[MI] Lots of parts for sale (more in Engine/DT/susp, Exterior, Misc. threads)
Car: '92 Camaro Vert
Engine: 305 TBI V8
Everything I ship out will have a tracking #. I can ship USPS, UPS, FedEX or DHL and will use whatever is cheapest if you have no preference. I will take PayPal or cash. I can be reached here, at JamMasterClay@gmail.com, or by phone at (248) 410-8367 (text messages preferred).
Photos can be seen here: http://s908.photobucket.com/user/Cla...Sale/Available
(Click on photos once to see it medium size with description, and a second time to see the photo larger.)
Please check out my other listings!
Engine/Drivetrain/Suspension: https://www.thirdgen.org/forums/engi...things-fs.html
Exterior: https://www.thirdgen.org/forums/exte...things-fs.html
Misc: https://www.thirdgen.org/forums/misc...isc-items.html
!!!ALL OFFERS CONSIDERED!!!
110 mph Camaro Instrument Cluster: This is a 110 mph instrument cluster for a '90-'92 Camaro. The odometer shows 165, 047.4 miles. I was told everything works (all bulbs and gauges) but I was never able to install it to test. $75
110 mph Camaro Instrument Cluster: This is a 110 mph instrument cluster for a '90-'92 Camaro. The needles are a dark orange as opposed to the yellow of the needles in other clusters I've seen. The speedometer/odometer weren't working when I pulled it out of my car. The front lens is cracked. All other gauges and all lights were working when I pulled it out of my car, so you could swap them into a different cluster or swap a different odometer/speedometer into this cluster. The odometer shows 159,993.0 miles. $25
Cigarette Lighter Socket (Stock): This is the stock cigarette lighter socket from a third-gen Camaro. $5
Headlight Switch: This is the stock headlight switch from a third-gen Camaro. $25
Tonneau Switch (Yellow): This is a rare yellow print tonneau release switch from a third-gen Camaro Convertible $85
'92 Convertible Tan Seat Belts: These were removed from my 1992 Camaro Convertible. The front belts will work in any third-gen convertible. The rear belts are specific to 1992 Third-gens. so these are RARE. Comes with front and rear retractors, rear mounts and mount covers, front and rear receivers, and rear seat belt guides. A few mounting bolts are included, but not all that are needed...just use your existing bolts. They are in great condition, the rear seatbelt guides are a little faded however. $650
Hood release assembly (yellow): This is the hood release lever and cable. Everything from where it screws in to the cabin out to the hood latch. Handle has yellow print in great condition. $30
Tan carpeted center console: Tan carpeted lower center console and upper center console. Also comes with 90-92 automatic shifter plate and ash tray, and a window switch. $100
Curvy radio/HVAC trim bezel: If you notice, the corners of this radio/trim bezel are curved, which is correct for 1990-92 Camaros. Will fit '82-'92. $20
(Red) Z28 5.0L H.O. Dash Emblem 1: Red Z28 5.0 Liter H.O. Dash Emblem, all mounting tabs in tact. Some dirt on the front which should rub off. $10
1DIN aftermarket radio mounting bracket: Used to mount single DIN head unit in the stock 1.5 DIN opening. Protrudes an extra .5" to allow installation of newer, deeper units. $15
'82-'89 cigarette lighter & defroster with trim: This is the trim piece located to the right of the instrument cluster in 82-89 Camaros. It includes the cigarette lighter socket and lighter, as well as a defroster switch. $20
Cigarette lighter (yellow): This is a yellow print cigarette lighter. Don't know if it works, but the print is in excellent condition. $5
(Red) Z28 5.0L H.O. Dash Emblem 2: Red Z28 5.0 Liter H.O. Dash Emblem, some broken mounting tabs but the front looks perfect. $7.50
'90-'92 Defroster switch bezel: Defroster switch bezel for 90-92 style dash. In perfect condition with all mounting tabs intact. $5
Door lock manual switch/indicator: This is the manual switch for door locks, which also indicates if they are locked or not. Compatible with all 3rd gens. A little dirty but should clean up. Felt still intact. $2.50
OE Mirror with maplights, wire harness: This is the stock mirror from my 92 Camaro convertible. It features map lights with an on/off switch, as well as a gear shift light that shines onto your gear shifter when your headlights are on. Map lights also turn on when doors are opened. Comes with wire harness, and a few different styles/sizes of fire looms. I can provide installation help. $20
