Grant Red/Black steering wheel and 90-92 install kit brand new, will fit 82-92
title says, will work with 82-92 camaros but for 90-92 you need to trim the horn ring which i did ( so if you use it on pre 90 they'll be a gap)
Never ran, never used. just installed both brand new. ready to be mounted!
65 shipped
65 shipped
Car: 1986 Chevrolet Camaro
Engine: 2.8L V6 soon to be 3.4
Transmission: 700R4 soon to be WC t5
Re: Grant Red/Black steering wheel and 90-92 install kit brand new, will fit 82-92
Does this need a Grant installation kit? Also, the gap you're talking about, is it between where the steering wheel is mounted to the column?
It includes a grant installation kit. Tee gap im talking black ring you see, its about 3mm grinded from what you receive it as new from grant( because 90-92 has the air bag module so we need it a lil shorter), so the gap will be larger at the collar of the steering column.
but other then that, this steering wheel is ready to go.
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
What type of grant steering wheel is that, like the model number?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have the same wheel in my Formula,
If you still have this in a couple of weeks, I may grab it from you to replace mine that has sun faded.
Are you looking for any trades?
Ha, not unless you have any 46-47-48 Chrysler mopar parts, or a 1/10th scale Velineon Brushless ESC and motor for my RC car
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
PM'd ya!
Money Sent.
hectre13
12-11-2023 08:14 AM
