[IL] holley c950w/wideband...24#svo injectors
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
commander comes with wiring harness, manual, cd, and wideband upgrade.. like new with under 5k miles... SOLD
comp pro mag roller rockers 1.6-7/16 less than 5k miles.....SOLD
55# deika injectors..low impedance....$150 shipped
full exhaust .. SOLD..
emp stewart stage 2 aluminum water pump(reverse flow)7k miles,,only pulled because new pulley setup uses clockwise w/p $75 shipped..
36mm hollow swaybar &brackets..$50 picked up
24mm rear swaybar brackets....$30 picked up
Intrax 2" lowering springs.....SOLD
shipping to the lower 48 only
more to come
more to come
Car: 87 GTA
Engine: 385 sbc
Re: holley c950w/wideband...24#svo injectors
work has been crazy....... all pms replied too, tomorrow Ill get pics of more of the stuff
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
PM'ed
Car: 87 GTA
Engine: 385 sbc
fyi for everyone, the exhaust is being sold as a pickup only and the y pipe is custom made for the headman headers.... the headers have a 02 bung at the collector for a wideband and there hedman, the catback is a hooker with the aerochamber muffler...425 for the full exhaust
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Are the rockers self aligning?
Actually these I can use these.
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
what are the ohm on the injectors?
Car: 87 GTA
Engine: 385 sbc
also have a set of 55# siemens deika injectors...$200 shipped
$775 shipped for the holley dfi
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
still have the rocker arms (comp pro mag 1.6 7/16)
looking at a few things in this add has well
Car: 87 GTA
Engine: 385 sbc
Car: 87 GTA
Engine: 385 sbc
willing to trade or partial trade for suspension parts,,,, not interested in stock parts and I already have springs, shocks and struts and brakes..... looking for adjustable torque arms, lcarb, tubular kmembers, rear control arms, front control arms(well anything tubular
)... Supreme Member
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Hey Sean its Carlos. Did you end up using the exhaust? Still have it? I might be interested in it for next week if no damm exhaust shop can do a decent job in merging my y pipe into a 3in for my Hookers.
Car: 87 GTA
Engine: 385 sbc
I still have the exhaust,,, lmk what you want to do... sorry Im not going to split the exhaust(all or nothing) and no I dont think it will mount to stock exhaust
Car: 87 GTA
Engine: 385 sbc
exhaust pending....
I also have a summit fuel pressure guage(screws into fuel rail)$10 +shipping
holley stealth ram adj. fuel pressure regulator $25 + shipping
I thought it was bad so I bought a kirban fpr but it turned out my fuel pump was causing my fuel pressure to drop once I shut off the engine..
Car: 87 GTA
Engine: 385 sbc
LOWERED PRICE......$650 shipped for the holley commander,
Car: C4 Corvette
Engine: l-98
Car: 87 GTA
Engine: 385 sbc
Car: C4 Corvette
Engine: l-98
It shouldn't be that much via USPS. If everything will fit into large flat rate box (8 pistons fit in there) it should be arround $55.
Try to check this out:
http://ircalc.usps.gov/MailServices....&p=0&o=1&mt=11
I could go as high as $700 shpped.
Car: 87 GTA
Engine: 385 sbc
Car: C4 Corvette
Engine: l-98
I didn't get any anwser about 950. If shipping is a problem, I could find someone in US for you to ship to, and he can forward it to me. But I'm sure that you could ship it for $60 max.
...... the rocker arms and holley are both still available