Tan passenger area carpet: Used tan front carpet (passenger, interior area) See picture for condition. $100
Door Panel Mounting Tabs: Tabs that screw into door panels and hold them in place. 11 ct.. I don't know how many would be a complete set… $2
Black Door Panels 1: A set of black leather/carpeted door panels. Overall good condition, some paint chipping on the trim (can be seen in image c). Although they appear to have some water damage they are still very solid. Looks like they originally were in a Firebird with cup holders on the doors, and the holes have since been patched (picture e). I almost didn't even notice, you would have to have your head at the floor to see. $100
Black Door Panels 2: A set of rare black leather/carpeted door panels. These were apparently folded at some time and the back cardboard is very flimsy, but the front should look fine if mounted on good condition backing. I originally planned on using the upholstery on these with my current door panels, but I have since decided to get the Pontiac deluxe style door panels. These do have a hole for manual windows, but that can be easily patched with carpet or plugged with plastic. $100
Convertible trunk carpet pieces: These carpet pieces go in the trunk of convertibles to cover the well the top sits in when folded down. As you can see the carpeting is coming off, but it could be easily glued. $15
Convertible spare tire cover: Molded carpet spare tire cover for convertibles. In later years ASC provided this rather than the modified plastic pieces from hatchbacks. This is in very good condition with Velcro in-tact (I will also include plug for latch cover hole and velcro to attach the molded carpet to the latch cover). Probably a rare item as it was only in convertibles and only a year or two. $35
Bose kick-panel speakers: A set of Bose kick panel speakers. I don't know much about the Bose setup but it looks like these were recovered. The covering has the pattern from packing but should look okay if smoothed out. I thought I was going to go with a factory Bose system but have instead decided to go aftermarket and as such I am going to fabricate kick panels for aftermarket components. $75
Black convertible rear speaker panels: A set of rear interior panels for convertibles. This is the earlier style with the cutout for lap belts (such as the set I am selling). These do not include speakers or the speaker grille. I thought I'd install these in my car because I couldn't find the correct ones without the cutout (which were '92 only), but have since decided to get my panels re-upholstered. As with all interior parts, these are relatively hard to find. $100
Convertible trunk storage compartment: Two trunk trim panels for the storage compartment in convertibles (driver's side). Both black, but the one on the left must have been Armor-Alled because it is darker. Neither comes with the lock, but this can be easily added. These are both in great condition. Somehow I ended up with three of these, so these two are for sale... $100 each
Trunk storage box: Cardboard storage box for inside of the drivers side trunk locking compartment. This is compatible with both convertibles and hatchbacks. I thought I would need this for my car but I was able to adapt my molded carpet to work so I have no use for this. It appears to have some water damage but is still solid. It's a little dusty, but once installed should look very nice. $20
Black passenger sun visors: Black passenger sun visors. These are the curved style for T-Top/convertibles (however they should work in hard-tops as well). Top is in perfect condition, bottom has a little wear as can be seen in the pictures. Hinges and mounting screws included. When I purchased my car it had no sun visors and somehow I ended up with three passenger ones and one driver's. $50 for top one in pic, $25 for bottom one
Emergency brake handle: Emergency brake handle (plastic). Taken off of my '92. $10
Automatic gear shift handle: Gear shifter handle for automatic car (plastic). Removed from '92 Camaro but should work with any thirdgen. $20
Dash switch bezels: Bezels for 90-92 style instrument panel surround. The one on the left in the pics is for the left side of the steering wheel. Someone drilled a hole in it for a switch. One on the right in the picture is for the right side of the steering wheel, for cars without rear defroster. $5 each
