Parting out 88 Trans am 5 speed car, lot of upgrades SOLD!!
Updated 8/24/11
Car and all parts are sold, thanks everyone
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
Re: Parting out 88 Trans am 5 speed car, lot of upgrades
Which March set is it? 4010? Is the belt for no smog pump or a smog pump? Are they in good shape? If so I'll take em.
March part # 4000, it's the 2 piece black powder coat version, one for crank and one for alt., you still need a shorter belt which is included. It's made to run with smog pump, I also have new Dayco Smog pump bypass pulley. Both pulleys and belt are new, have been installed for a short period but never run. Pulleys have slight marks where the bolt head locked them down other wise as new, belt is new never run Goodyear gatorback.
Will do $75 shipped
Will do $75 shipped
Car: 91 Z28, 2014 ZL1
Engine: 383, LSA
Transmission: WC T-5, T6060
Axle/Gears: 3.73 in both
Do you know what part# the headers are? How much shipped to 28539
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
pm sent
I'll Shoot some pics this afternoon on the KYB's and Tokico's both were installed but car never moved, so no miles on them.
Shifter is factory GM shifter, New, slight surface rust on stick, easy fix with sanding and paint.
$60 shipped for shifter
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Axle/Gears: 3.42 Posi
Do you have the upper radiator support and lower bracket for dual fans?
Upper radiator shroud and lower fan bracket are both sold.
Formula Wheels need to be redone as in: yes they have some curb rash, clear peeling and RH front has small ding. I've taken pics but most of this cannot be seen, the pics make the wheels look better than they are so I am not posting them for someone to think they are better than they are and be disappointed when they receive them. Center caps are included but not in the best shape.
This is why I'm asking $20 per wheel, they need work
Car: 88 Firebird formula clone
Engine: Yeah its in there
Transmission: Thats in there too
Axle/Gears: Yeah there in the back
how much for the rear sway bar? and did it have disc brakes?
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
