for pics
Engine: 355 chev
Ted, i'm looking for the engine side motor mounts. I'm going to move my mounts on the K member up to fit the SBC, but i dont have the motor side mounts.
So i need the Engine mounting cups that bolt to the block, and yes the carpeted panels are what i was talking about
Alright, if you still have the full harness available shoot me an asking price. thanks
Transmission: auto
Justin89Formy, you will have your pics today,
MrPhotographer0, ok i have the mounts and bolts hows $20 plus shipping, i have that speaker panel cover but waht color are you looking for,
montecarlossman, just need some info from you,also is your car serp as in 1 belt or v-belt as in 3 belts, is the car staying carbed? or are you going to swap it back to tpi, if its staying carb i might be able to help with a cheeper harness either way your still gong to modify them for carb,
Its definitely going back to tuned port injection or else I wouldn't be looking lol. I cant stand it when people swap to carb. I'm going to put a 5.7L L98 back down in the car like it was suppose to be and yes it will be the serpentine pulley setup
Transmission: auto
ok will let you know on the harness and ecm, there was someone who asked first,
Car: 89 formula 350
hey ted im STILL waiting on pics of your NOS 91-92 gta taillights after like a month. Do you actually have these parts for sale or what? For a $1200 asking price I'd figure I could at least get some pictures sent to justintiime@gmail.com
Transmission: auto
Justin89Formy, i know its kinda hard to part with them but i will due what i said and get you the pics later today, as a matter of fact i will take them outside and unbox them and take the pics right now,
Transmission: auto
montecarlossman, sorry but i have a paypal e-check on hold for the wiring harness and computer, was waiting for it to clear, sorry for the delay,
Foster382, this car has the del cat set up, is that what your looking for
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
How much for the master cylinder and parking brake cables?
How do I make sure that my car has the pbr brakes?
Transmission: auto
Red87SC, i have the mc, but the parking brake cables went with the rear,
earler rear have 2 cast steel rear calipers one one sits on the front of the rear axle on the passangerside, later style rear calipers are aluminum and both sit on the back side of the axle,
Car: 1991 Formula
Engine: 350TBI
So it's just a straight pipe from the Y-pipe to the muffler? If it fits on the stock flanges give me a price.
Car: 87 Trans am
I honestly don't know which brakes I have.
I have an adjustible proportioning valve on the car now and its cranked almost all the way but the rear brakes aren't biting very hard. Probably need the mc from a disc brake car right?
Transmission: auto
Foster382, there were 2 differnty style exhaust systems one with duel cats and with a single cat, what due you have under your car first,
Red87SC, i dont know what to tell you i dont know whats been done to the car in order to help
Transmission: auto
yes i have one
looking for a 89 tpi throttle body still have one and how much shipped to 76182 also can you send pics of it to dek1285@yahoo.com
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i need ecm prom and harness. how much shipped to 63368. swapping from tbi to tpi. o and if you got air box. dont need intake going stealth ram
Transmission: auto
lowridetractor, yes i have the duel fans, upper and lower mounts and the wire harness to the fans
dek1285, yes i still have it,
josh006, sorry the harness and computer has been sold, but i due have an air box