Trunk latch bolts: Bolts to attach trunk latch to body. Not sure of compatibility. My convertible cane with a slam-down latch (2 bolts) and I installed a pull-down (91.5-92 uses 3 bolts, don't know about older pull-downs). $5
Center console cover: Hinged cover for Camaro center console. Someone must have really hated the guy who owned the car before me because they sliced into this (as well as keying the car). $0
Power mirror control (yellow): Control switch for power mirrors, and bezel. From my '92 with yellow text. Worked when I removed it. $25
Trunk latch wire harness plug: This holds the wires that plug into the trunk latch (at least for 91.5-92 slam-down and pull-down latches) $0
Spare tire rest: This came out of the back of my '92 Camaro Convertible. I never had a spare for it but I'm assuming it just sits on this. I have no use for it because I don't have a spare. The top part looks great, the bottom is a little dirty. $25
Hard-top sun visors: Sun visors for a hard-top thirdgen. I purchased these shortly after I bought my '92 Camaro and didn't realise that the hard-top ones were different than t-top/convertibles. Seller said they were black but faded…they look brown to me. $50
Black leather convertible rear speaker panel: Drivers side rear interior speaker panel. Black leather, speaker and light included. Has cutout for seatbelt, I believe this is from 89-91 convertibles, but not entirely sure. Looks much better in person, but could use a good wipe down to look great. $75
Bose Delco Radio/Cassette: This is a Bose radio and cassette player from a Camaro. It is in extremely good condition (needs to be dusted). Never installed it but was told it was from an 87 and was told that it works. $150
SOLD:
Tan armrests: Set of tan arm rests. These are the newer style that came out of my '92, but will work with any thirdgen (with the exception of those with the Pontiac deluxe door panels). They are in great condition with no real defects that I know of. Mounting screws included.
HVAC Control (yellow): HVAC control for 90-92 Camaro, and mounting bracket. Exactly as pictured.
HVAC Control (white): HVAC control with white print. Comes with mounting bracket and screws, exactly as pictured.
Trunk switch (yellow): Trunk switch (yellow print). It has a chip in it as can be seen in the pictures.
Automatic shifter plate (white): This is a shifter plate for automatic transmission Camaros. Ash tray is included. There is some melting between the shifter and ash tray as can be seen in picture b. Ash tray is illuminated with a fiber optic wire as can be seen in picture a.
Window Switch (Broken): This is a stock window switch. The print is faded on it, and one of the springs inside is missing. This would be good for parts to repair a broken window switch.
Kick Panel Speaker Holders (black): These are custom fabricated kick panels for the third-gen. They are painted/upholstered in black and can hold a shallow mount speaker up to 5" in diameter.
I also have some stuff that's on the car right now but I am planning on selling. If anyone's interested in this stuff I should be able to get it to you before too long.
SOLD:
- 25th anniv RS dash emblem
- Tan leather seats - Fronts are removed, pics available on request. I need to find black leather split-back rear seats. If I don't I'm keeping the rears and getting them reupholstered. I could sell old upholstery.
- Tan door panels
- Black arm rests
- Door handle trim
- Window switch (yellow): Power window switch with yellow printing (somewhat worn). Came off of my '92 Camaro and worked fine, but I'm switching to white printed stuff. $5
Car: 89 Iroc Convertible
Re: Lots of parts for sale (more in Engine/DT/susp, Exterior, Misc. threads)
Black convertible seatbelts - full set:......Would you sell just the front retractor units?
Engine: 305 TBI V8
I'd rather not split up the set, but make me an offer...
Id give you 75 dollars shipped.The same amount you got them for from Bradley.
Engine: 305 TBI V8
I think only the rears are from Bradley. I had to get a few sets to get everything I needed for my year (if you look in the picture there's actually three receivers for the rear and four for the front...) The absolute cheapest I could do is $80+shipping. I looked into how much I spent for everything and even there I'm taking a loss. If you give me your zip I could get you a shipping quote in the morning.
