parting out 1989 formula 350
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
parting whole car. pbr disk posi
tpi setup
much more
tpi setup
much more
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
Re: parting out 1989 formula 350
how is the a/c unit? Blows cold? How much for the compressor to 12564?
Car: 88 Firebird Formula
Transmission: WC T5
Axle/Gears: 9 Bolt 3.45
how much for the air intake boot (the second part that attaches to the TB) ... shipped to 03608
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
how much for all the emission hoses and the black looking box on the left side of the engine its i think an air diverter or something like that but i need all the emission stuff don't need the egr just the stuff on the side of the engine if u can send pics of what I'm talkin about that would be great and shipped to lancaster , CA 93535
ill buy the tpi distributor cover and the boot that conects to the throtle body shipped to lancaster CA 93535
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
How much for the under hood chassis portion of the wire harness? C100 connector around to the starter. Can send picture if you are not familiar how it unplugs (I wasn't until last weekend). MI, 48350
Not the engine harness, but it is under the hood. Just the part not connected to the ECM. https://www.thirdgen.org/forums/atta...00_harness.jpg There is a 2 or 3 pin connector joining it to the engine harness near the firewall pass through. 2 more connectors join it to the HVAC above the heater core. At the firewall it is bolted together with the light harness. This harness goes C100 firewall to AC compressor, wipers, alternator and starter.
Somebody else can have the whole TPI setup and its engine harness.
Car: 89 GTA
Need Alternator/Power Steering Pump bracket shipped to 38008...will also want A/C Compressor with connector if it isnt already sold.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
do you have the door map/cupholders? looking for driver and passenger including mounting screws and caps to cover screw holes.
Car: 1992 Firebird Formula T-Top
Engine: 5.7 TPI
Transmission: TH700-R4
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
how much for the runners shipped and the egr temp wire if in good condition on both to IL 60073
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
is the temp sensor wire in good condition i will take if you can send a pic that would be great kowalski_rich@yahoo.com and your pay pal thanks
if you got the t/v accelaretor cable goes on gas pedal to throttle body if you got it ill buy from you would like some pics and a price
Car: Corvette
Engine: 5.7
Hey Don,
Do you have a TPI ignition coil and mounting bracket and a trans kick down cable and throttle cable from a tbi car? If so I need them and can pick them up on Friday if your available thanks.
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
How about the third taillight lense and the rear deck panel under the spoiler? any rust?
