mild comp roller cam
Old Apr 9, 2011 | 09:49 PM
tpibird305spd's Avatar
Car: firebird
Transmission: T-5 NWC
Axle/Gears: 4.11
have this cam sitting in my garage. its an XR-264-HR and its for a factory roller motor. its allmost new with less than 500 miles on it. i bought everything new as a matching combo from comp when i built my motor. the lifters are the high energy rollers and the springs are 986-16 1.43inch outer dia double w/dampers. look up xr264hr and see comps' dyno sheet with a near identical engine and they made 335hp and 421ft/lbs
slightly noticable idle good vacume
valve lift with 1.5 rocker .487intake .495exhaust
lobe lift .325intake .330exhaust
duration @ .050 212intake 218exhaust
lobe separation 110.0
i went 13.1 @ 110mph on radials/nwc T-5/3.73 in my 86 firebird leaving the line at idle
Old Apr 9, 2011 | 09:53 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Re: mild comp roller cam
Pm sent
Old Apr 10, 2011 | 06:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
And the price is ...............................?
Old Apr 11, 2011 | 11:46 AM
Car: firebird
Axle/Gears: 4.11
$200-cam
$110-lifters
$50-springs
Also looking for Firebird and or sbc stuff. let me know what you have
Old Apr 16, 2011 | 03:39 PM
Car: firebird
Axle/Gears: 4.11
Cam and springs pending payment
Old Apr 17, 2011 | 12:50 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Do you have a part number for the lifters?
Old Apr 17, 2011 | 12:56 PM
Car: firebird
Axle/Gears: 4.11
850-16 High Energy for oem roller cam sbc
Old Apr 17, 2011 | 06:49 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Do factory heads need machined to fit these springs?
Old Apr 17, 2011 | 11:15 PM
Car: firebird
Axle/Gears: 4.11
1badeagle the cam and springs are sold but the answere to your question is yes the spring pockets would have to be opened up for the 1.46" springs.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Stryker412
Sep 7, 2015 09:11 AM
