[Sold] Gone
Car: 1991 Camaro Z28
Engine: 6.2L LS3 to come
Transmission: 4L60E LVL2 700rwhp
Gone
THREAD ENDED
Re: 91 CAMARO PART OUT OWENSBORO, KY
I'd let it go for $150 cash. No lower at the moment. Also I can't promise it will run smoothly as it has sat inside the shop for a good bit and I only drove the car for a little amount of time before it was pulled, it seems fine at the time it was pulled though. Just being honest.
Car: 92RS
Engine: LS 402 inwork
Axle/Gears: 10 bolt,3:73's
what color are the arm rests? if they are black, when you are ready to ship, i want them.
Will do
Alright, just let me know.
Car: 92RS
i will have to pass on the grey armrests. I headed in the black direction. Thanks for getting back quickly
Car: 92RS
Door panels. are they both in the same shape as the one pictured? If so i will take them both. Do you have the black pieces that go on the tops of them?
Thanks,
Ethan Hodskins
Re: 91 CAMARO PART OUT OWENSBORO, KY - UPDATED
Post removed, part sold
Car: 91 Z28
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
you sold the front chin spoiler? If not was wondering if you could sell me the brackets that hold it onto the front lower fenders or take a picture of them installed so i could see how they look and work... plz... thnx
Car: 91 Z28
they are essentially a piece of aluminum, with 2 studs on either end. you sandwich the front fender tab and the rubber nose tab between the bracket and the 10mm nut they use for those studs. so essentially, you put it on the inside of the rubber nose, so the studs point towards the wheels,through the appropriate holes, then put them through the designated holes on the fender, and put the nut on accordingly...
Car: 91 Z28
or wait, i'm sorry... i thought you were talking about the nose... *DURR* i think they are just a piece of rubber that is part of the spoiler, and they just slide into the 2 slits in the fender, and then you put a retainer in the tab through the inner fender, the fender, and the spoiler
Car: 91 Z28
i don't recall what size they are... check online... you should only need 2 of them if you're mounting the spoiler... one for each end... is there a hole in the spoiler itself? where it would mount to the inside of the fender? if there is, there should be a hole in the inner fender... it all comes together... it's usually one of the not reusable clips... i believe they mount half of the inner fender to the fender itself... i don't have any though... sorry my friend
I've read the descriptions and I still have no idea what you're wanting. Maybe someone could produce some pictures. Sorry...
WHEELS ARE GONE. Tradeda friend for some Iroc wheels, pictures coming soon.
WHEELS ARE GONE. Traded a friend for some iroc wheels, pictures coming soon.
Here are the new wheels. $200 obo. Tires are good, wheels look great with the exception of the missing center caps.
Car: 1991 Z28
Engine: 355 TPI
front chin spoiler... (piece under the face) has retaining / mounting clips on each side inside the bottom of the fender... if you remove the piece to sell it you may understand what i'm getting at .... 4 tabs slide through the bottom slots of the fenders and then clips hold them in place... i need the mounting hardware clips... there should be 4.. 2 per side.
HOOD AND TAILLIGHT COVERS ARE BACK UP FOR GRABS
Will take $80 for the high rise spoiler and $225 for the hood.
Car: 83 T.A L69 T5 WS6
Engine: L69 5.0 H.O
Transmission: T5 5 SPEED
Axle/Gears: 3.73 POSI TRAC
will the floor pans fit a 83 bird. and is there any rust. can you get pics..
MOST PARTS ARE GONE!
Still have the hood, arm rest, pad that goes under steering column for shipping
305TPI, 700R4, and Iroc Wheels for pick up.
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I'm trying to get it together to get up there
From: Home is La Joya Texas- right now Qatar Sand Box
Car: 91 Formula, 91 RS/SS, & 95 Cobra
Engine: TPI 305, LS1, & 5.0
Transmission: 700r4, 4l60e, & 4spd auto
Axle/Gears: 3.73, 3.73, & 3.73
200 for hood shipped pm me cash in hand
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I am looking for a few TPI parts. Check out this link and let me know if you have any in the condition I want and if you're willing to sell:
https://www.thirdgen.org/forums/sout...restoring.html
I am also looking for a tire inflator and tire inflator bolt holder:
https://www.thirdgen.org/forums/inte...-inflator.html
Thanks.
Andy
Thanks.
Andy
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Do you still have the Iroc rims and tires? If so would you ship to 70037? Also, do you still have the seat belts? What color and what shape? Full set?
I'm in Owensboro, Ky.
