[IL] Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors
Old Nov 17, 2010 | 01:54 PM
nes_t_383's Avatar
All parts are located on the Northwest side of Chicago, IL 60656. You are more than welcome to personally pick them up to save on shipping costs. Please let me know your address for shipping quotes,. No longer have a thirdgen and have no further need for this stuff. For feedback purposes, my ebay screen name is nes-t-1 and my name on LS1tech.com is 98_LS1. I only accept paypal and I do NOT charge you extra for the fees!!
Here are the items I currently have for sale:
Total Seal MaxSeal Piston Rings for 4.030” bore, p/n M3690-35
Brand new in the box, taken out for photos. Features premium ductile iron gapless top rings, conventional second rings, and standard-tension oil rings. Gaps open as standard piston rings wear, allowing more combustion gases to escape (blow-by). Gapless rings solve this problem with two-part interlocking rings to close gaps and to improve piston-cylinder seals. As gapless rings wear, gaps stay sealed. Total Seal Maxseal ring sets are ideal for street, race, mild nitrous, and mild forced induction applications.
Specs:
Bore (in): 4.030 in.
Bore (mm):102.489mm
Top Ring Included: Yes
Top Ring Thickness:1/16 in.
Second Ring Included: Yes
Second Ring Thickness:1/16 in.
Oil Ring Included: Yes
Oil Ring Thickness: 3/16 in.
Oil Ring Tension: Standard
Oil Ring Tension Rating: 20 lb.
File Fit:Yes
Gapless:Yes
Top Ring Material: Ductile iron
Top Ring Facing Material: Ductile iron
Second Ring Material: Cast iron
Second Ring Facing Material: Cast iron
Oil Ring Material: Stainless
$225 + shipping
Used hydraulic roller camshaft, SLP 51000. Specs are 206/212 duration @ .050. .480/.487 lift with 1.5 rockers. 112 lsa. Made tons of torque down low. Lobes look great! Used for about 3,500 miles, ex cellent condition. $125 + shipping SOLD!!!
Hotchkis Sport Suspension Weld-On Subframe Connectors, p/n 4001. Black powdercoat. New, never installed. Some minor scratches from just sitting around. For third generation camaros and firebirds. Will not fit convertibles.
$125, local pick up in Chicago only, will NOT ship. SOLD!!!
Cloyes Double Roller timing set, p/n SA314S
Brand new in box, never used. High Performance set. SBC 86-up w/ factory roller cams.
$50 + shipping SOLD!!!
Auto Meter Single Gauge Pod p/n 10201
Brand new in box, never used. Fits 2 1/16 in. diameter gauge. Fits 1982-1992 Camaro/Firebird.
$15 + shipping
Milodon Diamond Screen Windage Tray for SBC, p/n 32250
Brand new in the packaging, never used.
Milodon's exclusive Diamond Stripper design features hundreds and hundreds of small louvers that quickly scavenge oil from crankshaft rotation, but prevents reversion common to screen-type windage trays. They are completely finished, gold irridited, and require no additional fitting for installation. Extensive dynometer and on-track testing verifies that these windage trays out-perform other screen type trays on the market. They permit rapid oil return and protection from oil splash-back, while providing increased power by reducing windage.
$75 + shipping
Used Lakewood Lower Control Arms, p/n20140
Polyurethane bushings, black powdercoated, missing some of the grease fittings. Fits 82-02 Camaros and Firebirds.
$40 + shipping SOLD!!!
Used BMR Adjustable Chrome Moly Panhard Bar, p/n MPHR002H
Polyurethane bushings, Black hammertone powdercoated, made out of strong but light chrome moly, adjustable “on-car”. Had on car for literally 100 miles, perfect condition.
$110, picked up in Chicago, do not want to ship. SOLD!!!
Competition Products SBC 4130 Hardened Racing PushRods, p/n 1400
5/16 diameter STD, 7.800” length, 4130 Seamless one-piece heat-treated tubing , Aircraft Chrome Moly, .075” wall. Pressed tips. For use to 7000 rpm. Set of 16.
$40 + shipping
Used Bosch fuel injectors, p/n 280 150 759
These are the stock injectors out of my 1989 Pontiac TransAm GTA 5.7L, TPI, ~70,000 miles on these. Nothing wrong with them when removed, worked flawlessly, replaced w/ some bigger Accels when I changed motors. Comes w/ the installed o-rings.
$50 + shipping
Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-001.jpg
Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-002.jpg
Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-003.jpg
Old Nov 17, 2010 | 01:55 PM
nes_t_383's Avatar
Re: Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injec
more pics
Attached Thumbnails Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-004.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-005.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-006.jpg
nes_t_383's Avatar
pics cont.
Attached Thumbnails Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-007.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-008.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-009.jpg
Old Nov 17, 2010 | 01:57 PM
nes_t_383's Avatar
pics
Attached Thumbnails Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-010.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-011.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-012.jpg
Old Nov 17, 2010 | 01:58 PM
nes_t_383's Avatar
still more pics
Attached Thumbnails Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-013.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-014.jpg   Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-015.jpg
nes_t_383's Avatar
one more pic
Attached Thumbnails Total Seal rings, SLP cam, Suspension, Dbl Timing set, Pushrods, Gauge pod, Injectors-pics-016.jpg
Old Nov 21, 2010 | 08:45 PM
nes_t_383's Avatar
sfc's, lca's, and panhard bar all sold! Everything else still for sale!!
Old Nov 22, 2010 | 10:39 PM
native1031's Avatar
Is it complete suspension?
Old Nov 22, 2010 | 11:47 PM
nes_t_383's Avatar
all of the suspension is sold except for a set of lower control arm relocation brackets.
Old Nov 24, 2010 | 05:51 PM
nes_t_383's Avatar
cam, timing set, and pushrods are pending sale
Old Nov 25, 2010 | 11:35 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Interested in the timing set if it falls through.
Old Nov 25, 2010 | 10:05 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
find out how much the injectors would cost shiped to 38220.I could use a back up set for my 89 iroc if they would work,and I think they should
Old Nov 26, 2010 | 09:28 AM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
Ill take the injectors if you wouldn't mind meeting me halfway. Im at 60930.
Also is the timing set a Hex-Adjust set?
Old Nov 26, 2010 | 10:48 AM
nes_t_383's Avatar
cam and timing set are sold!
Old Nov 26, 2010 | 11:23 AM
nes_t_383's Avatar
pm sent
Old Nov 26, 2010 | 11:28 AM
nes_t_383's Avatar
pm sent on the injectors, timing set is already sold
Old Dec 5, 2010 | 07:56 PM
nes_t_383's Avatar
rings, injectors, gauge pod, windage tray, and push rods are still available for sale!!!
Old Feb 17, 2011 | 02:43 PM
TheNewStyle's Avatar
Car: '88 Formula
Axle/Gears: Stock
Any chance you can help me solve a pushrod problem and maybe I can buys yours?? Stock 350TPI with 083 heads that have screw in studs, non aligning rockers, guide plates, heavy duty valves and springs, 3-angle valve job. Just a napa head gasket... Help??
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
