[MI] -TPI Intake and SBC parts-
Old Feb 10, 2011 | 05:05 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
Transmission: borg warner t-5
My parts inventory has spiraled out of control so its time to sell some of this stuff.
-1985 TPI intake (9th injector) $100 includes shipping up to $20 - SOLD
-Firebird/Trans Am TPI air intake tube ( I have 2) $15 Shipped each - SOLD
-Accel HEI Super Coil (PN: 140003) $20 Shipped - SOLD
Attached Thumbnails -TPI Intake and SBC parts--tpi-intake_-9th-injector   -TPI Intake and SBC parts--tpi-ta-air-intake.jpg   -TPI Intake and SBC parts--accel-coil.jpg
Old Feb 10, 2011 | 05:18 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
Re: -TPI Intake and SBC parts-
- SBC Gear Reduction Starter - DAMAGED DRIVE GEAR - caused the starter to grind on the flexplate every once in a while, but it still works, you may be able to replace the drive gear. $20 shipped
- Set of SBC V-Belt pulleys (Crank, Water pump, Alternator) $15 Shipped - SOLD
- Alternator (worked the last time it was used) $15 Shipped
Attached Thumbnails -TPI Intake and SBC parts--sbc-gear-reduction-starter.jpg   -TPI Intake and SBC parts--sbc-v-belt-pulleys.jpg   -TPI Intake and SBC parts--v-belt-alternator_1.jpg
Old Feb 10, 2011 | 05:23 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
- A.I.R pump pulley (6 rib) $5 Shipped -Scrapped-
- Misc. Carburetor throttle cable brackets $5 Shipped -Scrapped-
- Power Steering Pump (Small Diameter pulley) I don't know if this is any good or not but consider it a core $10 Shipped -Scrapped-
Attached Thumbnails -TPI Intake and SBC parts--.i.r-pump-pulley.jpg   -TPI Intake and SBC parts--misc.-throttle-cable-brackets.jpg   -TPI Intake and SBC parts--power-steering-pump_core.jpg
Old Feb 10, 2011 | 05:33 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
- Weiand Supercharger Pulley (Crankshaft) $100 Shipped OBO
- V-Belt Pulleys (Crank & Water Pump) $10 Shipped - SOLD
If you don't see it here, I might have it. I have a ton of parts I still don't have images of. Just ask and I'll try and dig it up.
All prices have some wiggle room especially if your close enough to pick them up, But I have some of this stuff so cheap I may not be able to ship it for what I'm asking.
Thanks for looking, and all parts carry what I'm gonna call a warranty. If it doesn't work, or is broken, or whatever, I'll ship out another one if I have it or refund your money.
Attached Thumbnails -TPI Intake and SBC parts--weiand-supercharger-crank-pulley.jpg   -TPI Intake and SBC parts--sbc-v-belt-pulleys_2.jpg
Old Feb 10, 2011 | 08:19 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
do u have a carb'd sbc intake manifold for a 1987 and up?
Old Feb 11, 2011 | 09:23 AM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
Sorry kent624, I don't have one of those.
Old Feb 16, 2011 | 03:14 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
-Remanufactured firebird MAF. Bosch sensor with a made in Canada label. I can't read the part number or the name of the remanufacturer. $50 shipped - Sale pending
Attached Thumbnails -TPI Intake and SBC parts--capture_00009.jpg   -TPI Intake and SBC parts--capture_00010.jpg
Old Mar 6, 2011 | 05:57 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
still got the tpi?
Old Mar 7, 2011 | 11:49 AM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
yeah, I still have it. The one pictured is off an 85. I also have a very nice one off an 86 and one off a 91. All 5.0L set-ups.
Old Mar 7, 2011 | 01:24 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
if ur selling the one off the 91 camaro tpi ill take it any picks ?
Old Mar 7, 2011 | 05:28 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
I'll post some pics of the 91 intake up here soon. Its still currently attached to the engine.
Old Mar 7, 2011 | 05:49 PM
1BADZ28SD's Avatar
ok let me know if its 91 i want it
Old Mar 7, 2011 | 06:33 PM
travis401's Avatar
Car: 91 Camaro RS
It include the sensors?
Old Mar 8, 2011 | 10:23 AM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
What sensors do you need? I'll see what I can dig up. I should have multiples of all the sensors except for MAF's
Old Mar 8, 2011 | 10:27 AM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
- 91 TPI intake - SOLD
91 305ci SBC - engine has 160,000 miles on it. I just removed the intake manifold last night and the engine has quite a bit of sludge buildup. It did run but I would tear it down and clean/inspect before running it. $50 OBO Shipping = expensive
Attached Thumbnails -TPI Intake and SBC parts--91-tpi.jpg   -TPI Intake and SBC parts--91-tpi_2.jpg   -TPI Intake and SBC parts--91-tpi_3.jpg
Old Mar 8, 2011 | 10:58 AM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
- 4-bolt main SBC block. currently .030 over. Will need to be honed at the very least to clean up some surface rust. More than likely will need to be bored out another .030. Good High nickel content block (note the 010 and 020 castings in the timing chain area. $100 Shipping = expensive
Attached Thumbnails -TPI Intake and SBC parts--4-bolt-main-sbc.jpg   -TPI Intake and SBC parts--4-bolt-main-sbc_2.jpg
Old Mar 8, 2011 | 12:10 PM
1BADZ28SD's Avatar
Originally Posted by regalracer
- 91 TPI intake - Sale pending to 1BADZ28SD
If the intake sells, the rest of the engine is still for sale. $150 OBO Shipping = expensive
sold i want it !!!
Old Mar 8, 2011 | 04:24 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
I'll get working on removing it from the engine tonight. Let me know everything you need. Sensors? Wiring? ect.
Old Mar 8, 2011 | 07:14 PM
1BADZ28SD's Avatar
u tell me whats included ?
Old Mar 9, 2011 | 11:25 AM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
1BADZ28SD - you have a PM
Old Mar 9, 2011 | 10:47 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
so lucky...i need a 90-92 tpi. let me now if you get anymore? ill need comp/harness/everything to go from tbi to tpi, with cruise control if that makes a diffence.
Old Mar 9, 2011 | 11:20 PM
1BADZ28SD's Avatar
pm replay
Old Mar 10, 2011 | 01:42 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
DARKmj16 - I do still have the harness, ECM, distributor for the 91 TPI setup. I'll make you a real good deal. Otherwise this stuff will be headed to the scrap bin.
Old Mar 10, 2011 | 09:48 PM
DARKmj16's Avatar
Engine: 305 tbi
shot me a price and ill check around see if i can get the rest for a good deal.
Old Mar 16, 2011 | 10:18 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
PM Sent ------->
Old Apr 25, 2011 | 12:01 PM
regalracer's Avatar
Car: 1982 Trans Am
Engine: 355 ci
Make an offer on any of these parts, what doesn't sell is headed to the scrap yard.
check out my for sale album here
https://picasaweb.google.com/cmcracer20/PartsForSale#
Old Apr 25, 2011 | 12:06 PM
1BADZ28SD's Avatar
hey i will buy you the other intake if u want to sell it to me just make sure on the price with shipping
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
roysatikas
Sep 7, 2015 08:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
