[VA] parting 88 rs
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
parting 88 rs
i bought a 88 rs for some parts to help put my car back together and im going to part whats left which will be everything minus the rearend suspension front k member and carpet/panels. let me know what you need! car will be striped in a week or two and the shell scraped anything that can unbolt will be removed and sold. have a 145 cluster!
Re: parting 88 rs
which piece do you need exactly? can you find me a picture of what you need? if its a interior plastic panel all i have are red peices.
Re: parting 88 rs
i have a red one that was sprayed black at one time and i may have a grey one also ill have to look.
Re: parting 88 rs
yes i believe it is flame red. if you want pm me or email me so i can email you pictures from my phone and ill go get some to send.
Guest
Posts: n/a
Re: parting 88 rs
xxjoshxx09@yahoo.com Send as many of those back panels as possible. I lost mine which is kinda crazy to say. Can you get the pics right now for me if you can Put them on here to make it easier or to my email whatever works best ill stay on right here and wait for you thanks.
Re: parting 88 rs
lol yeah ill get them i gotta ride over to my moms house ill only be like 20mins or so.
Car: 1984 Camaro Z28
Re: parting 88 rs
hello im wondering if you still have the headlight switch i have a 1988 rs camaro too and im guessing my switch is bad because i cannot get my low beams to work at all! the high beams work when the switch is all the way out but when i press the switch back one only the DRLS come on not the headlights its really annoying when i have to drive some where at night and i am blinding every driver with my lights haha also would you happen to the brake light switch that goes under the brake pedal i think mine is missing because i get no brake lights only the spoiler light ohh i also need a new spoiler light too its burnt out only one bulb lights up in it and its sealed closed
Guest
Posts: n/a
Re: parting 88 rs
Sounds like bad wire or short? Also check your fuse.
Re: parting 88 rs
i checked the fuses a while back all fuses are good i also had a problem with the signals i replace the signal bulb today and the signal finally worked no brake light :'(
Guest
Posts: n/a
Re: parting 88 rs
when i mean low beams new headlights? te problem i had with my third brake light was the bulb I had like 5 things i didn't know that lite up until i explored and took everything apart. Put all new bulbs and fuses and they all work now. Look great.
Re: parting 88 rs
no i haven't yet because where i live its too cold most days until it hits the spring i live in penticton i will have to get new bulbs do you know if the lights are sealed or non sealed bulbs im not too sure atm
Guest
Posts: n/a
Re: parting 88 rs
Yes they are sealed. If there stock and it is freezeing out i jsut did a tune up on a escalade today.. In my garge with no heater or anything. My hands are frozen and cracked.
Low beams are sealed and the other bulbs aren't the third brake light tends to get loose and falls out and jingles around. I was like what the f*** is that noise. it was so annoying i puled over took it off it was the broken bulbs jingling all over. replaced it made sure it stayed in. Car is nice in quiet and im always working out in the cold. it's negative -18 where i am right now in ny.
But get all new bulbs replace low beams. If not that then it is wiring short or somthing.
I still haven't got to fix my horn which is annoying me. But sick of this weather.
Re: parting 88 rs
$100obo just throwin numbers out there just looking around seein what they go for average.
Re: parting 88 rs
aww i should off picked up the headlights from my local pick n pull even though there wasn't much there also screamin86 does the trunk and the hood supports work?
Re: parting 88 rs
i believe so but i cant say for sure till i have the car at the house to look it over a little better. like i said the car will not be at my house till at the earliest tuesday and i work 2nd shift 12hrs a day so whatever i can remove in the mornings and between watching my 2yr old may be limited till the weekend.
Re: parting 88 rs
yeah not trying to make money just what i have in the car and help some others out at the rate stuff is going it will not be long.
Re: parting 88 rs
nice if you could hold those for me then i could get some money some how maybe sell somethings i have laying around for some cash
Re: parting 88 rs
i dont want to be ripped off though please they need to be able to hold up my hold and trunk please be honest mine dont hold and one of these days the hood is going to fall on me
Re: parting 88 rs
The seats are black but have a good amount of ware on front ones but I can't remember if the rear is split or not.
Re: parting 88 rs
she car should be at my place wednesday and ill be able to check the seats out and whatever else. also here is a pic of the car with the rear hatch up to show they work.
p.s looks like the rear seat is solid.
Re: parting 88 rs
alright just so everyone knows i havent forgot i just wanted to let yall know that we had abiut 8in of snow wednesday and the car is on a hill in a field and saturday it got into the 50s and well as you can guess its a mud pit right now and until the ground frezzes or dries up i cant get it down to the road without tearing it up or someone getting a tractor stuck.
Re: parting 88 rs
Is it a ttop car? I have a 90 rs, it has ttops and is missing everything that goes on the ceiling around the glass, It was ripped out I assume due to the fact that they leak and ruined the headliner. Do you have an intact ceiling including the overhead light cover, headliner or plastic moulding? Preferably red moulding
Re: parting 88 rs
I will have to find a way to test the hatch motor and I believe the dash pad is cracked up. Yes it is a t-top car but has black interior but my trans am had red interior and is a t-top car and ill be using all the black panels from this camaro for my car.
Re: parting 88 rs
they should be black but all of the interior minus the dash and console an seats are going into my car.