Thats ok,I have several spare sets of vert belts in various colors.Will most likely end up dying one set black
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Since purchasing my '92 Camaro Convertible back in July I have collected a fair amount of parts, so I'd like to start getting rid of some stuff. Most of this stuff I purchased with the intent to use on my car but have since changed my mind or found that it wouldn't work for my car. A lot of it I only took out of the box for pictures. I would prefer meeting at a public place for pickup, but I can ship stuff out as well at your expense (Everything I ship out will have a tracking #. I can ship USPS, UPS, or FedEX and will use whatever is cheapest if you have no preference). I will take PayPal or cash. I can be reached here, at JamMasterClay@gmail.com, or by phone at (248) 410-8367 (text messages preferred).
Photos can be seen here: http://s908.photobucket.com/home/ClaytonJamesPhotography/tag/Camaro%2520-%2520Interior
Radio Install Kit: Kit used to mount single DIN head unit in the stock 1.5 DIN opening. Protrudes an extra .5" to allow installation of newer, deeper units. $15
Rear latch cover for locking shelf: Rare black plastic carpeted rear latch cover. This latch cover is needed to use the locking shelf (with or without the Bose speakers). This one is only compatible with vehicles without the pull-down hatch motor. It has the trunk light, and a switch (I'm assuming for the trunk light, but the automatic function could be maintained if you already have it). $200 SOLD
Locking Trunk Shelf: Black carpeted locking trunk shelf for cars without hatch pull-down motor. Compatible with "Rear latch cover for locking shelf" I am selling. This is perfect to hide valuables in your trunk, or a good place to mount amps, speakers, etc. Unfortunately it will not work in convertibles without major modification, which is why I am selling it. $50 SOLD
Black front passenger seatbelt: This is in extremely good condition as can be seen in the pictures. The only reason I'm not installing it in my own car is because I didn't realize that the seatbelts are different for convertibles. $50
Black convertible seatbelts - full set: The front two seat belts in this set are correct for all third-gen convertibles. The rears are the lap-belt only style (I think these were 82-88 with two piece lap and shoulder in 89-91 and one piece lap/shoulder in 92) This is a complete set. The buttons on the receivers are pretty faded but these can be easily fixed. I was told that one of the rear belts doesn't lock...probably because of rust which may be fixable. I'm only selling these because I can't use the rears in my 92 and I ended up finding a complete front/rear set for 92. These are pretty rare because they are convertible specific... $200
Tan armrests: Set of tan arm rests. These are the newer style that came out of my '92, but will work with any thirdgen (with the exception of those with the Pontiac deluxe door panels). They are in great condition with no real defects that I know of. Mounting screws included. $30
Radio/HVAC trim bezel: Trim bezel for around the radio and heat-A/C controls. Appears to be perfect condition. $10
Power mirror control (white): Control switch for power mirrors. White Text - not sure if it's compatible with center console location in Pontiacs. Never tested but was told it works…somehow in switching my yellow print stuff to white I ended up with two of these. $15
Trunk switch (yellow): Trunk switch (yellow print). It has a chip in it as can be seen in the pictures. $0
Trunk switch (white): Trunk release switch (white print). Works, has some fading, scratches. $5
- Dashpad - no cracks
- Steering wheel with airbag
- Yellow print HVAC control
- Tan center console
- Tan carpet - can remove when I get black carpet
- Tan kick panels
- Tan door sills
- Tan "J" shape convertible trim
- Tan leather seats - I need to find black leather split-back rear seats. If I don't I'm keeping the rears and getting them reupholstered. I could sell old upholstery.
- Yellow print lock/unlock (x2)
- Tan door panels
- Black arm rests
- Door handle trim
- Tan convertible rear speaker panels - I have yet to find these for a '92 in black leather, so I will probably have to get this reupholstered and sell just the upholstry
- Tan seatbelts - fronts will work in any third-gen vert, rears are 92 specific
How much for the dash pad, shipped to 22701 ??? got a pic of it..? Stone
Engine: 305 TBI V8
Here's some pics: http://s908.photobucket.com/albums/a...le/Dash%20Pad/
I won't know shipping until I can remove it and box it up. I think I might just hold on to it though, I was going to get a Firebird one because I like the speaker grilles better, but after doing some more research I've found out it won't fit.
