[PA] Borg Warner 9 bolt posi rear disc brakes w/ 3.27 gears
This rear came out of an 88 T/A w/ approx. 70k miles on it. All brake components has been replaced within the last year or so. I also have the master cylinder and proportioning valve for those who are converting from drum to disc brakes.. Gear ratio is 3.27
Asking $400 B/O
located in Hatboro,Pa
Asking $400 B/O
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
Re: [PA] Borg Warner 9 bolt posi rear disc brakes w/ 3.27 gears
Interested - do you have any pics? I'm also interested in the valve if you still have that as well
Car: 1991 GTA Trans Am
Engine: TPI
Transmission: T-5 World Class
Axle/Gears: 10 Bolt 3:45
Extreemely interested and I'm some what local... (My car had drums and a open dif) It's a direct bolt in with the master cylinder and proportioning valve?
Yes it is a direct bolt in. Like I said I have the necessary parts to make it happen. I have someone coming tomorrow to look at it. So I'll have to let you know what happens.