Engine: 305 TBI V8
Items added:
Want a title? Post!
Car: 1984 trans am, black&silver,Recaro
Engine: manual v8
Transmission: manual
Will the defrost reapir kit bwork for a 1984 trans am?
Suz
Suz
Engine: 305 TBI V8
The defroster repair kits only contain the connector and cover to fix the wiring going to the defroster. If the problem is with the grid itself you will need something else. What exactly needs to be fixed on your defroster?
is it power windows and locks or no? If so how much for the whole power locks, and windows harness and set up. If not how much for a complete drivers side door panel arm rest and all shipped to 19530
Engine: 305 TBI V8
It does have power locks and windows, but I'm not parting out the entire car and I definitely need to keep the power locks and windows.
As for the door panel, I would rather not split up the driver's and passengers side but I will consider it. Which door panel are you interested in? I have two different styles of black ones, and I have tan ones that are currently in the car. I also have older style black arm rests and newer tan arm rests. What else exactly do you need, the handle trim, switches, etc? I won't be able to get you a price until tomorrow at the earliest because I work all night. Also, if you're interested in the tan panel it'll be a little bit until I can take it off the car...
Engine: 305 TBI V8
Items added:
Curvy radio/HVAC trim bezel: If you notice, the corners of this radio/trim bezel are curved, which is correct for 1990-92 Camaros. Will fit '82-'92. $20I
Black seat belt receiver: I believe this is a rear receiver, but it is longer than the ones in my 92 Camaro. It is in excellent condition, and I'm disappointed that I can't use it in my car. $10
Coat hanger hooks: Because I own a convertible, I don't know much about these. I believe they mount to the top of the rear speaker grill. I believe they are dark grey in color but they look almost black. $5
Automatic shifter plate (white): This is a shifter plate for automatic transmission Camaros. Ash tray is included. There is some melting between the shifter and ash tray as can be seen in picture b. Ash tray is illuminated with a fiber optic wire as can be seen in picture a. $0
HVAC Control (yellow): HVAC control for 90-92 Camaro, and mounting bracket. Exactly as pictured. $10
HVAC Control (white): HVAC control with white print. Comes with mounting bracket and screws, exactly as pictured. $20
HVAC/Radio trim bezel: This is the older style trim bezel with squared edges, but is compatible with all Camaros 82-92. $20
Round Leather Automatic Shifter ****: Don't know anything about this, but it appears to be a shifter **** for an automatic car. It is round and wrapped in leather, and in excellent condition. $25
Want a title? Post!
Engine: manual v8
Items added:
I'm replying to an email I got listing a part for a 82 ect...transam. Its a square HVAC/radio trim bezel for 20 dollars. Id like very much to buy it. I live in Fairfiled Ca. Zip 94534. What would that be incliding for post as well? Mine is cracked and I need to replace it. I am a serous buyer and can pay with paypal.
Warm regards Susan Davison.
Want a title? Post!
Engine: manual v8
I'm interested in the square HVAC/RADIO bezel for 84 trans am at 20 dollars. I live in Fairfield CA. What would that be for post as well. I'm a serious buyer and can pay with paypal.
Regards Susan
Regards Susan
Engine: 305 TBI V8
I will look for a box for that and try to get a shipping quote for you tomorrow. I don't expect if would be more than $5-$8 but I'll let you know.
Thank you for the inquiry
Clayton
Clayton
Engine: 305 TBI V8
Items Added:
Window Switch (Broken): This is a stock window switch. The print is faded on it, and one of the springs inside is missing. This would be good for parts to repair a broken window switch. $2
Window Switch: This is a stock window switch. The print is faded on it. $5
Kick Panel Speaker Holders (black): These are custom fabricated kick panels for the third-gen. They are painted/upholstered in black and can hold a shallow mount speaker up to 5" in diameter. $50
Car: 1991 red Z/28
Transmission: T5 swap
Do you have this plastic hose. Runs from the charcoal cannister to the throttle body. I circled the part. https://www.thirdgen.org/forums/atta...astic-hose.jpg
Engine: 305 TBI V8
Engine: 305 TBI V8
Items sold:
Window Switch: This is a stock window switch. The print is faded on it. sold
Black seat belt receiver: I believe this is a rear receiver, but it is longer than the ones in my 92 Camaro. It is in excellent condition, and I'm disappointed that I can't use it in my car. sold
Coat hanger hooks: Because I own a convertible, I don't know much about these. I believe they mount to the top of the rear speaker grill. I believe they are dark grey in color but they look almost black. sold
Black convertible seat belts - full set: The front two seat belts in this set are correct for all third-gen convertibles. The rears are the lap-belt only style (I think these were 82-88 with two piece lap and shoulder in 89-91 and one piece lap/shoulder in 92) This is a complete set. The buttons on the receivers are pretty faded but these can be easily fixed. I was told that one of the rear belts doesn't lock...probably because of rust which may be fixable. I'm only selling these because I can't use the rears in my 92 and I ended up finding a complete front/rear set for 92. These are pretty rare because they are convertible specific... Front belts and two of the four front receivers are gone. I still have the rear lap belts which are NOT convertible specific, and front and rear receivers. sold
Power mirror control (white): Control switch for power mirrors. White Text - not sure if it's compatible with center console location in Pontiacs. Never tested but was told it works…somehow in switching my yellow print stuff to white I ended up with two of these. sold
Engine: 305 TBI V8
Items Added:
Engine: 305 TBI V8
SOLD:
Tan armrests: Set of tan arm rests. These are the newer style that came out of my '92, but will work with any thirdgen (with the exception of those with the Pontiac deluxe door panels). They are in great condition with no real defects that I know of. Mounting screws included. sold
HVAC Control (yellow): HVAC control for 90-92 Camaro, and mounting bracket. Exactly as pictured. sold
HVAC Control (white): HVAC control with white print. Comes with mounting bracket and screws, exactly as pictured. sold
Trunk switch (yellow): Trunk switch (yellow print). It has a chip in it as can be seen in the pictures. sold
Automatic shifter plate (white): This is a shifter plate for automatic transmission Camaros. Ash tray is included. There is some melting between the shifter and ash tray as can be seen in picture b. Ash tray is illuminated with a fiber optic wire as can be seen in picture a. sold
Window Switch (Broken): This is a stock window switch. The print is faded on it, and one of the springs inside is missing. This would be good for parts to repair a broken window switch. sold
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
do you have the remote hatch release mechanism (mounts on inside tailpanel?)
Engine: 305 TBI V8
Engine: 305 TBI V8
Car: 1984 Firebird SE
Engine: 2.8 L
Transmission: Automatic
Would you happen to have the 4 screws that hold the dashpad on through the defrost vents?
Thanks!
Chris
Thanks!
Chris
Engine: 305 TBI V8
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Do you have a 87 trans am stock shifter assembly?
Hi
I need the right rear side panel including the speaker sail section. Need light gray in color. 1986 iroc z. Do you have this piece. If so, how much?
thanks
C. Oren
thanks
C. Oren
Engine: 305 TBI V8
I am extremely sorry I did not see this post two years ago, somehow I missed the notification about it. I'm sure you're not still looking, but I don't have that part. Again, I am very sorry.
I have sail panels without the speakers: http://s908.photobucket.com/user/Cla...l?sort=3&o=104
I also have a driver-side sail panel with the speaker: http://s908.photobucket.com/user/Cla...ml?sort=3&o=54
I do not know the exact years that these panels are from. I'm sorry, good luck with your search!
INTRESTED IN THESE ITEMS SHIPPED TO 33615, WILL YOU DO 30 SHIPPED?
Engine: 305 TBI V8
Sure I should be able to get it shipped out some time this week if you still want it.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
